9n3 Polo GTi Stage 2
ashie
Car Model: 08 Polo GTi
Post by ashie »
Hey gents,
You guys are quite knowledgeable about these things.
Recently I have had STO do my downpipe and full exhaust with phase 2 software.
My car feels awesome and goes like a train on steroids. Only thing is I don't know how fast my car is compared to the next sports car. I've checked out many clips on youtube of stage 2 polos but many have added extras like 4bar frp, custom intakes and the like and they taking out Renault Megane F1 RS'.
Thing is, I would like to know what benefits these mods would have to my vehicle and are they costly to get...?
I don't do street racing but would like to have the peace of mind knowing my car has the power when needed.
Thanks in advance... :driving:
Tyler
Registered for: 16 years 6 months
Re: 9n3 Polo GTi Stage 2
Post by Tyler »
Hi, I don't know which company you got the software from but I did an FRC stage 2 software upgrade and I had to put a larger FMIC as well as a Forge TIP in order to stop pinging so I'd be careful about booting it in this hot weather! :wink:
I would say the TIP definitely helps the breathing at the top end and worth every cent, the FMIC is also a must and allows the software to be a little more lenient on the timing... especially if your map is aggressive...
Two other things to consider are replacing the one-way recirculating dump valve with a stronger one... that helps hold the boost and makes a difference with the smoothness and avoids boost spikes what can be a problem without a larger intercooler... and the other is the turbo actuator... as they get older the internal spring can't cope with the increased boost requirements from the software. I made myself a bracket and attached a shortened clutch spring from Midas which worked like a charm, very smooth power delivery... only problem is it's a MASSIVE BI%CH to try and get to...
With my stage 2 software and mods, DP, TIP, FMIC, DV and water-meth inj my 9nGTi was pushing 156kw atw and 344Nm and getting the hang of the wheelspin was doing decent 14sec ¼miles
Current: Hyundai i20 1.6 GLS
Ex: Polo 6R GTi
Ex: 2011 Subaru WRX 195kw
Ex: 2008 Polo 9n GTi
Ex: 2002 Opel Coupe Turbo
Ex: 1996 Opel Astra 200iE
Ex: 1994 Jetta 3 VR6
Ex: 1992 Jetta 2 CLi
Ex: 1992 Jetta 2 CLx
Ex: 1980 Fiat Elite 2000
ashie
Post by ashie »
Hi Tyler,
Thanks for the info. Sweet numbers you running there.
My car standard pushed out 119kw atf and 240nm. So with the mods the tuner (Amien from Evolution Performance, STO software) told me I should be getting +-140kw and +-300nm. He said that there are a few polos that he did with this setup and they all running fine. So I think the boost pressure is not that high to require an intercooler.
The car still has the same fuel economy from when standard so I hardly ever boot the car - PS get 590 - 600kms per tank.
I was contemplating on this motorcade setup, but I'm afraid of heatsoak:
http://motorcade.co.za/index.php?main_p ... cts_id=553
http://motorcade.co.za/index.php?main_p ... cts_id=358
Which TIP are you running and do you have the standard air box with OEM filter?
SemiColon
I sparkle in the sunlight
Car Make: Volvo
Car Model: S40 T5
Membership No: 1641
Post by SemiColon »
Hello,
Some Tuner's don't 'need' you to have 4Bar FPR.
I was almost at stage2, just needed a DP ...but i removed everything except the 4BAR FPR.
I'm Rather saving up for a FMIC because the heatsoak is getting pretty irritating at the moment.
Stock ----> Stage1 = Biggest performance improvement especially midrange Torque.
Stage1 --> Stage2 = Torque stays about the same with more top end Power/torque.
4Bar fpr = R300 used
Intake = R600 (Good Quality Cone Filter plus bend for inside Airbox)
DP = R2000 (Test's show that a DP doesn't yield a lot if any gain at top end, more low end torque)
TIP = R1500 (This apparently helps with an increased intake diameter to the turbo, also the OEM TIP sucks itself close when increasing the boost.
