9n3 Boost adjustment issue
So i had the engine rebuild and a new turbo. Before the rebuild the car was boosting around a bar and settling on 0.8. The new engine has done round 10000km and i have been struggling to get the boost back up to previous setting as mentioned. The actuator has been adjusted but i cannot get the car to boost more than 0.5. Took the car to the shop that rebuild the engine and they said to adjust the boost they will have to take the turbo off. This doesnt sound right to me? Is there a way that they maybe bypass a sensor or adjusted something so that even if the actuator is being adjusted the boost will be 0.5 and nothing higher. Any suggestions before i have to spend a hell of a lot of cash to fix this.
Re: 9n3 Boost adjustment issue
Hi
Hatfield Pretoria
Hatfield Pretoria
- Car Model: 2006 polo 9n3 gti
Howzit man pop me a message i can assist you and see if we can pinpoint the issue rather than spending unnecessary money on it.
081 039 3263
081 039 3263
Did they plugin the n75?
The N75 is plugged in. Ive read somewhere that if the fuse for the N75 is blown that would also restrict the boost to .4 bar. Do you guys know which fuse this is? Maybe i should also look at getting a new N75 valve.
yes that is correct, i had a blown n75 fuse and boost was restricted to 0.4 bar
drive side panel by door
not sure which fuse
just check each fuse one by one so you know where to put it back
not sure which fuse
2007 Polo GTI
2013 Honda Ballade Elegance
1996 Honda Ballade 150i
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
2007 Polo 1.6 Comfortline
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
Make sure it is the issue before spending money replacing it. Have you scanned for errors? Run logs yet?
- Car Model: Mk7 GTi
- Membership No: 2093
Possibly they have incorrectly plumbed the N75 valve. Check that there first. With the plug facing you, Boost source should route the "underneath" of the valve, left of valve should feed to actuator and the other side should bleed into the turbo inlet.
Current: Mk7 Gti
Previous: Ibiza Cupra 20vT; Polo GTi 20vt
TSC Garage
Performance Tuning Solutions
info@tscgarage.co.za
0619955604
TSC Garage
0619955604
and remember if you disconnect the line from n75 to wastegate you will overboost, basically turbo will keep boosting till it goes boom.
basically thats how i tested to see if my turbo was still ok..
after fitting another n75 still no boost
then i checked the fuses, and problem found
but i had a boost gauge and did not let boost go over what it usually did
lol neat trick like in f&f latest f&f movie put a clip to your line to wastegate and pull it to win a race
burn car as well
lol
i wonder how many guys will pull their line to wastegate after that
burn car as well
lol
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
I checked and saw that the boost source and the feed to the actuator was swopped around. The car is boosting 0.9 on 93. Luckily the tank is on reserve and will fill up with 95 and then adjust the actuator another turn to turn and a half to get to a bar.Nikz_tsc wrote:Possibly they have incorrectly plumbed the N75 valve. Check that there first. With the plug facing you, Boost source should route the "underneath" of the valve, left of valve should feed to actuator and the other side should bleed into the turbo inlet.
Thanks guys for the help!!!!
