Belix's Jetta 2
Adamantium
Registered for: 16 years
Jetta 2 - the bad & downright ugly - b**ch won't start!
Post by Adamantium »
Why did you buy thees cah?lol give the wife the G6 this car seems problematic I wouldn't let her drive it.
Sent from my turbocharged iPhone
http://www.adamantiumcg.co.za
ADAMANTIUM GUARD-commercial/residential services PSIRA 1966419
07 Mini Cooper S
06 Corsa utility
11 CW Bigboy Sportflite F35
EX
06 CW Golf V GTICW G5 GTI
05 1.6 Ford Fiesta
97 1.3 Opel Corsa
Belix
Registered for: 14 years
Car Model: Passat B8
Re: Jetta 2 - the bad & downright ugly - b**ch won't start!
Post by Belix »
Yeah, but then I'd be driving this all the time, and I do way more driving!
well good news is that was only loose cable on the starter, so go it started, but what a pain in the ass location! compared to the 'normal' position on the manual right there in front :bang: hope I don't have to change that any time soon!
Anyhow, went out to ace spares to see about getting a bit for the central locking that was missing, but irritatingly, someone had bought the whole door of the car I saw early last month, so no luck :bang:
Anyhow, they had knock off door locks for R80 each that looked pretty good. Unfortunatley for me, I only tried one lock, not both, and one seems to have a manufacturing defect which is rather odd. Only figured it out after about an hour of trying to get the door to lock unsuccessfully!
if you see below, old lock pin has J shaped profile (note it goes in just under the '25'
but new lock has a extension on the locking ping going outward, which actually stops the lock locking. Weird!! The right hand side lock did not have the extension and worked fine.
another long trip out to ace spares to swap them :mad:
Another issue is the the left front door handle does not seem to push the lock up far enough to actualy open it. On closer inpsection I see the handle is non-oem, so I suspect it's another bad example, which is not working as well as OEM. Either that, or the door itself is bent such that the handle is angled slighty upward.
Will get an OME door handle and hope for the best.
Was trying to get the rubber 'boot' that goes between the handle and the door, bu VW only has stock of the fron one, back has 287 on backorder...given that it seems to be the same part for the citi, that seems pretty odd.
Belix
Jetta 2 - the bad & downright ugly - CLONK from the back axe
Post by Belix »
Hey folks
When I reversed the car yesterday and put on the brakes, something from the back right of the car went CLONK! On the drive thereafter, I got a small clonk - one clonk for each rotation of the wheel. Since the only thing that turns on the rear axle is the drum brakes, I'm guessing it's something to do with that.
Given that the hub nut needs a large 265nm to tighten, and I don't have that large a torque wrench, I'm a bit hesitant to start poking about.
Any idea what might cause a 'clonk' for each rotation?
Re: Jetta 2 - the bad & downright ugly- CLONK from the back
That torque is the FRONT hub nut NOT the rear. You will have a totally broken off stub axle if you try that at the rear.
Belix
Post by Belix »
good to know! :eek:
any idea what the torque for the back would be?
Car Make: VW, VW, Aprilia
Post by Jetta2 »
The rear nut for the bearing hasn't got a specific torque setting.
You most likely tightened the nut too tight and damaged the bearing.
Replace bearings and do the following to tighten the nut up -
Tighten nut by hand.
Take a flat screwdriver and fit the blade between the washer and the disc/drum.
Tighten with spanner while rotating the wheel until you can just move the washer from side to side using the screwdriver.
Not too tight, the washer must be able to move with a bit of pressure.
Pop the castellated nut thingy back on abd fit a split pin in hte holes and bend the legs over.
Belix
Post by Belix »
Thanks folks!
don't worry, have not even taken the nut off yet - wanted to see what I was getting into with the back drums before taking them apart. Given that I've not overtightened the nut, would a 'clang' with each turn of the wheel be liekly to be caused by bearing? I'm familiar with a bearing making a whining sound, but a clang per rotations is a new one on me. Given that it only started when braking on reversing, I reconed brakes would be a liekly suspect.
Scatman
Car Model: 320d Msport
Membership No: 1773
Post by Scatman »
Hey man!
I'd check if all the wheelnuts are the same length. If they are, then I'd take off the drum and check for anything like the handbrake cable not being hooked in or anything that looks like its bent, or has been taking a knock.
@Ryan, thanks for the advice on the rear wheel bearing, I always wondered how you know when its tight enough!
@Belix, keep us updated as to what the problem is/was!
2008 BMW 320d Msport Auto
2006 Audi A3 2.0T
2006 BMW E90 330d Manual
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
Belix
Post by Belix »
Scatman wrote: I'd check if all the wheelnuts are the same length
Thanks you senior! That was it, I remembered TWT put in one lug bolt when I had the tyres changed. No idea why it only played up a couple days later, but checked the bolts, three were oily on the bottom, one all shiny - the longest one. Swapped it to the front and sorted!!
