Mk5 GTi does nothing when i turn the ignition key
- Car Model: MK6 GTi DSG
Had the battery disconnected and when i reconnected the terminals the ratchet accidentally touched the other terminal. When i open the door the lights come on as per usual. Radio works, instrument cluster lights up with dates, km and distance travelled. When turning the key absolutely nothing happens.
André Chivell (aka VWDIEZL / aka SHOVES)
Current: '09 Golf 6 GTi DSG aka Phat ass
Hers: '08 Touran 1.4TSi
Previous
2007 VW Golf 5 GTi DSG
2009 VW Tiguan 2.0 TSi 4motion
2011 Hyundai Santa Fe CRDi AWD
2012 Hyundai iX35 2.0
2004 Toyota Caldina GT four AWD
2003 Ford Focus ST170
2002 Hyundai Tiburon FX
2002 Subaru WRX V7
2002 Toyota RunX sport
2007 Toyota Camry 2.4 Sportivo
1996 Toyota Celica coupe
Previous
2002 Subaru WRX V7
- Registered for: 7 years
- Car Model: Golf MK5 2.0 TFSi
Re: Mk5 GTi does nothing when i turn the ignition key
I did the same thing, and it was a fues that burnt, thats a good place to start...
They seems to ok... the auto elec's next recommendation was the ECU.
Previous
2002 Subaru WRX V7
Previous
2002 Subaru WRX V7
Niks...
Previous
2002 Subaru WRX V7
Previous
2002 Subaru WRX V7
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
The motor would still turn if the ecu was fried. Something has shorted or a fuse has popped somewhere. Go through every fuse again.
check the big fuses on the battery this is exactly why you should just use a short spanner when you tighten the battery and why you do positive first and then the negative.
Next thing, how do i get it into neutral when the ignition is dead?
Need to get the car moved out of the garage.
Previous
2002 Subaru WRX V7
Previous
2002 Subaru WRX V7
Lift up the cover under the lever, the park lock solenoid can be pulled back and the box then can shift into neutral. Its the silver "barrel" on the right of the shift mech. If you look at the lever you can see the pin holding it in park, use a screwdriver to gently push it out the way.
Sent from my GT-I9505 using Tapatalk
Oh you definitely popped the main fuse. It will be one of the four on top of the battery.
there is a release for the gearlever somewhere in the front of the gearlever
- Membership No: 2033
Updates André?..... You get it out the garage and running again. I know you're in NZ and all, but still......
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
Haha... so she was towed to the european dealership. They plugged in VAG COM and voila... she started again. Needed a reset of some sort...
Previous
2002 Subaru WRX V7
Previous
2002 Subaru WRX V7
Glad you got sorted. I wonder if you disconnected and reconnected the battery if that would have had the same effect. Next time be more carefulshoves wrote:Haha... so she was towed to the european dealership. They plugged in VAG COM and voila... she started again. Needed a reset of some sort...
HOWIE-WP,
