Goo day gents,
What would cause this turbo Flutter on my S3 8L apart form a defective DV ?
I have tested my 710N DV and it works perfectly.
Boost leak perhaps ??
Should I do a Leak test ?
Low down rpm turbo flutter ?
- P1LAYA-ZN
- Car Make: Audi, VW and Toyota
- Car Model: S3 8L 20VT & Mk 1 Jetta GLi
- Car Make: VW Polo
- Car Model: Gti
- Membership No: 2029
Re: Low down rpm turbo flutter ?
Mine did this before. Was a vacuum hose that popped off the top of the dv. Have a look at the vacuum hoses around there. Could possibly be torn.
- P1LAYA-ZN
I've checked, no obvious leaks.
Car also doesn't seem to be boosting properly. Just the turbo flutter is very noticeable.
I think I'm gonna do a boost leak test and go from there.
Does anyone have a fitting for a K04 TIP to do the Test ?
I only have 1 for my A3 K03S
Also, when fitting the Boost guage, where is the best place to put a T-piece for Vacuum ?
I know most use the FPR, but is it it the best place ?
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
T it from the DV line, that way if it pops off it doesn't drop the pressure to the FPR causing a drop in fuel pressure.
- SoDub
- Chairman
- Car Make: Seat
- Car Model: Seat Ibiza Cupra 20VT
- Membership No: 1998
Have you done any deletes? Mine Fluttered and was not boosting fully. Changed to a new DV and did the same. Bypassed the N249 and it went away.
El Toro
2009 Seat Ibiza Cupra 1.8T(El Toro)
Blossom
2007 Seat Ibiza Cupra 1.9TDi(Blossom)
Turbo Killer Sportline
2007 - Polo TDI Sportline
"I live my life 1 turbo at a time."
El Toro
Blossom
- P1LAYA-ZN
I'm actually thinking of doing that delete.
If it works it probably means there is a vacuum leak.
Any simple ways to test for Vacuum leaks ?
- Kyle
- General
- Registered for: 11 years
- Car Make: Porsche
- Car Model: Adidas TYP 64
- Membership No: 1922
Based in Durban? I’d be happy to assist.P1LAYA-ZN wrote:I'm actually thinking of doing that delete.
- P1LAYA-ZN
Yup Isipingo/Toti area.Kyle wrote:Based in Durban? I’d be happy to assist.P1LAYA-ZN wrote:I'm actually thinking of doing that delete.
I sent you a pm.
