AUDI A3 2.0T NOT Sparking
I have an Audi A3 2.0 T 2006 MODEL it doesn't spark I have changed the pick up sensor but still no spark. I have also diagnosed it but it doesn't show any fault. Please help me what may be the problem.
- Car Model: VW Golf Plus 1.4 BUD 2007
Re: AUDI A3 2.0T NOT Sparking
Hi just my 50 cents worth, maybe check the key immobiliser coding, there are some locksmiths that have the machine , or maybe try spare key if you have one, if not ,then take to an auto electrician and he will check for voltage supplies and maybe a frayed wire somewhere in the harness, it’s hard to diagnose a car without having it in front of you, most times the Ecu , key reader ring, and body control box can be faulty , maybe it got fouled with water etc
Ex : Polo Vivo, Renault Clio 3 1.6, Renault Megane and Scenic 1.9dci, Renault Clio 3 1.4, Renault Clio 2 1.4, Peugeot 308, Mini Cooper R56 1.6, Polo Tdi 1.4, Jetta 5 2.0 Tsfi Sportline, Ford Focus 2.0a, Bmw 320d E46 f/l, Citi Golf Chico 1.6, Corsa 1.7d converted with Gsi 1.6 engine, BMW X5 3.0im, Bmw 328 E36,Opel Kadett Ts by Group N Opel team, Jetta Vr6, Bmw 316i E36, Astra 160ie, UNO Turbo by Rudi, Bmw 325i Turbo by Alpine, Golf Gti16v exec, Mazda 323 Egi, Bmw e30 318i f/l
Hi ,
Thank you I will check it and update you.
check with vcds and see if there is RPM. If there is an issue with immobiliser it will also show in VCDS
Thanks . Is there anyone around Kempton Park who can assist to check for me with VCDS kindly refer me if you know someone.
