My 16v build, continued
- Robz
- Registered for: 11 years
- Car Model: Polo Classic 20V
- Membership No: 3256
- vadia
- Car Make: vw,nissan,merc
- Car Model: mk1,np300,c200 amg,gti7
Re: My 16v build, continued
hi i have a golf 1 20l 8v turbo it has a t28 on her and a 600*300*76mm intercooler its running on 0.5 and overboost @0.7 and i noticed from 5000rpm clutch slips on boost and it hsa a sachs im using a 3mm stainless steel plate in the middle of the orignal metal head gasket all i did was remove the rivets and swop the steel plate win the center with the 3mm plate and it works fine just put copper spray car is running strong on dictator but i noticed on idle rev is not so smooth it moves a bit so i think i need to take my baby to panic to dyno tune it up all i want is to have good power and show does 6 digit cars what a golf 1 can smoke them like already i smoked a ford focus st from lifestyle robots on beyers till the witkoppen cross he was shocked
opel monza cd
ford xr3i
mazda 626 200i egi
ford bantam
vw beach buggy
vw mk1 2.0 8v turbo
ford xr3i
mazda 626 200i egi
ford bantam
vw beach buggy
vw mk1 2.0 8v turbo
- Robz
Send your clutch in to norbrake so they can make a 4 puk solid button clutch out of it and maybe dual-diaphragm pressure plate should sort your slipping issues.
- vadia
thanks and around what will be my budget
opel monza cd
ford xr3i
mazda 626 200i egi
ford bantam
vw beach buggy
vw mk1 2.0 8v turbo
ford xr3i
mazda 626 200i egi
ford bantam
vw beach buggy
vw mk1 2.0 8v turbo
- Robz
This I cannot tell you. Mine was done for around R1600 3 years back and still going strong. I do have to replace my pressure plate some time.
- ob wan
- Car Model: MK1 2.0 16vT
Seems i damaged 2nd gear, making a noise but still drives, any tips before attempting to open up the gearbox?
05 G5 Gti (ex)
97 LSvtec (ex)
05 Ford Ranger 4.0 V6
Mk1 velo 2.0 16v...Turbo
97 LSvtec (ex)
Get these spline sockets, size12, 8 and 6.ob wan wrote:Seems i damaged 2nd gear, making a noise but still drives, any tips before attempting to open up the gearbox?
5th gear, mainshaft bearing retainer and CV joints use these sockets.
Oh also get an assistant, 5th gear is fracking tight, someone must hold the box still while you crack the bolt loose with the power bar.
The rest is too long to explain in one post. So if you have a little money, drop the box off with Oom Poy at 8V developments and let him sort you out.
If you want to DIY look here:missioner wrote:Get these spline sockets, size12, 8 and 6.ob wan wrote:Seems i damaged 2nd gear, making a noise but still drives, any tips before attempting to open up the gearbox?
http://brokevw.com/
Or
you can contact me on Friday when I'm back in SA to help you.
- Robz
Hi Papajo
This is a great site thanks and will come in handy in the next month or two as I have to get ARP bolts installed onto my FFZ's diff.
- ob wan
Need a new mainshaft, broke a tooth off, any suggestion on where to source one? Oh and thanks for the tips and sites guys, it made this job very easy
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
Robz wrote:Hi Papajo
I can check for you on Saturday. Should still have a few at home.ob wan wrote:Need a new mainshaft, broke a tooth off, any suggestion on where to source one? Oh and thanks for the tips and sites guys, it made this job very easy
- ob wan
Fantastic!!!!PapaJo wrote:I can check for you on Saturday. Should still have a few at home.ob wan wrote:Need a new mainshaft, broke a tooth off, any suggestion on where to source one? Oh and thanks for the tips and sites guys, it made this job very easy
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
from what I gather on brokevw.com, all vw 22mm mainshafts have the same 1st and 2nd gear which is machined to the shaft?
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
Correct.ob wan wrote:from what I gather on brokevw.com, all vw 22mm mainshafts have the same 1st and 2nd gear which is machined to the shaft?
- ob wan
picked up a donor box for R800 just now, what a bargain!
papajo, will push on your button if I get stuck, thank you very much
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
Good find and great price.ob wan wrote:picked up a donor box for R800 just now, what a bargain!
- ob wan
Just finished assembling it, will put the box back tomorrow and report the outcome
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
Smooth as silk!
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
ob wan wrote:Smooth as silk!
- ob wan
had my first hick-up with the box, selector locating screw seized... luckily I check it first before removing the gearbox
couldn't get it out of third gear so coasted home in 3rd...
nr2 in the pic below, funny thing is, the box feel fine without it?
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
update: my DIY double diaphragm pressure plate mod
straps will be made double aswell and the rivets are exactly 6mm, so might use m6 button head cap for that, big thanks to Rinus aka blueblob
input will be valuable, so please comment...
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
more than 10k views!!! thanks to all watching! I'm off to the bottle store!!!!!
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
- ob wan
clutch done....
some extra safety measures, didn't go double straps
camera makes the angle look very weird and extreme but it's all good and no that's not a crack it's debris
05 G5 Gti (ex)
97 LSvtec (ex)
97 LSvtec (ex)
