Vw Workshop Manuals
johnathanfraser
Re: Vw Workshop Manuals
Post by johnathanfraser »
if anyone can help im looking for a caddy 2002 pdf complete and free manual im having all the hell in the world with this one that would awnser all my questions pls send me a download link thread kind regards johnathan
Andre Delport
Car Model: MK1 CTi 1995
Post by Andre Delport »
Hi Guys
I am looking for a workshop manual for VOLKSWAGEN Polo Classic 1996 - 1998 (1.8I)
New/second-hand or a Pdf download.
Help would appreciated.
Phreak
Wheel Whore
Registered for: 7 years 10 months
Car Make: VW only
Car Model: Feet
Post by Phreak »
Hey Guys and Gals
I came across these eye candies to please our reading pleasures
http://www.cardiagn.com/
http://www.cardiagnostics.be/-now/VAS%2 ... rogram.htm
there are more but i can not find the links now
will post them when i find them
1998 Golf 3 - Donor to what I want,
1999 VW Microbus - stripped for parts- got tired of waiting for spares
2004 VW Golf 4 ex
1998 Audi A4 ex
1996 VW Golf 3 ex
1992 VW Golf 1 aka ' The Little ****" met a lamp post sadly
1986 Ford Saphire ex
1987 Ford Meteor ex
1969 Ford Capri GT ex
nothing in life is what is seems until you explore the truth behind what people do not what you to know.
If life is not about falling, then why are we here
Phreak
Wheel Whore
Car Make: VW only
Car Model: Feet
Post by Phreak »
Oh and this one
and for those who do not know this is also available to us now
http://etka.cc/
2004 VW Golf 4 ex
1998 Audi A4 ex
1996 VW Golf 3 ex
1987 Ford Meteor ex
cado
Post by cado »
I have a polo 2 (round light)9N have received an advise from someone that my stub axle is bent . Please advise if I need to change both stub axle or just the one that is bended
Bospatrollie
Car Model: Mk2 GTi 1.8 8v; 9n Polo 1.9Tdi
Post by Bospatrollie »
cado wrote:Hi guys
Why post here, in this thread about manuals, regarding your car's stub axles? If just the one is bent (how the hell to you bend a stub axle?) then replace it. I usually follow a rule-of-thumb with certain things i.e ball joints, wheel bearings, tie rod ends, cam belt etc. whereby, if I do one, I do the other. With the cam belt, I always replace the tensioner as well, but that's just me.
'87 Mk2 1.8 8V GTi (Current) 84wkw,130Nm
'05 Polo 1.9 Tdi (Current)
'72 Landy Series LWB Bakkie (Sadly missed)
'06 Freelander Td4 (SH*T)
'04 Colt Rodeo 2.8 Tdi DC
'03 Isuzu KB250 DC (One of the Best vehicles ever!)
'94 323 1.6i Sport Sedan
'89 323 2.0 EGi Hatch
'96 Audi Cabriolet 2.6E
'95 Audi 80 2.0 16V Quattro
'83 Skyline Hatch R30 2.8
Fitted Kawa 1000 engine to Mini
Upgraded mini to 1275
'75 Mini Clubman - 1000cc
'92 Laser 2.0 16V
'92 Laser 1.6i
'92 GTi 2.0 16V
'78 Lancia Beta 2.0 16V Coupè
cado
Post by cado »
hi
I'm new on this forum.I'm still learning .
thanks
Ashveer03
Post by Ashveer03 »
Any workshop/repair manuals for polo 9n pd tdi? The second link Phreak mentioned has a polo 9n manual but it is more like an owners manual, not so technical..
Any help sourcing this will be appreciated.
Ashveer03
Post by Ashveer03 »
Johan142 wrote:hi
im new to the vw family got myself a vw golf 5 1.9tdi
i have a problem with my cd player the cd seems to be stuck what is
the steps that i can take to get it out and working again
thanks
If u can hear the the motor in the radio making a noise when u press the the eject button, i think the only way to remove the disc is by stripping the radio up and removing it manually...' these head units are quite fragile though, rather get it to a sound shop if u arent sure..
pokker-old Dub Lover
Post by pokker-old Dub Lover »
Et guys in new here...drive a 1998 vw polo 1.6i and has been strugling with da wiring on my cluster. My Speedo and tacho is also not working. I replaced da gearbox speed sensor and check for voltage on da da sensor ,everything is fine but it seems there's no signal to da cluster. I want to test da cluster signal but don't have a detailed diagram for da cluster plug pin out. Any help guys?