So you are looking at Over R4k to go from SW only to stage 2.
I'd Rather spend it on a bigger intercooler. ffs heatsoak is a biatch.
EDIT* a "stronger" DV is also needed...over R1k
八拾六
Stompie
Boostleak Guru
Registered for: 12 years 9 months
Car Model: 2006 120D
Membership No: 1843
Post by Stompie »
ya its weird how they can do stage two with only DP?
i had to get induction, TIP and DV before i could do Stage one, then had to get stage 1+ file and then stage 2 file and DP to be on stage 2.
all mods from stock cost:
1. Forge DV 007 - R1300
2. Forge TIP - R1600
3. induction - R500
4. Unitronic sw stage 1 - R3500
5. wild cat DP (on special) - R1900
6. Stage 1+ file upgrade - R500
7. Stage 2 file upgrade - R600
All in all +-R10000k
BMW 120D E87
Demon Tweaked
Registered for: 16 years 9 months
Car Make: VW & VW
Car Model: MK7R & MK6 GTI
Membership No: 1845
Post by Demon Tweaked »
PoloGTIman wrote:ya its weird how they can do stage two with only DP?
3. induction - R500
i think you a bit confused you dont need anything for Unitronic stage 1.
LB MK7R 359WHP 511NM
MK6 GTI DSG UNITRONIC Stage2
AUDI RS3
BMW E92 M3 350WHP @ Rally Cross Motors
UNITRONIC SEAT Ibiza Cupra 1.8 20vT Stage3 434WHP 509NM @ KAR
VW Citi Chico 1.4
jk
Registered for: 18 years 7 months
Post by jk »
im also thinking of REVO2
I have a forge tip, 63mm DP, and REVO1 the cars is still quite strong, I need a Forge DV to hold boost, my IC is holding up better, trying to maximise airflow, vents and if need be remove my right fog altogether.
Need the 4bar FPR for REVO2 and maybe the DV.
ashie
Post by ashie »
Ok, so from the information so far I need to get the following to maximize my current phase 2 software:
Aftermarket DV (is this dump valve or diverter valve?)
TIP which would run with a cone filter placed in airbox
Demon Tweaked
Car Make: VW & VW
Membership No: 1845
Forge 008 DV bro, Forge TIP as well.
AUDI RS3
VW Citi Chico 1.4
ashie
Post by ashie »
Shot Demon...
Will sort these mods then report back.
Thanks again guys
dees@pgti
Registered for: 12 years 4 months
Car Model: 12' Golf 6 GTI
Post by dees@pgti »
I have revo 1 and a few mods - cost so far
Revo 1 : ran 173HP/288NM@KAR with sw only
Just fitted:
Forge TIP
76mm Flowtech D (required for revo 2)
4bar fpr (required for revo 2)
next in line
Custom Induction
Revo 2 sw
then it's
Forge DV 007p
FMIC
and that will be it for me :driving:
'12 VW GOLF 6 GTI
'13 BMW 320i F30
'07 VW GOLF 5 TDI
'07 VW Polo Gti - Revo 2
'10 BMW 320i E90 Msport
'05 BMW 318i E46 Msport
'93 Golf CTi
'86 Mazda 323
jk
Post by jk »
dees@pgti wrote:I have revo 1 and a few mods - cost so far
Revo 1 : R2950 ran 173HP/288NM@KAR with sw only
Just fitted:
Forge TIP (R1650)
76mm Flowtech DP (R1500) (required for revo 2)
4bar fpr (R700) (required for revo 2)
next in line
Custom Induction
Revo 2 sw (R500)
then it's
Forge DV 007p
FMIC
How's your DV holding up?
Also any ideas on the intake? Not a fan of the burgy mod, I still have the PD160 setup with a K&N filter.
boost'd
Criminal Troll.
