On my mk2 16v jetta I found that the bushing at the front of the shift box is very worn causing side to side play on the gear lever.
Does the orange bush in the kits from goldwagen also fit in that black rubber housing, or is it a complete bush assembly?
Any tips on making the job easier when replacing it? Do you remove the whole shift box and rod from the car?
Vw mk2 16v shift box bushing
- Carel040
Re: Vw mk2 16v shift box bushing
Yes it is a k@k job have to remove exhaust
