Kr oil issues
- Car Model: Mk3 VR6 Jetta
Kr oil issues
Hi guys it's been awhile, I need some help on my project.
Current setup is stock kr, running some boost.
The issue I am having is there is to much oil coming from the sump breather, I have a pipe from the sump breather directly to a catch can, from the catch can I have a drainage back to the sump.
The catch can does has of a vent for the pressure to be released , however under boost, it's spraying the oil out the oil catch vent. Couldn't fit a small filter on the catch can, so used some perforated material in the mean time.
Need help guys
Need help guys
Im not driving fast.....im flying low !!!
BT Mk4 Gti (Current)
Mk4 Gti (ex)
20v Rsi (ex)
20v Rxi (ex)
Golf 1 1.6i+vat (ex)
Golf 1 abf (ex)
1.3 tazz (ex)
328i droptop (ex)
Jetta Vr6 (ex)
83' porsche 944 (ex)
Golf 1 20v Turbo (ex)
Gsi 16vS (ex)
78' Rabbit stroker (ex)
325is evo2 (ex)
20v Quest (ex)
4E Turbo quest (ex)
1.6i Velocity (ex)
84 mk1 GTI 14.8 at Tarlton (ex)
16 sport Mk2 (ex)
RS2000 (ex)
16 Sport Mk2 (ex)
Mk4 Gti (ex)
20v Rsi (ex)
20v Rxi (ex)
Golf 1 abf (ex)
1.3 tazz (ex)
328i droptop (ex)
Jetta Vr6 (ex)
Gsi 16vS (ex)
325is evo2 (ex)
20v Quest (ex)
4E Turbo quest (ex)
1.6i Velocity (ex)
16 sport Mk2 (ex)
RS2000 (ex)
16 Sport Mk2 (ex)
Re: Kr oil issues
Too much boost
Too much bore clearance
Collapsed rings (from overheating)
Broken ring
Broken piston
Any one of the above.
Broken ring
Broken piston
- AlexTDi
- Car Model: '15 Polo GTI
- Membership No: 1724
Re: Kr oil issues
If it's a stock KR internals drop compression after addressing the issues panic suggested above.
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Daily:
'15 6C Polo GTI DSG
Re: Kr oil issues
The car doesn't smoke, only puff under boost, currently boosting 0.8.panic-mechanic wrote:Too much boost
Broken ring
Broken piston
Mk4 Gti (ex)
20v Rsi (ex)
20v Rxi (ex)
Golf 1 abf (ex)
1.3 tazz (ex)
328i droptop (ex)
Jetta Vr6 (ex)
Gsi 16vS (ex)
325is evo2 (ex)
20v Quest (ex)
4E Turbo quest (ex)
1.6i Velocity (ex)
16 sport Mk2 (ex)
RS2000 (ex)
16 Sport Mk2 (ex)
Mk4 Gti (ex)
20v Rsi (ex)
20v Rxi (ex)
Golf 1 abf (ex)
1.3 tazz (ex)
328i droptop (ex)
Jetta Vr6 (ex)
Gsi 16vS (ex)
325is evo2 (ex)
20v Quest (ex)
4E Turbo quest (ex)
1.6i Velocity (ex)
16 sport Mk2 (ex)
RS2000 (ex)
16 Sport Mk2 (ex)
Re: Kr oil issues
Shucks I did not even spot that. Stock CR and boost mmmm not a great idea.
Re: Kr oil issues
Any way around this panic, drop boost to 0.5?, increase the drainage size, on the catch tank? It is a lot smaller than the intake?panic-mechanic wrote:Shucks I did not even spot that. Stock CR and boost mmmm not a great idea.
Mk4 Gti (ex)
20v Rsi (ex)
20v Rxi (ex)
Golf 1 abf (ex)
1.3 tazz (ex)
328i droptop (ex)
Jetta Vr6 (ex)
Gsi 16vS (ex)
325is evo2 (ex)
20v Quest (ex)
4E Turbo quest (ex)
1.6i Velocity (ex)
16 sport Mk2 (ex)
RS2000 (ex)
16 Sport Mk2 (ex)
Mk4 Gti (ex)
20v Rsi (ex)
20v Rxi (ex)
Golf 1 abf (ex)
1.3 tazz (ex)
328i droptop (ex)
Jetta Vr6 (ex)
Gsi 16vS (ex)
325is evo2 (ex)
20v Quest (ex)
4E Turbo quest (ex)
1.6i Velocity (ex)
16 sport Mk2 (ex)
RS2000 (ex)
16 Sport Mk2 (ex)
Re: Kr oil issues
Drop the compression ratio, have it tuned properly, then boost the crap out of it to your hearts content.
- Car Model: MK 3 GTI 16v Turbo
Re: Kr oil issues
I must cocncur with the above, drop the compression
i am currently running a KR setup in my golf 3 gti, running 1.0 bar boost with lowered compression (9.35:1) no oil leak issues
i found the quickest fix to the compression lowering issue was fitting the 1.8t passat pistons (AGU) in the standard 1.8 KR block with stock rods, and crank ( try get the rods from the 1.8T motor as well)
as a side note: fit a oil cap/Tapet cover breather from the new vw bug to your tapet cover to assist with breathing, and plumb that to your crank breather, and then in to your oil catch can ( works a charm, ill post a pic of mine if i get Photobucket to work)
hope this helps
hope this helps
Re: Kr oil issues
Is it possible to route the sump vent into the catch can, a d then back to the tappet ?
Mk4 Gti (ex)
20v Rsi (ex)
20v Rxi (ex)
Golf 1 abf (ex)
1.3 tazz (ex)
328i droptop (ex)
Jetta Vr6 (ex)
Gsi 16vS (ex)
325is evo2 (ex)
20v Quest (ex)
4E Turbo quest (ex)
1.6i Velocity (ex)
16 sport Mk2 (ex)
RS2000 (ex)
16 Sport Mk2 (ex)
Mk4 Gti (ex)
20v Rsi (ex)
20v Rxi (ex)
Golf 1 abf (ex)
1.3 tazz (ex)
328i droptop (ex)
Jetta Vr6 (ex)
Gsi 16vS (ex)
325is evo2 (ex)
20v Quest (ex)
4E Turbo quest (ex)
1.6i Velocity (ex)
16 sport Mk2 (ex)
RS2000 (ex)
16 Sport Mk2 (ex)
Re: Kr oil issues
Sure it is.
Re: Kr oil issues
denfinitely is, but try leave on vent on the catch can venting to atmosphere
given your current over pressure you may just pop the breather hoses off of the catch can, my breather from tappet and block are connected via a T piece, and then to the catch can
and then one vent to atmosphere from the catch can
Re: Kr oil issues
Agree with others, compression drop required.
What size piping to the breather bottle is installed?
Do you have the large splash plate clipped on the oil pump pick up?
