Le Clue
Posts: 10890 Registered for: 14 years 7 months
Car Model: Golf Mk7 GTI Clubsport
Membership No: 1458
Post
by Le Clue » Wed Mar 22, 2017 11:30 am
MacMan wrote: DIY
Yes but what of you pull an injector and need to replace the teflon seal?
Sent from my iPhone using Tapatalk Pro
Previous Rides:
2011 VW Golf Mk6 R
2007 VW Golf Mk5 GTI
2013 VW Polo 6R GTI
2011 VW Scirocco GT 2.0TSI
2010 VW Golf Mk6 GTI
2007 VW Polo 1.9TDI Sportline
2009 VW CitiRox 1.6i
MacMan
Posts: 4120 Registered for: 21 years 8 months
Car Make: SEAT
Car Model: Tarraco XC 1.5 TSi
Membership No: 478
Post
by MacMan » Mon Mar 27, 2017 5:41 pm
Le Clue wrote: MacMan wrote: DIY
The injectors should be removed and cleaned anyway because they're very likely to also have some build-up on them.
The injector repair kit is around R150 per injector, so still much cheaper than getting a shop to do it.
'20 SEAT Tarraco XC 1.5 TS i
'12 VW Up! 1.0 MP i
'06 Golf MKV GT i
'04 Golf MKIV GTi .:R
'99 Citi Golf 2.0i
Le Clue
Membership No: 1458
Post
by Le Clue » Thu Mar 30, 2017 2:01 pm
MacMan wrote: Le Clue wrote: MacMan wrote: DIY
I know that - The problem is not having the special tool to replace the injector seals. I would love to DIY it though...
Previous Rides:
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
MacMan
Car Make: SEAT
Membership No: 478
Post
by MacMan » Fri Mar 31, 2017 12:17 pm
Le Clue wrote: MacMan wrote: Le Clue wrote: MacMan wrote: DIY
You don't need a special tool. You can use a small socket to push the seal onto and then transfer the seal onto a slightly bigger socket, and then onto the injector.
'12 VW Up! 1.0 MP i
'06 Golf MKV GT i
'99 Citi Golf 2.0i
Posts: 26715 Registered for: 21 years 8 months
Post
by panic-mechanic » Fri Mar 31, 2017 12:35 pm
I made my own special tool. If you have a lathe and a piece of roundbar you can knock it out in 10 minutes
Le Clue
Membership No: 1458
Post
by Le Clue » Sat Apr 01, 2017 11:29 am
Ahhhh... thanks
Previous Rides:
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
