Please Help!!!
Please Help!!!
Good evening guys,
I have a 2002 Golf 4 2.0 and i am planning on turbo charging it. I need help wiht which turbo to use ect. I have the following on my list and please let me know if i am forgetting about something.
I want to use std internals. I am planning on doing max boost of 0.6 bar. I am currently running a Spitronic Management but will be changing it to a Dictator STD system.
1. Turbo Manifold - Guy is charging me R1 800 to build one
2. Intercooler (550x140x65) R1600
3. Oilcooler R1100
4. Turbo ???
5. Dump Valve R600
6. Dictator STD Management R2650
7. Boost Pypes ???
8. Turbo Timer R595
9. Oil Catch Tank R680
10. Fuel Pressure Regulator R595
11. Fuel Pump ???
12. Oil Cooler Sandwich R450
13. V-Band Clamps ???
14. Oil Pressure Gauge R330
15. Oil Temp Guage R295
16. Boost Gauge R280
What else do you guys think i need. Any advise will be greatly appriciated.
3. Oilcooler R1100
4. Turbo ???
5. Dump Valve R600
7. Boost Pypes ???
8. Turbo Timer R595
11. Fuel Pump ???
- THEGTOWNER
Re: Please Help!!!
Add breaks and suspension in there no point in all that power if you can't stop or put it to the ground. Be safeDanieRichards wrote:Good evening guys,
3. Oilcooler R1100
4. Turbo ???
5. Dump Valve R600
7. Boost Pypes ???
8. Turbo Timer R595
11. Fuel Pump ???
Sent from my SM-A500FU using Tapatalk
Re: Please Help!!!
The brakes has been upgraded already and i am going to stiffen the suspension.
- THEGTOWNER
Re: Please Help!!!
Sweet sorry man just have to cover all the bases how much power does she make?
Re: Please Help!!!
The biggest thing you are forgetting is a way to drop the compression ratio.
And then it's all the little things, turbo oil supply line, turbo return line.
You can buy a 20vt sump and use that and possibly use the 20vt return line with some mods.
- P1LAYA-ZN
- Car Make: Audi, VW and Toyota
- Car Model: S3 8L 20VT & Mk 1 Jetta GLi
Re: Please Help!!!
Why not just sell the 2.0 and buy a Golf 4 1.8T and save some follicles
I'm sure it will work out alot cheaper and use the same cash for mods.
- THEGTOWNER
Re: Please Help!!!
Apparently the 1.8 20v turbo motor can go to 230wkw on stock internals too
- THEGTOWNER
Re: Please Help!!!
That's the 1.8T 20v Aug/Bam motor fitted to the golf 4 gti /Audi S3 2005ish modelsTHEGTOWNER wrote:Apparently the 1.8 20v turbo motor can go to 230wkw on stock internals too
The Aug motor does 110 kw at the flywheel stock
The Bam motor does 132 kw at the flywheel stock
So a good Base to start from and you can pick them up for around 20k with the gearbox if I'm not mistaken
Re: Please Help!!!
Why changing management systems? Both can be mapped for boost.
- marzbars
- Car Model: 1988 Corrado 16V
- Membership No: 1316
Re: Please Help!!!
Graham Savage went through this exercise on a XFlow mk4 2.slow
Maybe look for his rides thread for whatever info is there.
Current : 1988 VW Corrado
Ex : 1990 VW Golf CSL 1.6
Ex : 1995 VW Caddy 2.0 8v
Ex : 1996 VW Golf 3 GTS 1.8i
Ex : 1995 VW Golf 3 GTI
Ex : 1993 VW Chico 1.3
- amstel18
- Car Model: Tiguan Allspace
Re: Please Help!!!
BAM was 165kw.THEGTOWNER wrote:That's the 1.8T 20v Aug/Bam motor fitted to the golf 4 gti /Audi S3 2005ish modelsTHEGTOWNER wrote:Apparently the 1.8 20v turbo motor can go to 230wkw on stock internals too
But ja somehow my previous reply got lost somewhere.
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
- THEGTOWNER
Re: Please Help!!!
Oh **** so I'll definatly spend the extra on the bam motor then
Re: Please Help!!!
Turbocharging a motor is not as simple as most people think. Its not just fitting a turbo. There are always small things that make u wish u didnt do the conversion. And i highly doubt 0.6bar will keep u satisfied for a long time, boost is addictive.
Rather save and buy a motor that comes turbo charged, it can handle more boost, less possibilities of breaking and will save u the time trying to figure stuff out
