B20 conversion on a 1.4 velo
Mk1Crazee
Registered for: 6 years 8 months
Car Model: 1980 Mk1 4 Door 2L8V
Re: B20 conversion on a 1.4 velo
Post by Mk1Crazee »
Those B20's are cheap though but the labour and added extras to make it work will ultimately become pricey. will be interesting to see though.
I've seen this conversion done in a '81 Mazda 323
1989 VW Fox 1800 (Sold)
1985 Ford XR3 1600Sport (Restoration Sold)
2004 Mk1 Golf 1.4i Velo Motor (Sold)
1980 Mk1 Old School Golf 2L8V
Shallow Pockets. Backyard Builder :moon:
Rourke
Registered for: 11 years 4 months
Post by Rourke »
ALRoN73 wrote:
Rourke wrote:its not a vw but i wonder
Those B20B Motors are pretty cheap R5900.00 R6000.00 and funny hey has 1 and a half to 2 years ago it was 3500.00 for this motor.i found 1 at a pawn shop for R2000.
I think if a mount can be maid up with a adapter plate for the vw gearbox with aftermarket management then maybe it could work .
It is assuming that u can mount a vw box to a honda engine.
people mound toyotas in microbuses carrevelles.(Adapterplate) Well im not clued up on what all goes into this but if it can work why not
also a ffz box runs out of steam so will it handle the honda seeing as a honda revs more too.
if the box and management and mount is sorted then the rest is basically as if you anyway giving attention to the motor . New exhaust people anyway do this for breathing and sound and performance. water pipes ect its anyway a good idea then you know you have new parts in anyway.
what do you guys think
B series motor spins other way around so ffz box will give you 5 reverse gears and 1 forward :lol:
on that note what makes a engine spin in the direction it does ?
if i think about it is it not the starter and the position of the starter?
if u using the vw box with vw starter then i dont see the problem.
If i think about it it will then just be the firing order that might need to be reset in the direction the motor spins.
Oh shuchs but what about the oil pump? will it work in anydirection? and water pump too?
Hey im a noob and my thinking is on a basic level not professional level but does it work this way?
cheers
ob wan
Registered for: 15 years 4 months
Car Model: MK1 2.0 16vT
Post by ob wan »
B20's can't rev, polystyrene block from factory....
i had a itb B20vtec in my ballade, past 7k the sleeves cracked if you had no brace in it... and to make it last will cost you one kidney, one leg and half an arm...
since i went vw 9a turbo, no looking back
05 G5 Gti (ex)
97 LSvtec (ex)
05 Ford Ranger 4.0 V6
Mk1 velo 2.0 16v...Turbo
ALRoN73
Post by ALRoN73 »
ob wan wrote:B20's can't rev, polystyrene block from factory....
You stand and rev the car all day or what?
ob wan
Post by ob wan »
pfff, do you?
05 G5 Gti (ex)
97 LSvtec (ex)
ALRoN73
Post by ALRoN73 »
pfff, do you?
No thanks
ob wan
Post by ob wan »
specs on my block were:
eagle rods
wiseco 10.5:1
arp headstuds
typeR cams
vernier pulleys
42mm 4-2-1 header
63mm exhaust
dual intake and exhaust valve springs
toyota 43mm itb's
did 120wkw.... on a good day
only problem was the block... the b18 block was super strong coz the sleeves weren't siamesed....
b20 has super thin sleeves and the sleeves actually move under load and revs
but putting a jdm in a german is sacriledge....
sies!!!!!
05 G5 Gti (ex)
97 LSvtec (ex)
ob wan
Post by ob wan »
anyways, if anyone wants to do the conversion i'd be more than happy to quote.... hehehehehehe
05 G5 Gti (ex)
97 LSvtec (ex)
Hazaree7
Car Model: Velociti 1.6i & Polo 1.9TDI
Post by Hazaree7 »
Vtec in a mini
https://youtu.be/fEqOfUxzXio
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner »
Anonymous wrote:Hey guys, I want to drop a b20b motor in a golf mk1... Can it be done... Can somebody please tell me what needs to be done and what I need to change...
Please Whatsapp me on 0617592339 - abdul
Thanks,
Easy
Buy a honda, slap VW badge on it. Done.
Jokes aside
You basically need a whole B20 powered Honda and a rolling Citi shell. Cut and weld the shell to suit the Honda motor, gearbox and suspension. Transfer the wiring and merge the two harnesses. When the motor starts you are about halfway done.
Basic requirements for the build:
1. Above average professional level mechanic skills
2. Welding with MIG and TIG fabrication skills
3. A fully kitted fabrication workshop
4. A heap of cheatahs (Rand's preferably $)
5. Time in abundance.
missioner
Post by missioner »
Hazaree7 wrote:Vtec in a mini
Can't use MCM as an example.
1st it's a done conversion as somebody already makes a subframe to suit both the motor and body.
2nd those boys had top notch specialists helping them
3rd it still took 2 months to complete with a fairly large budget thats R10 to AUS$1.
Anything can be done, but is it worth doing?
Mk1Crazee
Post by Mk1Crazee »
ahh the JDM Mini.. cool project from MCM
ob wan
Post by ob wan »
1. Above average professional level mechanic skills have done worse
2. Welding with MIG and TIG fabrication skills Both i have
3. A fully kitted fabrication workshop i have
4. A heap of cheatahs (Rand's preferably $) not so much of, for customer's expense
5. Time in abundance self employed.
05 G5 Gti (ex)
97 LSvtec (ex)
missioner
Post by missioner »
Hahaha
I hear you brother.
Donavan
Post by Donavan »
Audi A4 B8 2.0T - Daily
