No trigger in dictator
Hi guys I'm new at this please can someone help me I have a vr6 golf and I have a dictator wen I connect it it does not trigger but if I change the box it works with a turbo map and then my box workes at times I sent my box to dictator and the say no fault found please tell me Wat am I doing wrong
Re: No trigger in dictator
Give us more information on your setup to assist you in identifying where the problem may be.
Ok so with another box it works??? That then confirms you are getting a trigger input on that box. Is the test box same type as yours, ie 60-2? What ignition trigger is used and selected on Dicktator?
Did you perform a setup for correct ignition on your ecu and did you load the start up map? Post your ignition page setup here.
Dictator uses a trigger spcific box. So it must say 60-2 otherwise it will not work.
Hi guys the 60-2 dicktator is working but now i cant find the wire for the rev counter on the car please help i really need to speak to someone please can i have a number to call if not this is mine 061 120 0408 thanks
See this for reference. Might help.
http://www.a2resource.com/electrical/ma ... r6aba.html
Pin 22 is tacho output from Motronic ecu to dash. Green/Black wire, find is on your dash and splice in.