Registered for: 13 years 4 months
Post by boost'd »
I spent less so far on my bt setup....... Just saying
dees@pgti
Post by dees@pgti »
Just fitted:
Forge TIP
76mm Flowtech DP (required for revo 2)
next in line
Custom Induction
Revo 2 sw
then it's
Forge DV 007p
FMIC
The OEM DV seems to be fine - the forge DV holds boost better so would like to get one soon.
Also very undecided on the induction - i've read that the burgy mod does yield good results...how is the flat bed filter with the pd160....did you notice any difference?
'12 VW GOLF 6 GTI
'13 BMW 320i F30
'07 VW GOLF 5 TDI
'93 Golf CTi
'86 Mazda 323
mika1803
Registered for: 12 years 2 months
Car Model: 07 PGTI
Membership No: 3089
Post by mika1803 »
I only have stg 1 from revo, other mods in the pipe line, have not dyno'd yet, will chech at the dyno'd day next week.
, but car feels a lot stronger.
Any worthwhile fmic besides the Ibiza one.?
Got contact details for flowtech as every1 else quoted 2k for the dp.
Some people are wise, then some are just other-wise
08 Audi A4 2.0 tfsi S-line
Ex:07 Merc E63 AMG
Ex:11 6R PGTI
Ex:10 Silver Leaf Jetta 2.0 TSI-K04
Ex:12 Brilliant silver Jetta TSI comfortline, 9j 18 inch BBS wheels,custom intake, eibach
Ex: 07 Flash Red Polo Gti, stage 1 revo software, 63 mm downpipe, custom intake,G4 GTi.:R wheels,boost gauge
Ex: Alfa Romeo 156 2.5 v6 24v, intake, de-cat exhaust, GTA wheels
Ex: Tazz 130, Rsi wheels, some sound,
Florida, Woes Rand
Stompie
Boostleak Guru
Membership No: 1843
Post by Stompie »
3. induction - R500
sorry bro a bit confused you right, reason why im thinking this is because the day i did stage 1 file i also did TIP and then yosh told me that if i do induction it would run alot better. lol either way thats about what youl need to get to stage 2
BMW 120D E87
Demon Tweaked
Car Make: VW & VW
Membership No: 1845
boost'd wrote:I spent less so far on my bt setup....... Just saying
:lol: i know what you doing and i agree :grin:
AUDI RS3
VW Citi Chico 1.4
Demon Tweaked
Car Make: VW & VW
Membership No: 1845
Just fitted:
Forge TIP (R1650)
next in line
Custom Induction
Revo 2 sw (R500)
then it's
Forge DV 007p
FMIC
get the Forge 008 DV it "replaces" the Forge 007.
AUDI RS3
VW Citi Chico 1.4
dees@pgti
Post by dees@pgti »
ok cool...
Killerwatt
Car Model: S3
Post by Killerwatt »
Im in the process of agreeing... :evil:
Demon Tweaked
Car Make: VW & VW
Membership No: 1845
doooo it :evil:
AUDI RS3
VW Citi Chico 1.4
ashie
Post by ashie »
Alright so I got word from Ferroli on the following:
Quoted:
"They reckon it is the 008. They are both exactly the same except for the slight difference in the exterior. The prices are as follows:
Intake Pipe: R2050.00
Diverter Valve: R1700.00
Fitment: R275.02"
Looks like I'll have to be digging deeper into my pockets :crazy:
sonic-mike
Registered for: 6 years 1 month
Car Model: 9N3 PGTI 1.8T ..Vraaap!
Post by sonic-mike »
Guys who can you recommend does this for me.. im in limpopo 6 hour drive to jhb... and how long does it take to fit and tune all the bells and whistles.. these numbers are smaller than i ever imagined... with that said im a noob in mechanics i reckon my second hand 9n3 gti could be preformanced but i have no idea how to know or dammm stock 1.8's can fly... i have chowed golf 6 tdi 2 litre and m3 at local bush airport landing strip...
