difference between a DGG and FFZ gearbox?
- Car Model: Mk5 Jetta 1.6+vat
hey guys..my DGG box on my mk2 is bust..i settled for a FFZ box due to the scarcity of the DGG and the one i came across was in a mess..according to 3 mechanics they told me that the FFZ is an identical replica of the DGG just a newer version and that the ratios will be the same...but i've heard from other sources that they aren't because the FFZ has "much" shorter ratios...so what is the differences i'm going to experience?i'm running this box with my ABF motor..has anyone ran this FFZ with an ABF on a mk2?
thanks
thanks
no turbo no gas jus OLDSKOOL kickin ass...
- Car Model: Cti
- Membership No: 2095
Re: difference between a DGG and FFZ gearbox?
I think most of the guys have ffz with their abf's.
The dgg does have longer ratios iirc. That 2nd & 3rd gear is awesome. Lol.
Personally prefer the dgg over the ffz as I saw the difference in my cti with both these boxes. Oh theres also a difference with the cv cups I think on the ffz. You will have to change it as its smaller iirc. Let some of the experts respond.
- Citi1.4i
- Car Model: Tdi
DGG & FFZ Gear Ratios
1st = 3.455
2nd = 1.944
3rd = 1.370
4th = 1.032
5th = 0.850
R&P = 3.941
I believe the FFZ ratios are too short for anything above a 1600 and I use an FF on my 2l, that said ... the FFZ ratio set does seem to be the ratio set of choice on this board for whatever reason(s)
FF Gear Ratios
1st = 3.455
2nd = 1.944
3rd = 1.286
4th = 0.909
5th = 0.712
R&P = 3.894
Possibly a better compromise would be the ACD, (or AUG? which shares the same ratios bar 2nd gear)
ACD Gear Ratios
1st = 3.455
2nd = 2.118 (AUG = 1.944)
3rd = 1.444
4th = 1.129
5th = 0.894
R&P = 3.667
Download this spreadsheet and play around with the ratios http://www.mediafire.com/file/6oxiaug90 ... ulator.xls
1st = 3.455
2nd = 1.944
3rd = 1.370
4th = 1.032
5th = 0.850
R&P = 3.941
FF Gear Ratios
1st = 3.455
2nd = 1.944
3rd = 1.286
4th = 0.909
5th = 0.712
R&P = 3.894
ACD Gear Ratios
1st = 3.455
3rd = 1.444
4th = 1.129
5th = 0.894
R&P = 3.667
- mojo786
- Car Make: Vw+SEAT
- Car Model: VeLo+Cupra
interesting...anyone with a aug/acd box on 2.0 8v?
i would like to know what 1/4times they got with this box.
Velo-ABF-ride-thread
2.0 16v ABF - MP9/ Per4mance Custom Tuned-(0837860345)
57mm F/F
Custom ratio Bolted diff Gearbox
CrossDrilled VR6 stoppers!
JOM coilovers
A.R.B
Webasto tilt n slide sunroof
.:R -Line boot spoiler
07 SEAT IBiza CUPRA TDi
Allard EGR delete
BMC flatbed filter
dp/FullZorst
Sw
Mopower.abf@gmail.com
- Car Model: '84 Mk1 2.0 20v ITB's
- Membership No: 3004
The CTI comes with an AUG box that's the one you reffering to which has larger cv cups, the DGG comes out of the Polo's.Tashveer wrote:I think most of the guys have ffz with their abf's.
Sup
FFZ is the later/newer version of the DGG box. They have identical ratios. I used to work at VWSA as senior tech advisor to the dealer network in Sub Saharan Africa. Use or don't use my advice/info, its ur choice.
Note also that the FF box referred to above is not the same as FFZ. They are out of the old mk1's. They have 3.89 diff.
FFZ have 11mm diff rivets as opposed to 9mm on DGG and older.
- Car Model: Cti
Thought i would share some experiences i had with my FFZ box... All good and lasted thus far without any issues. 2'nd gear syncro slowley starting to give way, gonna try some new g-box oil and see if that will make a difference.
