X-flow 8V head on ADY block
- Registered for: 15 years
I want to fit the newly accuired X-flow head to my block. Besides water pipes, what else needs changing? Do i use the same head gascet or must i ask for the X-flow one, or are they the same?
There is no oil or water journals that needs modifications for this???
I understand setting up cam timing remains the same as with the U-flow heads.
- Moderator
- Registered for: 19 years 6 months
- Car Model: MK7.5 GTD
- Membership No: 695
Re: X-flow 8V head on ADY block
Straight bolt on
Build your car for yourself, not what an internet forum tells you.
Current rides
2018 MK7.5 GTD
1992 Fox 2.0 20vt
http://www.vwclub.co.za/forum/viewtopic ... 11&t=60525
My Ex Rides
1981 1.3 Escort sold
1988 1.6 VW Fox sold
1995 Jetta 3 CLI sold
1997 Vr6 Hi-jacked
2000 2.0L MK4 Golf sold
2003 1.4 TDI Highline sold
2006 Polo 1.9 S/L sold
1994 CTI 8v Turbo retired
2010 1.6 TDI Sold
2011 Polo 6RGTISold
2013 MK7 2.0L TDI DSG Sold
Current rides
2018 MK7.5 GTD
1992 Fox 2.0 20vt
My Ex Rides
1997 Vr6 Hi-jacked
2010 1.6 TDI Sold
2011 Polo 6RGTISold
- Fran
- Registered for: 20 years 7 months
- Membership No: 1306
Is the exhaust manifold flange diffrent from the u-flow to x-flow?
2000 Vw Citi ABF 2.1 16v, tdi crank, 84mm pistons, Dicktator - 115.5kW & 202 Nm at the wheels
- Fran
No.Fran wrote:Is the exhaust manifold flange diffrent from the u-flow to x-flow?
now just for understanding purposes...
what gains does one get from changing from a U-flow to a X-flow and why?
My other ride is your Mom...
CURRENT - 2004 MK4 GTI .:R - Garret GT3071R with Tial Vband Turbine housing, Pagparts casted stainless steel vband manifold, 76mm exhaust vbanded, 350hp intercooler and 63mm piping all round, Tial MVS 38mm vband wastegate
EX: 2000 MK4 GTI - SAC Conversion
EX: 1992 CITI 1.3
EX: 1992 CITI 1.3
Contrary to popular myth mongers, fitting an 8V X-flow head will not magically make the motor produce plenty more power.
Yes, the X-flow 8V head does flow more air than the U-flow, but it is marginal, and not a huge amount like some people say.
Easier fitment of ITBs, turbos etc are possible with an X-flow head seeing as there will be much more space behind the head for a turbo and groceries than on a U-flow where the turbo and inlet manifold fight for space. Also with ITBs, they will be nowhere near the hot zorst mani on an X-flow head.
ahhhh.. so the x-flow is perfect for turbo applications but im assuming its prolly a beesh to get it to work out right?
EX: 1992 CITI 1.3
EX: 1992 CITI 1.3
you use the gasket form the non crossflow motor. It's not a straight boltover. You have to weld up one port on the front of the head and drill the front 2 head bolt holes bigger.
Now I remember that the head I got from rob_dbn had one oil drain welded up and the two outer head bolt holes were drilled bigger.panic-mechanic wrote:You have to weld up one port on the front of the head and drill the front 2 head bolt holes bigger.
Pic:
Sorry, edited that pic wrong.
The two front head bolt holes on the outside are bigger.
- graham savage
- Colonel
- Membership No: 803
Nope, works like a bomb and still keeps that 8v power band... like everything you do with your car, its application specificUmphufu wrote:ahhhh.. so the x-flow is perfect for turbo applications but im assuming its prolly a beesh to get it to work out right?
- Car Model: S3, Polo Playa,
Jetta2 wrote:Now I remember that the head I got from rob_dbn had one oil drain welded up and the two outer head bolt holes were drilled bigger.panic-mechanic wrote:You have to weld up one port on the front of the head and drill the front 2 head bolt holes bigger.
