charcoal cannister on polo 9n3 gti
Hi guys. I just want to find out about the charcoal cannister on 2007 polo 9n3 gti. Has anyone ever changed this part. My car has about 200k on the clock now and just thinking that maybe over time it is blocked or clocked up or has a leak or something and causing the fumes I can smell when idling. Can someone tell me where it is on this car and also what is the part number for the cannister.
- Deranged_9n3
- Darth Vader
- Membership No: 1639
Re: charcoal cannister on polo 9n3 gti
WUTEl Toro wrote:Hi guys. I just want to find out about the charcoal cannister on 2007 polo 9n3 gti. Has anyone ever changed this part. My car has about 200k on the clock now and just thinking that maybe over time it is blocked or clocked up or has a leak or something and causing the fumes I can smell when idling. Can someone tell me where it is on this car and also what is the part number for the cannister.
My Youtube Channel
Tiguan Track & Field 4Motion
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
Loud 'n Low, Rollin' Coal
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
What are you trying to say here dude. Are you being sarcastic here.
- Deranged_9n3
- Darth Vader
Never in my life have I heard of something like this. So basically, I am waiting for someone more knowledgeable than myself to give some clarity on the subject
My Youtube Channel
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
- chrisg4
- Car Make: Seat
- Car Model: Cupra 1.8T
I assume he is referring to a catalytic converter?
Soldier510
Seat Cupra 1.8T
Toyota Corolla 1.6
Ex Polo 9n3 1.6i Comfortline
Ex Golf V 2.0 Black Magic
Ex Golf IV 1.6
Ex Jetta II Clx
Ex Toyota Corolla 1.3
Seat Cupra 1.8T
Toyota Corolla 1.6
Ex Golf IV 1.6
Ex Jetta II Clx
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
The charcoal canister is a part of the EVAP system, a fuel smell can be a result of it leaking, not sure how often they need to be replaced, I would say almost never. First check that the car isn't leaking fuel from the fuelling system, if you're sure it isn't then replace the canister.
I am actually referring to the carbon canister or evap canister which ever you want to call it. I've read up on it and people do say that if the charcoal in the canister gets degraded over time it can and will cause emissions issues by venting all the fumes into the atmosphere and hence the smell of fuel I am getting. Also by venting these fumes into atmosphere, it's not going to the engine where it is used so someone correct me if I'm not mistaken here but this can affect the air fuel ratio as well.
I have checked and am certain that the car is not leaking fuel or else I would have easily seen it on the garage floor. No fuel leaks no water leaks and no oil leaks.
- THANAS
- Forum Advertiser
You won't necessarily see it on the floor. Deteriorated rubber can sweat fuel and when it does leak it normally only does so under pressure and then it's as a fine mist (which is its most dangerous form as it vapourises very easily). Find a second hand canister or just replace it.
- Car Model: Polo 9n3 GTi
Is it possible to delete this?THANAS wrote:You won't necessarily see it on the floor. Deteriorated rubber can sweat fuel and when it does leak it normally only does so under pressure and then it's as a fine mist (which is its most dangerous form as it vapourises very easily). Find a second hand canister or just replace it.
'07 Blue Polo GTi 9n3
Powerflow 76mm DP- 63mm Zorst> 90deg intage/cone> Forge TIP> Forge Splitter DV> Forge Charge Pipe> Cupra FMIC> BC Coilies> R8 Coilpacks> 4Bar FPR > Devils Own Stage2 WMI
So the very basics of it is like the picture. it is possible for the evap purge valve side to be blocked or not working then maybe fuel is filling the charcoal canister and you are smelling it. To delete you will have to do some plumbing and then it might be smelly all the time.
The thing is there can only be raw fuel in there if the tank was overfilled and it pushed into the canister.
if you smell it ALL the time I am back where you need to check or replace all hoses.
it is very possible to have a fuel leak and never see fuel on the floor.
You could even have a leaking o-ring around in injector and smell it but never see fuel at all on the floor or dripping.
Thank you much appreciated
