The Fabrication thread.
- 1.8iblackie
- Car Model: vw polo classic. NO ENGINE
Re: The Fabrication thread.
Finished up the collectors and worked on a dual fuel 8 injector setup Im doing on a ca18det.
This is the parts I built for Grant's vr6 turbo. Made 325kw last night on 0.8bar. Break in period is done going over to the Eth now on 1.5bar
8vT 187.2kW and 361Nm
- 1.8iblackie
Did some aliminium build up on a rowland manifold that some genius ported in all the wrong place. Now to get both faces skimmed and reshaping the ports. The custom interxooler on the ca18det found its home.
Nice work bud, tell me would you be able to do floor pan repair work?
- marzbars
- Car Model: 1988 Corrado 16V
- Membership No: 1316
Saw your Electig Eel sticker on a car I went to look at some time ago
Current : 1988 VW Corrado
Ex : 1990 VW Golf CSL 1.6
Ex : 1995 VW Caddy 2.0 8v
Ex : 1996 VW Golf 3 GTS 1.8i
Ex : 1995 VW Golf 3 GTI
Ex : 1993 VW Chico 1.3
- 1.8iblackie
I dont do body work like tht unless its for my own stuff. There are vplenty of body shops that are real good with that kind of repairs. Started modifying a 20v intake today to go onto ABF turbo.
Machined off the bits i dont need now to weld them together and port it.
- 1.8iblackie
What car was it? I dont like handing out stickers as the guys just stick on their car that have real bad fabrication done on them.marzbars wrote:Saw your Electig Eel sticker on a car I went to look at some time ago
If You see a sticker like this You know its my work. I did custom manifold and exhaust on this tdi. Made 246kw with Nos.
- Carel040
Yea I agree soft porn just for sake of the kids
- marzbars
Was a silver Audi A3
Sticker on the intake/battery box
- stig
- Membership No: 2083
I have one of your intercooler kits i bought from Quintin Qtec. Great kit, only one comment. The pip running from the turbo to the cooler, hot side, it had a bracket where you bolt it to the gearbox welded to the pipe. Mine was leaking on that bracket weld on the pipe, whole weld cracked. Maybe look into improving this in future. Like i said kit is awesome just had that issue.
The Ride:
H&M Dyno Night: 114KW 429NM
- 1.8iblackie
stig wrote:I have one of your intercooler kits i bought from Quintin Qtec. Great kit, only one comment. The pip running from the turbo to the cooler, hot side, it had a bracket where you bolt it to the gearbox welded to the pipe. Mine was leaking on that bracket weld on the pipe, whole weld cracked. Maybe look into improving this in future. Like i said kit is awesome just had that issue.
Ask Quinton why that bracket is there. He wanted them there. Built the first one on his car and then just copied them. Told him from the start they will brake off. There was another bracket just before the MAP sensor that I removed and he wanted.the top pipe as a 2 piece pipe that I also stopped doing like that.
- stig
Yeah mine has both brackets stil on but I now removed the gearbox one.1.8iblackie wrote:stig wrote:I have one of your intercooler kits i bought from Quintin Qtec. Great kit, only one comment. The pip running from the turbo to the cooler, hot side, it had a bracket where you bolt it to the gearbox welded to the pipe. Mine was leaking on that bracket weld on the pipe, whole weld cracked. Maybe look into improving this in future. Like i said kit is awesome just had that issue.
The Ride:
- 1.8iblackie
- Membership No: 2101
I'd be interested in this. Will it be something like the IE manifolds for the TFSi?1.8iblackie wrote:I work entirely on my own so I dont really have time to do development on more than 1 thing at a time. Im busy with a CNC machined intake manifold for thr tfsi motors.
- 1.8iblackie
Kuvi-VPS wrote:I'd be interested in this. Will it be something like the IE manifolds for the TFSi?1.8iblackie wrote:I work entirely on my own so I dont really have time to do development on more than 1 thing at a time. Im busy with a CNC machined intake manifold for thr tfsi motors.
Not like IE ones.
- 1.8iblackie
