Either get a custom gasket made or use a spacer and two gaskets.
Speak to redline engineering they can make you a gasket.
Or investigate using ethanol. You can buy bulk drums and is cheaper than avgas.
Devils own alcohol injection
Re: Devils own alcohol injection
Thank you Papajo I really appreciate your help, if a copper gasket is no good for my application, what material do you recommend ?
Thank you Papajo your help is much appreciated, if a copper gasket is no good for my application, which material do you recommend ?
- Donavan
Audi A4 B8 2.0T - Daily
