Gotech MFI X
Gotech MFI X
I have a Gotech MFI X battery died and I think it lost map because it's over fueling and missing a lot, I have the map on a USB from my tuner, i downloaded the software, how do I reload the map? The software came with 3 things " Dealer tune" , "ProX tuner" and "gear x" now I tried opening dealer tube but it does not open my map, my map is an .ecu file,and ProX keeps on saying "not responding" so as I do anything( with out connecting the Gotech yet) any suggestions?
Re: Gotech MFI X
you have to connect the unit. Won't do a thing without the unit connected.
Re: Gotech MFI X
Ok which app do I use for it? As the software came with 3, dealer tune, ProX2p4 and GearX
Re: Gotech MFI X
Dealer tune.
Re: Gotech MFI X
Why dealer tune? Last time I tried using dealer tune it didn't detect the box, also dealer tune doesn't open any maps, it doesn't detect .ecu files
Re: Gotech MFI X
Re: Gotech MFI X
Yes on that site doesn't it say MFI X uses Pro X?
Re: Gotech MFI X
Yes so try that.
- Car Make: VW Golf 1
- Car Model: 2.0 h8 valve
Re: Gotech MFI X
ProX is the right one to use....When using ProX, connect up to the management, open the program, and then start the car....Without starting the car it will not pick on the software....Had the same issue when I attempted to reload my last map!!!
Low Battery + Gotech MFIX = endless problem
My map spiked so badly that the timing and fuelling was the same across all rpm ranges (eish)
Re: Gotech MFI X
Also, if you need a cable let me know...You can borrow mine no problem
Re: Gotech MFI X
Yes please! I've been looking for a cable! I live in Newcastle and don't know where to buy it from!
Re: Gotech MFI X
Go to any computer shop and buy a usb to serial converter.
Re: Gotech MFI X
I got the adapter, tried to connect to my laptop(windows 7) but it's not picking up, on the bottom it says monitoring for port activity, then but nothing, when I move my mouse, the top in the bar says not responding
Re: Gotech MFI X
So I figured out why, it's coz I have windows 7 professional, it needs windows 7 ultimate.. damn
Re: Gotech MFI X
ProX doesnt respond on any of the laptops I've tried, I did it with mine and my friends laptop which has windows 10 on it8VALVE-zn wrote:ProX is the right one to use....When using ProX, connect up to the management, open the program, and then start the car....Without starting the car it will not pick on the software....Had the same issue when I attempted to reload my last map!!!
Re: Gotech MFI X
Plug in, open the program with ignition on, and then start the car.
The application will open and work fine if you follow this.
Re: Gotech MFI X
With any windows?8VALVE-zn wrote:Plug in, open the program with ignition on, and then start the car.
Re: Gotech MFI X
Windows 10 requires some add-on programs I believe, its not straight forward like the other windows versions.
Try with the laptop running on windows 7.
