Vaal Triangle Spintronics tuner?
- jmms
- Car Make: VW T3
- Car Model: Caravelle Automatic
Hi All
I'm in the process of swapping an AGG into my VW Caravelle Kombi and I'm looking for a company or person that does Dyno tuning on the Spintronics system in the bus.
Anyone that you can suggest?
For now, thanks in advance.
Re: Vaal Triangle Spintronics tuner?
Phone ACD Vaal Motorsport on 016 3623267 in Meyerton. They are at the Model service station c/o Johan le Roux and Galloway street (Across the corner from the fire department).
AFAIK they do tuning on Spitronics and Dicktator systems and do Unichip.
Edit:
Email: info@vaalmotorsport.co.za
Website: http://www.vaalmotorsport.co.za
Edit:
- jmms
- Car Make: VW T3
Thanks PapaJo, I'll give them a call
jmms wrote:Thanks PapaJo, I'll give them a call
- Membership No: 2033
OP is looking for Spintronics, though.........PapaJo wrote: AFAIK they do tuning on Spitronics and Dicktator systems and do Unichip.
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
Ok on a more serious note to the OP, before I attempt to link up via a very long cable or wifi to try and assist.
Do you have a base map loaded in the ECU (specify the type of Spitronics ECU you have, eg Pluto2) and is all wiring done and you can start up and only require a tune?
- jmms
- Car Make: VW T3
Hi
Yes, do have a base map loaded on a Saturn Standard (can't start yet as I'm waiting for the exhaust to be done)
I think I'll only need a tune (well the engine so to speak)
- jmms
- Car Make: VW T3
actually I am a DJTHANAS wrote:He wants to be a DJ, DJ JJMS.
But the name came from long ago when I was first diagnosed with MS and my initials JM
Ok post up here if you need help.jmms wrote:Hi
Did you phone ACD motorsport to enquire if they can tune it for you?
- jmms
- Car Make: VW T3
Thanks, I'll check with ACD motorsport in the am.PapaJo wrote:Ok post up here if you need help.jmms wrote:Hi
Any updates?
