washer dropped into intake
TMG
Post by TMG »
Long time no post. Recently got my Mk2 project car up and running again.
So I disassembled an intake on my 20 8V X-flow turbo and heard a small M6 washer drop by accident. While I cannot be sure that it entered the intake I need to make sure of this before cranking it again. :bang:
I removed the intake completely and cannot find this washer in Cylinders 2-4.
Cylinder 1's intake valve is open and it's possible that the little washer entered the cylinder. Can one inspect the cylinder without removing the head?
Car Make: VW, VW, Aprilia
Re: washer dropped into intake
Post by Jetta2 »
If you have a bore scope you can see in the cylinders.
If not, safest way is to remove the head.
Been there, done that, used plenty choice words.
You can try use a small magnet on a piece of string and get it into the plug hole or past the inlet valve, but seeing as the valves are steel and a magnet will stick to them, that can be an issue in itself.
Use a borescope and go through the spark plug hole. You can get the washer with a magnet throught the plug hole as well.
TMG
Post by TMG »
Thank you for the feedback. I wonder whether one can rent such a scope or whether one could buy a cheap one. In the states little USB versions sell for 15 US$ but I don't know if one can find something similar here?
Howie-WP
Membership No: 2033
Post by Howie-WP »
TMG wrote:Thank you for the feedback. I wonder whether one can rent such a scope or whether one could buy a cheap one. In the states little USB versions sell for 15 US$ but I don't know if one can find something similar here?
Slightly more then $15, but....
https://www.gumtree.co.za/a-digital-cam ... 0432474109
Howie-WP
Membership No: 2033
Post by Howie-WP »
https://www.gumtree.co.za/a-other-camer ... 0180037709
TMG
Post by TMG »
I also searched a bit and contacted a Pretoria based seller, let's see whether I get any response.
TMG
Post by TMG »
What a relief, washer pulled out of cylinder #1. A kind local mechie sent his son with a borescope and with some coaxing with wires and a magnet on the end of a screw driver we were able to get it out. Now to run for oil and some bits and pieces and look to fire her up..also some billies for the kind samaritan.
AlexTDi
Registered for: 12 years 7 months
Car Model: '15 Polo GTI
Membership No: 1724
Post by AlexTDi »
you got lucky! but well done on being patient and finding it first before firing up.
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