Belix
Re: Jetta 2 - the bad & downright ugly- onto other issues...
Post by Belix »
next to be done
* replace power steering bottle and fluid
* figure out why I got no low beams. I guess the stalks are faulty. (How easy is it to swap it with a new citi set on stalks?)
* try get fan working
* try get dash into repsentable condition
* paint up rusting battery area
* replace heater core - where can I get a replacement?
Scatman
Membership No: 1773
Post by Scatman »
Haha, this should be documented, this is one of those rare times I'm actually right :-D
Glad its sorted man, whats next on the cards for the Jet? And did you get the door handles to work right?
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
Belix
Post by Belix »
the one pirate door handle on the left front does not seem to push the lock lever up high enough, so the door will not open. So wondering if I should try an OEM door handle at R1280 odd, or try a whole bunch of different non-oem ones at R85 odd each.
heineken
Registered for: 13 years 6 months
Car Model: MKII Jetta CSL
Membership No: 2009
Post by heineken »
Are you gonna take the pull type or the polo lift handles from autostyle ?
Belix
Post by Belix »
for the price of an OEM one, may as well give it a try! Will see if GW has them as autostyle is a bit of a drive.
Belix
Post by Belix »
got around to replacing the front passenger door handle. It was a lot better but still did not seem to lever down enough so I figured the door must be bent a bit. After a yank with an iron bar in the handle opening, the door opens now!
I decided to change to locks rather than have two different keys, and this is what greated me when I took the old lock out.
So! No pins whatsoever :crazy: :crazy:
Anything could open that lock!
Anyway, managed to configure five of the six the pins in the new lock to work with the current key
I recall that you can use a self taping screw to fix this issue, but was not sure where the screw would go...I assume at the end of the lever?
Also changed the power steering fluid and bottle.
Old bottle definately past it's prime!
Old fluid is this colour, while new fluid is clear!
Apparently i have a leak somewhere as this was the rear passenger compartment after the weekend rains.... :bang: :bang: :bang:
Belix
Re: Jetta 2 - the bad & downright ugly- temp sender unit?
Post by Belix »
does the temperature gauge get info from two sender units?
The temp needle seems to show the right temperature, but the light is always blinking now.
Also, rad fan is ALWAYS running. Where is this controlled from, as I assume the switch must be faulty.
OEM+
Registered for: 14 years 4 months
Car Model: MK2 GTi
Post by OEM+ »
Radiator fan is controlled by the switch on the side of the radiator. Check that the 2 pins aren't touching each other that would cause it to bridge the switch and run all the time.
I think the water temp light is controlled by the sensor on the coolant bottle??
1991 MkII GTI 16V http://www.vwclub.co.za/phpbb3/viewtopi ... 11&t=95318
2015 Land Rover Discovery 4
2014 PW Golf Highline DSG TDi Xenon&LED pack, Pano Roof, Nav, RearView Assist, Park Assist, Climate Control
2016 Audi RS3
2020 Tiguan Highline TSI
2013 Land Rover Defender 90
OEM+
Car Model: MK2 GTi
Post by OEM+ »
Belix wrote:next to be done
GW has them.
2016 Audi RS3
Belix
Post by Belix »
thanks and thanks!
Will check out both
Belix
Re: Jetta 2 - the bad & downright ugly- head blown?
Post by Belix »
Engine is overheating. After filling with water, and a 15 minute drive, temp gauge light comes on. When you check the water with engine running after cooling down, there is a lot of pressure, bubbles etc (not steam). Water is a very rusty brown colour. Have checked oil and it does not seem to be mayonaise-ish, but does it seem liekly the head is blown letting gases into the water system?
This car was a real lemon. Since purchase, interior fans and aircon have died, overheating has started, rain leaks, dash lights died...
sigh!
vr6zn
Registered for: 13 years 10 months
Car Model: 1998 MK3 VR6 Golf
Post by vr6zn »
check the thermostat and fuse for the interior fan and aircon.
Six is always better then four!
1998 Golf VR6 (Durban Stock)
2001 Polo Playa 1.4i
1994 Jetta VR6
1992 1.3 Citi Golf
Belix
Post by Belix »
yeah, will do.
Sadly, seems I was right. lots of mayonnaise looking crud when tappet cover off.
Sigh...
No time to attempt a head gasket replacement myself at the moment. Gonna have to take the thing in to a mechanic...
Wonder if the temp gauge is working rpoperly, becasue although the light came on, it never moved into the red.
Belix
Post by Belix »
Power steering pump seems to have gone now, perhaps it was so amaized atnew fluid.
and worse news
Head has been skimmed to much already - so need a new head.
Anyone know what heads the 1.8 block accepts?
Re: Jetta 2 - the bad & downright ugly- Need new head!!
Basically any of the 8v heads from about '85 onwards will fit.
Belix
Post by Belix »
Thanks panic
Wonder where the worse place in JHB is to leave your car overnight.... :crazy:
