Help needed: Citigolf cuts off while driving
- Car Make: Scooby
Hi Guys,
need urgent help on this.. once again
recently (after the heavy rains in kzn & jhb ) my citi 1.4i while driving switches off,
after a little while it starts again, drove up to jhb fine & then started its nonsense
but noticed the sound below the petrol tank was no londer there so i assumed
it was the fuel pump luckily i had someone check it out & it was the fuel pump relay that packed up, got it replaced, (part from VW) & worked fine...
in addition to all of this, i have checked the coil, plug leads, distributor etc & seems to be ok
now the problem is... while driving & nearing a robot or stop street when i slow down & drop gear to 2nd with my foot down on the clutch & leg off the accelerator it switches off with only the battery light on... try starting & it starts on the turn...
what could be the problem with my car??
can i hook the car up on the computer & will it pick up any faults rather than checking everything again?
who can help with this?
appreciate the feedback as it is rather annoying while driving & not know when it will switch off
- boosted 16v
- Car Model: 16v Turbo
Re: Help needed: Citigolf cuts off while driving
i had the exact same problem it was the coil...
every time it gets hot the car will cut of ...
- Ripdbod
- Car Model: citi golf
- Membership No: 1655
Just a suggestion,
if you slowing down means you on the brakes.
I had the same problem, everytime i went on the brake the car would switch off.
Found out there was water on the tail lights.
Drained the water out and sealed the unit properly, no prblems thereafter.
Current :
1998 Citi golf
2.0l 8v
282 estas, 50mm exhaust
93hp - panic's dyno
Hers : 2012 Polo 1.6 comfortline
1998 Citi golf
2.0l 8v
93hp - panic's dyno
- Car Make: Scooby
@ boosted, i will have to check the coil as soon as it does this again
@ Ripdbod, i do press the brake when slowing down but i dont think thats the problem
cos the rev drops below normal mark & goes back to normal but sometimes drops which then switches off
- vr6zn
- Car Model: 1998 MK3 VR6 Golf
Try realigning the throttle body.
Six is always better then four!
1998 Golf VR6 (Durban Stock)
2001 Polo Playa 1.4i
1994 Jetta VR6
1992 1.3 Citi Golf
1994 Jetta VR6
1992 1.3 Citi Golf
- Car Make: Scooby
& how do i go about doing that?vr6zn wrote:Try realigning the throttle body.
- Car Model: 1988 Jetta mk2 cli
Yeah next time it cuts out get out and feel your coil if its seriously hot then that could be your problem!
As far as re aligning your throttle body you have to use vag.com if I'm not mistaken. I know there is a procedure that you can do which involves unplugging the ECU and what not but I forget what the procedure is. But that's if you can't get on to a vagcom!
- Tdi jetta 4 ever
Maybe it's caused by a airlock in the fuel system or your brake booster is leaking or coil.
Robin
robinwisse@gmail.com
- Car Make: Scooby
Happened again this morning
checked the coil & its cold
guess i will have to send the car in to VW
or can you guys recomend me to someone who can have a look?
i'm quite sure VW midrand will waste my time
- MikeD
- Registered for: 18 years 2 months
I dont know much about a citi.com but could it not be the TCI unit that is packing up?Citi.Cum wrote:Happened again this morning
Is the TCI unit part of the coil on these cars?
Current Car
05 Polo 1.9 TDI Sportline
96 CTI Golf - Upgraded to EFI , 272 Cam, 60mm Drop, Brospeed Branch, s/s f/f, brake upgrade
90 BMW 318i
90 BMW 318i
- Car Make: Scooby
Not sure what's a TCI unit of where its situated
- Registered for: 21 years 5 months
If you still have the faulty relay, open it up and check if it's rusty inside.
If the relay is contaminated I can bet you that either your windscreen or rain tray is leaking on the drivers side.
Cheers,
Jean
Cheers,
Jean
Jean
Land Rover Defender 90 2.8
2.8 BMW M52
165KW 380MN
325i Intake
Custom Exhaust by Powerflow, Thanks Roddy
- Car Make: Scooby
i did open the faulty relay & yes you are right, it was rusty on the insideBandit wrote:If you still have the faulty relay, open it up and check if it's rusty inside.
