Scirocco R dyno numbers - updated
- BdtDSG
Hi Peeps,
I bought a 2011 Scirocco R (TFSi) a while back. The previous owner had software done on the car as well downpipe, throttle pipe and a forge actuator. After I fixed some issues, I took it for a power run on a dyno.It made around 170 kw and 390 nm atw. I was expecting a bit more from it though with the mods it has. Logged it and requested boost is met with no errors logged. Are these figures more or less in the expected range for an R with these mods?
Thx
Thx
- Car Model: Audi A4 B8 6MT Turbonetics T66
Re: Scirocco R dyno numbers
What dyno did you run on?
Audi A4 2.0T 155KW Manual FWD. JE Pistons, IE Rods, Calico Bearings, Turbonetics T66.
- BdtDSG
Autotrix in dbn..
Autotrix breaks hearts down here should be right then. If logs look good then don’t stress. PM me if you want to chat further about options.
- BdtDSG
Hehe yep certainly broke my heart!JonathanT4 wrote:Autotrix breaks hearts down here should be right then. If logs look good then don’t stress. PM me if you want to chat further about options.
Something's up with that car or the file, cause that's stock power.
With only software, downpipe and intake our scirocco R made 229wkw at Autotrix
Contact me anytime if you want to have the car looked at, or pull in to TSC Garage - 12 Peter Road, Springfield Park.
Kinetic Garage
0849991860
0849991860
- BdtDSG
Yip doesn't make sense. New k04, new DV, new plugs, boost leak tested, boost peaks at 1.5 at around 3600 RPM and tapers down to 1 at high RPM, which looks correct. So I'm stumped. Will get the file looked at first since hardware seems fine. It does have a forge actuator on the turbo, dunno if I should try the stock one. But the boost curve looks correct though. Will let the pro's take it from here and start with a fresh map.
- BdtDSG
Does the curve look correct for a remapped k04?BdtDSG wrote:Yip doesn't make sense. New k04, new DV, new plugs, boost leak tested, boost peaks at 1.5 at around 3600 RPM and tapers down to 1 at high RPM, which looks correct. So I'm stumped. Will get the file looked at first since hardware seems fine. It does have a forge actuator on the turbo, dunno if I should try the stock one. But the boost curve looks correct though. Will let the pro's take it from here and start with a fresh map.
- BdtDSG
Numbers for one of the pulls done.. has to be something off on the carBdtDSG wrote:Does the curve look correct for a remapped k04?BdtDSG wrote:Yip doesn't make sense. New k04, new DV, new plugs, boost leak tested, boost peaks at 1.5 at around 3600 RPM and tapers down to 1 at high RPM, which looks correct. So I'm stumped. Will get the file looked at first since hardware seems fine. It does have a forge actuator on the turbo, dunno if I should try the stock one. But the boost curve looks correct though. Will let the pro's take it from here and start with a fresh map.
- BdtDSG
Shout-out to Treshen @ CPI for sorting my car out, spent hours at my house on a saturday night diagnosing and logging. Loaded a proper file for me. Very happy with CPI and Treshen's customer service.BdtDSG wrote:Numbers for one of the pulls done.. has to be something off on the carBdtDSG wrote:Does the curve look correct for a remapped k04?BdtDSG wrote:Yip doesn't make sense. New k04, new DV, new plugs, boost leak tested, boost peaks at 1.5 at around 3600 RPM and tapers down to 1 at high RPM, which looks correct. So I'm stumped. Will get the file looked at first since hardware seems fine. It does have a forge actuator on the turbo, dunno if I should try the stock one. But the boost curve looks correct though. Will let the pro's take it from here and start with a fresh map.
- Uncle Nunda
- Post Whore
- Car Model: S3
- Membership No: 1489
so what was wrong initially?
- BdtDSG
The file it had on was just way off, JHB file. And he picked up that fuel pressure is not keeping up. So upgrading HPFP and RS4 pressure valve this week. Then back to same dyno to see if it's on par. Scary part is we could see the car's been mapped 24 times previously. So...Uncle Nunda wrote:so what was wrong initially?
Awesome CPI FTW. We had a chat about your car and so amped for the mods coming!
- BdtDSG
Yip great service from them! Can't wait for the HPFP and RS4 valve...Kameel Kas Ramfol wrote:Awesome CPI FTW. We had a chat about your car and so amped for the mods coming!
- Uncle Nunda
- Post Whore
- Car Model: S3
fokkitBdtDSG wrote:The file it had on was just way off, JHB file. And he picked up that fuel pressure is not keeping up. So upgrading HPFP and RS4 pressure valve this week. Then back to same dyno to see if it's on par. Scary part is we could see the car's been mapped 24 times previously. So...Uncle Nunda wrote:so what was wrong initially?
- BdtDSG
Re: Scirocco R dyno numbers - updated
Updated after sorting out HPFP and SW...BdtDSG wrote:Hi Peeps,
Thx
