Hi Everyone,
I'm Kiran from Gauteng. New to the VW Forum.
Please can I have some advice regarding the following,
I recently had a problem with my car whereby whilst driving, the vehicle started to loose power and produced white smoke from the exhaust. Due to the remote area that I was travelling from, I could not stop so drove the vehicle back home to Midrand. Drove for about 50km with the lose of power.
My local mechanic managed to diagnose certain faults.
High Pressure Fuel Pump - Replaced
Coil Pack (Cyclinder 3 and 4) - Replaced all 4
Injector 3 - Replaced
The car drives normal but for some reason after 90kmph the vehicle looses idle and wants to switch off. What else could be the faults?
Regards
Kiran
2.0 TSI Scirocco Idle Problem
- Car Model: S3, Polo Playa,
Re: 2.0 TSI Scirocco Idle Problem
If you cannot pic any diagnostic codes for the existing fault, vcds have some windows you can sellect some settings to see values while driving, compare actual with request settings you can diagnose the problem, it can be so many things, I dought if anybody will pinpoint the specific fault for you otherwise then guessing
Thank u...will try that