Speeds i got per gear in my mk1 at 7000rpm on ffz gearbox: 1st, not to sure about 45, 2nd 110, 3rd 160, 4th 190, 5th not tested. This is obviousley not true gps speed, baring in mind the tyres used were 175/60R13 semi's.
@ 6000rpm speeds were as follows: 1st 40, 2nd 80, 3rd 120, 4th 160, 5th 205.
Stock standard FFZ box and diff. Used 210mm clutch kit.
For my motor 1st and 2nd gear are perfect, i would however like to get a shorter 3rd and 4th ratio.
- mojo786
- Car Make: Vw+SEAT
Lemme see if I understand this right,the 1st speeds u got because you had 13 inch semi's and revd up to 7000rpm per gearWit Ark wrote:Thought i would share some experiences i had with my FFZ box... All good and lasted thus far without any issues. 2'nd gear syncro slowley starting to give way, gonna try some new g-box oil and see if that will make a difference.
Nice speeds even for speedo readn
But howcum the big difference in speed in second run,I mean our motors make power within 6000rpm range so shouldn't be such a big drop unless you slapped on sum 18" pot lids.
I got a dgg on my velo from factory and get 140-145 on 3rd jus for the record.
57mm F/F
JOM coilovers
A.R.B
Allard EGR delete
BMC flatbed filter
dp/FullZorst
Sw
The speeds obtained at the 6000rpm mark were with the stock blik rims and tyres, think they are something like 155/80R13. sorry forgot to mention that.
- Car Model: S3, Polo Playa,
Citi1.4i wrote:DGG & FFZ Gear Ratios
1st = 3.455
2nd = 1.944
3rd = 1.370
4th = 1.032
5th = 0.850
R&P = 3.941
FF Gear Ratios
1st = 3.455
2nd = 1.944
3rd = 1.286
4th = 0.909
5th = 0.712
R&P = 3.894
ACD Gear Ratios
1st = 3.455
3rd = 1.444
4th = 0.909
5th = 0.894
R&P = 3.667
FN, FF, FH (most to 7/80) 3.89 3.45 1.94 1.29 0.97 0.76
FN, FF, FH, FJ (most from '81) 3.89 3.45 1.94 1.29 0.91 0.71
AUG (1.8 8v 90's G/J) 3.67 3.45 1.94 1.44 1.13 0.89
4Y, 9A, ACD, AEN (8v Close Ratio) 3.67 3.45 2.12 1.44 1.13 0.89
- Car Model: MK5 GTI DSG BWA
- Membership No: 1156
also the oil capacity on the FFZ was more than the DGG by a litre iirc
2012 Dec Mk6 GTI CW DSG - REVO Stage 1
Ex 2008 White Golf 5 Gti DSG REVO3 K04 - Weekend Toy
Regards
Hoosen
072 135 7861
Regards
Hoosen
072 135 7861
- mojo786
- Car Make: Vw+SEAT
So what's the best for the following N/A engines -
1.8 8v(short block)-
2.0 8v(2e-ady-agg) -
1.8 16v(short block)-
1.8 20v(non turbo)-
2.0 16v (9a-ABF)-
1.8 20v(non turbo)-
2.0 16v (9a-ABF)-
57mm F/F
JOM coilovers
A.R.B
Allard EGR delete
BMC flatbed filter
dp/FullZorst
Sw
- Car Model: Cti
Didn't all the velos come with ffz?mojo786 wrote:I got a dgg on my velo from factory and get 140-145 on 3rd jus for the record.
- mojo786
- Car Make: Vw+SEAT
My one started making big noise at 12000kms so vw changed it,only when I did motor swap I realised its a DGG but when it was 1.4 I used to be one up on other 1.4's.lolTashveer wrote:Didn't all the velos come with ffz?mojo786 wrote:I got a dgg on my velo from factory and get 140-145 on 3rd jus for the record.