Cheers,
Jean
i replaced it & covered the whole unit
Hi, i am having the exact problem with my golfy 1.4i. I see the rev going below 1 when applying brakes together with clutch and sometimes it switches off. I noticed it starts doing this once its warm. When cold it drives well. Please advise how did you get yours fixed because some machanics want to strip my engine something i dnt want. Infact they want me to be convinced its a big problem so that they charge me much
Hi guys I'm having the same problem with my 1.4i. I have tried numerous things. TB is shinny clean,tried another MAF sensor,replaced vacuum valve, tried another purge valve same problem, there is no blockages from the air box to the intake,air is flowing perfectly. Car timming is set to the T even tried another fuel rail but never helped The one thing that does stop this from happening is removing the small vacuum pipe coming from the vacuum valve to the small nipple thing at the end of the fuel rail. Been driving the car with the pipe off for a week n it doesn't cut off. Have spoken to may guy n everyone is baffled with this. What could be the issue???
By undoing the pipe you are allowing air past the throttle body which helps it idle.
This same question gets asked and answered a 100 times a week. It's the most common issue on mp9 and basically what it comes down to is that the motor that does the idle is busy failing. Generally means new throttle body.
- DannyM
- Car Model: 2005 Citi 1.4 Carb
Hey guys,
I'm having the same problem on my golf too now, except mine is an 05 Chico 1.4 carb and not an EFI model. I noticed the problem a few days ago and had to replace my fuel lines from the main outlet and return from the tank to the motor after i got stuck at a robot (output from the tank was torn open). I had water in my tail lights too so i drained them as well (after reading this post when the problem started). The coil, spark leads, plugs as well as the carburetor are all new (replaced them around 4 months back). The motor dies in 2nd or 3rd gear (so far) when I apply brakes with clutch in or even if i put it into neutral and apply brakes while coasting as well as at startup in neutral it will swing and then drop to around 300rpm and cut out.
What could the issues still be and what can I do to solve it?
Thanx in advance
Thanx in advance
Daily & Project '05 VW Citi Chico 1.4 Carb
Race car / Modded car life cycle: 1. "Sweet! new parts." 2. "It's running. Wanna race?" 3. "What's that sound?" 4. "F**king s**t thing is broken again..!"
This is how a water damaged relay looks like.Bandit wrote:If you still have the faulty relay, open it up and check if it's rusty inside.
Cheers,
Jean
Hi everyone. I am currently driving a 1990 Fox 1.8. Recently I encountered an issue where as I slow down and put my foot on the clutch the engine cuts out. The battery light and oil light both flash. Battery is in good condition and there is sufficient oil. When I turn car on it cuts out immediately unless I keep car revving. I drive in heavy traffic daily and this problem is worrying. Could it be a fuel pump issue? If so where is it located?
Any help would be appreciated.
Many thanks
Gavin
Many thanks
Gavin
Hi guys I'm having the same problem with my 1.4i. I have tried numerous things. The one thing that does stop this from happening is removing the small vacuum pipe coming from the vacuum valve to the small nipple thing at the end of the fuel rail. Been driving the car with the pipe off for a week n it doesn't cut off. Have spoken to may guy n everyone is baffled with this. What could be the issue???
Possibly diapraghm failure on the fuel pressure regulator. so it pisses raw fuel into the intake. alternatively could be a breaking fuel rail.
- Car Make: SEAT
Fuel pump should be underneath your RR door, just before your rear wheel arch.Gavin H wrote: ↑Wed Mar 14, 2018 10:37 am Hi everyone. I am currently driving a 1990 Fox 1.8. Recently I encountered an issue where as I slow down and put my foot on the clutch the engine cuts out. The battery light and oil light both flash. Battery is in good condition and there is sufficient oil. When I turn car on it cuts out immediately unless I keep car revving. I drive in heavy traffic daily and this problem is worrying. Could it be a fuel pump issue? If so where is it located?
Many thanks
Gavin
Hi my citi golf 1997 model cuts of when im driving, i did change my coil n plugs but stil does it an everytime it switch of i have to suck petrol out from the tank then its start again i did check my feul pump there is no blockings filter is good, the other thing is my engine is getting really hot when im driving
