Well done!! For a first try it looks very good and will do the job just fine.ob wan wrote:thank you, think it came out ok regarding it's my first manifold ever, still lots of work
to make it look the part though
I´m sure you have a plan to cover the fuel lines with some heat resistant protection as the exhaust will be passing down on that side.
May I also suggest that you put a support bracket, flat bar on either side of the turbo flange to the head flange side where possible to assist in preventing welds to crack with flex that will occur between motor and exhaust downpipe.