Pic:
wrong, not head bolts holes bigger but oil drain holes next to head bolts
And my post I made after that pic:vwpro wrote:Jetta2 wrote:Now I remember that the head I got from rob_dbn had one oil drain welded up and the two outer head bolt holes were drilled bigger.panic-mechanic wrote:You have to weld up one port on the front of the head and drill the front 2 head bolt holes bigger.
Pic:
Jetta2 wrote:Sorry, edited that pic wrong.
you still say head bolt holes, but your photo is correct
has to be the two holes next to the head bolts they are oil returns and not head bolt holes
Why do these need to be drilled bigger? And by how much?
- MarnoG
- Car Model: 2009 Citi Sport 1.4i
Sorry for the 'jack...
From which engine does the 8v xflow come? Are there different 8v x heads?
Marno
Stuff for sale:
- 2009 VW CitiSPORT 1.4i: http://www.vwclub.co.za/forum/viewtopic ... 9&t=198201
current: '09 VW CitiSPORT 1.4I
ex: '93 VW Citi Shuttle 1.3 (Golf VS. Truck)
Stuff for sale:
The x-flow heaad you want to use come off the mk4 1.6 and 2.l. There are others form the later range of polos but they are roller cam and cambox jobs which you don't get decent performance cams for currently.
- MarnoG
Thanks Mr. Panic!panic-mechanic wrote:The x-flow heaad you want to use come off the mk4 1.6 and 2.l. There are others form the later range of polos but they are roller cam and cambox jobs which you don't get decent performance cams for currently.
Marno
Stuff for sale:
Stuff for sale:
- Car Make: VeeDub
- Car Model: mk3 golf GS
hi guys,
i know this is an old post but i am doing the same swop ...
what would happen if you don't weld the oil port closed because i noticed that the port lines up with the block but slightly different
Linux -- Why look out windows, when you can run in the park ?
- moonwillow
- Car Model: 2L Caddy
What will happen if you don't weld up the oil port? sorry for the stupid question
Current rides.
1998 VW Caddy 2L 8v.
2015 Renault Clio
ex rides.
1998 Hyundai Elantra 1.8
2007 Mazda RX8 Hi-Speed
2007 Chev Lumina SS 6L V8
2010 Mazda BT50 3L 4x4
2010 Hyundai Elantra 1.6
1999 VW Chico 1.3 Carb
2005 VW Caddy 1.6
2007 Suzuki GSXR 750
2009 Citi ROX 1.4i
http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=159156
2015 Renault Clio
ex rides.
2005 VW Caddy 1.6
2009 Citi ROX 1.4i
- Moderator
The head is a straight bolt on to the ADY 2E AGG blocks no welding needed on the heads.
Only time the oild drain on the hed needs to be welded up is on the older block like the HV HM EV or KR blocks
You will need to use the MK4 2L head gasket witch allows for the larger oil drain port.
Current rides
2018 MK7.5 GTD
1992 Fox 2.0 20vt
My Ex Rides
1997 Vr6 Hi-jacked
2010 1.6 TDI Sold
2011 Polo 6RGTISold
Current rides
2018 MK7.5 GTD
1992 Fox 2.0 20vt
My Ex Rides
1997 Vr6 Hi-jacked
2010 1.6 TDI Sold
2011 Polo 6RGTISold
- moonwillow
Thank you duck.
Reason for my question was I will by swopping my u-flow to x-flow. Turbo setup will follow after that on my caddy.
Current rides.
2015 Renault Clio
ex rides.
2005 VW Caddy 1.6
2009 Citi ROX 1.4i
2015 Renault Clio
ex rides.
2005 VW Caddy 1.6
2009 Citi ROX 1.4i
- Registered for: 7 years
I see this is a very old post..i am doing the x-flow swop on my dx block,do i need to use the older dx headgasket after i weld up the oil drain hole?
- moonwillow
I used the 2e steel headgasket from goldwagen.
Current rides.
2015 Renault Clio
ex rides.
2005 VW Caddy 1.6
2009 Citi ROX 1.4i
2015 Renault Clio
ex rides.
2005 VW Caddy 1.6
2009 Citi ROX 1.4i
