Polo 6R GTI oil in the intake pipes
kingozzi
Registered for: 6 years 8 months
Car Model: PGTI1.4tsi 172kw 309nm(crank)
Post by kingozzi »
Howzt guys.
I have a PGTI 6R that consumes oil but no oil leaks, so i read here that there's twincharged motors use oil, so out of curiosity i opened the intake pipes from the turbo and found oil, not a pool but i could clearly see the oil..found more from the airbox to the regulating flap control unit.. so i though PCV valve, checked and its blowing one direction.. the car uses @list 500ml every +-1000kms..
Question: could this be the turbo? (Bad seal myb? If it is, shouldn't oil be on the exhaust side since the intake is sucking air in )
Question 2: could it be the oil separator (where is it located )
Thanks in advance