57mm F/F
JOM coilovers
A.R.B
Allard EGR delete
BMC flatbed filter
dp/FullZorst
Sw
mojo786 wrote:So what's the best for the following N/A engines -
1.8 20v(non turbo)-
2.0 16v (9a-ABF)-
90 mm flange
Code (Application)
ACN (07/84-09/86 GOLF)
(08/84-07/85 JETTA)
ACH (07/84-09/86 GOLF)
(08/84-07/85 JETTA)
AGS (08/86-07/87 GOLF)
(08/86-07/87 GOLF)
AOP (08/88-07/89 GOLF)
(10/87-07/88 JETTA)
AEN (11/87-07/88 JETTA)
ASF (09/87-05/88 GOLF)
(09/87-05/88 JETTA)
4S (08/87-08/88 JETTA)
AWY (08/89-07/91 GOLF)
(08/89-07/90 JETTA)
AVX (01/91-07/92 JETTA)
100 mm flange
Code (Application)
9A (08/84-07/85 GOLF)
(01/85-07/85 JETTA)
(07/84-07/84 RABBIT)
(07/84-07/84 SCIROCCO)
2Y (09/87-05/88 GOLF)
(10/87-05/88 JETTA)
(07/87-07/88 SCIROCCO)
ACD (09/87-05/88 GOLF)
(10/87-10/87 JETTA)
AGB (09/87-09/87 GOLF)
(02/87-07/87 JETTA)
(02/86-07/89 SCIROCCO)
ACL (08/87-09/87 JETTA)
AON (09/87-10/87 GOLF)
(09/87-05/88 JETTA)
AUG (08/89-07/90 GOLF)
(08/89-07/90 JETTA)
- araf69
- Car Model: 2008 MK5 GTi DSG
- Membership No: 1739
Had a FF gbox In my mk1 with HV motor, I liked the combo. Paid next to nothing for it. Was in my GT. Also gave my bud hell with his mk2 gti
my rides thread : https://www.vwclub.co.za/forum/viewtopi ... 1&t=138629
2008 mk5 gti - Stealth Tuned
Ex 2005 velociti 1.6i
Ex 92 nissan 200sx 133 hp atw
Ex 85 mk1 ABF on ats cups - 122kw 198nm atw
Ex 04 2.0i ADY citi on BBS - 15.8s 1/4mile
Ex 00 Citi 1.6i 272cam TDi wheels
Ex 02 mk4 gti 19s RS6 wheels
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Ex 92 uno turbo - 116 kW 222nm atw
Ex 95 uno turbo
Ex 84 mk1 2 door GT
- araf69
Ex 95 uno turbo
Ex 84 mk1 2 door GT
Ex 95 uno turbo
Ex 84 mk1 2 door GT
- boosted 16v
- Car Model: 16v Turbo
i had the 2y 1800 16v box on my abf...it has long gear ratio
good combination..i did try an ffz box the gears wear to short i think.. although it revs faster with the ffz
- Citi1.4i
- Car Model: Tdi
Thought you may find the graph below of interest;
The 2Y has the same ratios as an ACD, bar 5th which is shorter (0.912 vs. 0.894)
The ACD has the same ratios as an AUG, bar 2nd which is shorter (2.118 vs. 1.944)
The DGG and FFZ share the same ratios!
(The assumption for the graph below is 195/50/15 wheels/tyres)
We just fitted ffz 5speed box into vw golf mk1.
Lastnite while I test the car on my way home and find out that the car doesn't pull as a golf mk1 1'4 is supposed to. And somewhere is a strange kling noise while im driving, don't know what is.
Also seems that im driving on clutch and it's stif.
Start a new thread then we help you. Capish?!Morn89 wrote:Hi guys
The velo originally was developed as soon as they stopped manufacturing the life in 2005 I think... so your first velo that came out was exactly the same as the life only difference was that the life was a much faster 1.6i and to date it still is.. that is normally aspirated...
I have a 1.4i FFz gear box , I also have a 1.6i DDG gear box , I want to take out the 4th and 5th and move it to the FFz gear box will it work ?
- chucker02
- Car Model: Citi ADY
The ratios are the same so you will gain nothing, unless the gears are worn and you want to fix the ffz.
1971 VW beetle
1971 VW beetle
