my car swings but wont start
- Luke29610
- Car Model: MK3 Golf GTi
hi guys i need help:-) ive got a 96 golf 3 gti 2.0l 8v with gotech mfi management...few days back was driving around and the car just switched of at the stop street ..it kept on swinging but never started...ive replaced the coil,plug leads,management relay,checked fuses,new distributer cap and etc. and stil not starting plz help!
Re: my car swings but wont start
Have you tried changing the rotar? My golf did something similar when I had it. changed the rotar and it started on the first swing.
Hows your fuel pump?
92 CTi - EX
STO-Tuned Polo TDi 74kw - 122 bhp
CW Mk 5 GTi - Dp, Intake, Stealth Stage 2
194kw , 414Nm at Stealth HQ
- Colonel
- Membership No: 1041
are you getting spark, fuel etc
- Car Model: Amarok V6
- Membership No: 664
Like above... You are shooting in the dark by simply replacing stuff and spending money on stuff that you have no idea if they are broken or not.UDC wrote:are you getting spark, fuel etc
Make sure you get spark... make sure that the timing is correct and make sure that you are getting fuel. If those 3 are there the car should start.
Do you have a laptop ? can you connect it to the management and is it seeing the management and is the management seeing your inputs ?
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
BMW 335
Audi RSQ3
CURRENT CARS
VW Amarok V6 Exstream
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- Luke29610
hey guys...thanks for the reply i am getting spark and fuel...i never check the timing i will do that hopefully my friend know...yes i got a laptop ,i've got the software but do not know how to use it..but it does see the mangement and and etc
- Luke29610
how do set timing when car is not idling or starting???
- Rietbok
- Car Model: Vivo
Why would the timing suddenly go out for no reason? What makes you suspect that the timing is out?
- Rietbok
- Car Model: Vivo
Engines don't work with fairey dust... they work on science.
One or more of the things your engine needs to fire are missing.
- General
- Car Model: Golf GT
- Membership No: 1464
Set your timing marks to TDC and the rotor pointing to Cylinder 1, that will be close enough to get the car to start. Check the timing 1st before you undo anything.Luke29610 wrote:how do set timing when car is not idling or starting???
Current rides:
Hyundai - 1.4 Getz (daily)
Rietbok wrote:Why would the timing suddenly go out for no reason? What makes you suspect that the timing is out?
He was driving and all of a sudden it stopped and didn't whant to start again.. could be that the cambelt slipped a couple of teeth/ Timing out car won't start. It happens.
If there is fuel and there is spark then there is something wrong with the timing.. First have a look at the timing marks like Torker said then if that is correct you'll need to have a look at what the management is doing.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- Rietbok
- Car Model: Vivo
True, it could be timing, but wow something odd must be wrong for the timing to just change on it's own. Cam Belt stretched, worn badly, Dizzy not tightened.... But if everything is in working order your timing should not change on it's own.
- Luke29610
hey guys was checking the cam belt and etc...when i try starting the cams pulley is not turning...any ideas why?
- General
Loose crank pulley? Maybe the key sheared off on the crank nose? You have to pull of the covers to see whats happening on the pulley.Luke29610 wrote:hey guys was checking the cam belt and etc...when i try starting the cams pulley is not turning...any ideas why?
Current rides:
- Colonel
does the cam pulley have a cam belt on it?
- Luke29610
yes it does have a belt on it
- Colonel
then most likely what Torker says
Rietbok wrote:True, it could be timing, but wow something odd must be wrong for the timing to just change on it's own.
See
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
Take the cam covers off .. I agree it's most likly the key that is buggered.. There was a Jig floating around in the club to drill and insert dowels on the crank nose.
PS to get that crank nut loose is a b%$ch at times !
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- Rietbok
- Car Model: Vivo
lol... we were both right.joggiep wrote:Rietbok wrote:True, it could be timing, but wow something odd must be wrong for the timing to just change on it's own.Luke29610 wrote:hey guys was checking the cam belt and etc...when i try starting the cams pulley is not turning...any ideas why?
See
- Luke29610
hey guys thought i'll keep your updated...well my cam belt is filpn damaged its missing couple teeth n very greasy ...gonna change it today and se what happens...thanks again guys for the help!
With any luck you'll have no bent valves but don't bet your salary on it....
- Luke29610
ahh replaced cam belt and it....STARTED!!! MAX HAPPY just have to do timing abd etc
- Rietbok
- Car Model: Vivo
Great news!!! Well done!
- Luke29610
thanks Rietbok