Malcolm Goliath
Registered for: 8 years 2 months
Post by Malcolm Goliath »
Hi. Anyone have a copy of the Polo Classic 1.4i 1999 VW Workshop Manual please?
Also, how do I remove the dashboard as I need to replace the heater.
Thanx
Tabiso
Post by Tabiso »
Responding to radio issue and only if your radio is still original. First remove the outer layer covering the radio dash, with a piece of hardened plastic chip as this is very, very fragile nhe, and unsrew the screws on the sites. On top of the dash, open the squared bracket covering, there is a screw to loosen up, some few if not one wire and you will see what needs to be done. Coming to the radio, there are cables to unpluck at the lower back of the radio. Just check the points from which you are unplucking and there rest is for you to deal with the cd/radio.
Tabiso
Post by Tabiso »
Tabiso wrote:Responding to radio issue and only if your radio is still original. First remove the outer layer covering the radio dash, with a piece of hardened plastic chip as this is very, very fragile nhe, and unsrew the screws on the sites. On top of the dash, open the squared bracket covering, there is a screw to loosen up, some few if not one wire and you will see what needs to be done. Coming to the radio, there are cables to unpluck at the lower back of the radio. Just check the points from which you are unplucking and there rest is for you to deal with the cd/radio.
By the way Johan142, I am driving the same vw
JoBotha
Post by JoBotha »
Good day. I dont see any posts here lately. Is the forum still in use? I am looking for technical information with regards to a 1991 2.5 microbus. a Few butchers have been at work with the wiring so wiring information would be nice. Info on the engine (I dont know what all the solinoids and valves and pipes do) would be nice to. Any help will be greatly appreciated.
RobinCo
Registered for: 6 years 1 month
Post by RobinCo »
Hi Guys,
Does anyone Know where I can get a workshop manual for the VW Caddy 1.9 TDI
PLEASE HELP!!
Ashveer03
Post by Ashveer03 »
Wat do u need info on?
The_Librarian
Car Make: VW Sharan
Car Model: 1.8T
Post by The_Librarian »
Good morning guys
We have purchased a 2nd hand VW Sharan (2005, 1.8T model). I'm looking for the manual, but it is like finding a needle in a haystack.
Can somebody assist?
I need the OWM for sorting out the electric windows, central locking and one or two extra things besides.
TIA
Ook
cashsafe
Post by cashsafe »
RobinCo wrote: Thu Mar 15, 2018 10:40 pm Hi Guys,
PLEASE HELP!!
I am also desperately looking for one
Ashveer03
Post by Ashveer03 »
What exactly do u need from the manual?
riza
Post by riza »
Hi does anyone have a workshop manual for Jetta 4 1.6.
My trip meter does not reset and car is very sluggish
thanks
DobryiMihail
Post by DobryiMihail »
Hi everybody! A lot of Service Repair manuals for Volkswagen you can find and free download here - https://carmanualshub.com/category/auto ... olkswagen/
Lnrathan
Post by Lnrathan »
hi
is there any workshop manuals for the new spec citigolfs mpi and mp9?
Gummi
Car Model: Mk4 Jetta V5 AGZ
Post by Gummi »
Hi Guys. Anybody that can assist with a downlaod link for a workshop manual for a Jetta 4 V5? I tried the link on the first page but didnt find anything.
:grin:
weza187
Car Model: MK1 Wolf
Post by weza187 »
Hi There,
Did you get the manual for the entire engine or just for a specific part?
vw citi wolf
Gummi
Post by Gummi »
Hi guys. Anybody that can help me with a workshop manual for the jetta 4 2.3 agz pls. Need the whole thing lol as i have cosmetic, electrical as well as some mechanical bits to do.
I would greatly appreciate it.
Thanx
