Hi guys, I scanned a mk5 gti for a friend and these keep popping up. Any help will be appreciated.
3 Faults Found:
000051 - Turbocharger Bypass Valve Control Circuit
P0033 - 004 - Malfunction / Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 37
Reset counter: 255
Mileage: 157133 km
Time Indication: 0
Date: 2000.00.00
Time: 09:34:10
Freeze Frame:
RPM: 690 /min
Load: 34.1 %
Speed: 0.0 km/h
Temperature: 77.0°C
Temperature: 42.0°C
Absolute Pres.: 990.0 mbar
Voltage: 12.065 V
012599 - Intake Manifold Runner Control
P3137 - 001 - Basic Setting not Completed - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 160496 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 78.0°C
Temperature: 45.0°C
Voltage: 12.192 V
005769 - Powertrain Data Bus
P1689 - 008 - Implausible Message from Elect. Load Controller - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 161851 km
Time Indication: 0
Date: 2000.00.00
Time: 16:35:55
Freeze Frame:
RPM: 750 /min
Load: 23.1 %
Speed: 0.0 km/h
Temperature: 63.0°C
Temperature: 24.0°C
Voltage: 14.097 V
Readiness: 0000 0000
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 636 0070
Coding: 0012122
Shop #: WSC 00000 000 00000
VCID: 8109E38FD8FC51161BD-80D4
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
1 Fault Found:
00883 - Ignition Switch (D) Terminal S
012 - Electrical Fault in Circuit - Intermittent
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Part No SW: 1K6 920 873 HW: 1K6 920 873
Component: IMMO VDD 1610
Revision: V0003000 Serial number: VWZ7Z0F8153067
VCID: EFEDB537FE685766FD9-80BA
1 Fault Found:
00003 - Control Module
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 125795 km
Time Indication: 0
Date: 2000.00.00
Time: 15:11:37
I hope they come out right as I'm using my phone to post. Any help as to what they might be?
Error codes on mk5 gti
Re: Error codes on mk5 gti
Your DV is poked. (unless you unplugged it at some point with ignition on)
Do a recalibrate on the manifold flap.
Clear errors. see what comes back.
Thank you. Will do that.
