Polo GTI 1.8T Smokes On Idle When Cold
Pynoxim
Car Make: Lexus
Car Model: GS300
Re: Polo GTI 1.8T Smokes On Idle When Cold
Postby Pynoxim » Thu Dec 08, 2016 4:07 pm
I collectively know of around 10 1.8T's that have Valve Stem Seal issues, they all smoke in traffic, and on pull off after idling for a few seconds etc.
Thursday Milkshake Crew
'00 GS2 Lexus GS300
P1LAYA-ZN
Car Make: Audi, VW and Toyota
Car Model: S3 & A3 20VT & Mk 1 Jetta GLi
Postby P1LAYA-ZN » Thu Dec 08, 2016 4:34 pm
If valve stem seals are worn the car would smoke on start up. I don't have this symptom. If it were rings it would smoke all the time.
#Builtnotbought
Kevin vw 1.8t
Postby Kevin vw 1.8t » Fri Dec 09, 2016 11:04 pm
I change the valve below the intake sorted my prob out car doesn't smoke anymore
Kevin vw 1.8t
Silver Srfer
Car Model: Polony GTi
Postby Silver Srfer » Mon Dec 12, 2016 8:28 am
So I changed the PCV and cleaned out the intake.
Car still smokes on idle (when hot) :bang:
Stupid thing looks like it needs new valve stem seals :bang:
Runx RSi 2ZZ | Energy Suspension | UniQ+ | Competition Clutch | MWR | HKS | ProFit |BLOX |
9N3 GTi | 76mm DP |Intake | FMIC
JasonCPT
Car Model: A4 1.8T
Postby JasonCPT » Mon Dec 12, 2016 9:52 am
Silver Srfer wrote:So I changed the PCV and cleaned out the intake.
Luckily they're cheap, not sure about labour though.
2004 B6 Audi A4 1.8T - Atlas Grey
FK Automotive | Forge | Jaylan Performance | Zeetech Customs | VAGAS | Ratchet Garage
WBN
Wheel Whore
Car Model: 9n3 Polo GTi
Membership No: 3056
Postby WBN » Fri Dec 22, 2017 7:57 pm
Try this.... drain all the coolant...fill up with water....let it idle a little. ..then drain a few litres of the water and add coolant...and see if it's still doing the same thing
Sent from my SM-G800F using Tapatalk
Keshan_G
Car Model: Polo 9n3 GTi
Postby Keshan_G » Wed Jan 03, 2018 2:43 pm
90% of the time it could be the turbo seals, have you noticed a drop in oil levels?
Also the pcv sits under the intake manifold near the oil cooler and the prv sits on the tip
'07 Blue Polo GTi 9n3
Powerflow 76mm DP- 63mm Zorst> 90deg intage/cone> Forge TIP> Forge Splitter DV> Forge Charge Pipe> Cupra FMIC> BC Coilies> R8 Coilpacks> 4Bar FPR > Devils Own Stage2 WMI
Remzo
Postby Remzo » Sun Jan 14, 2018 4:59 pm
did you change the pcv or the prv? the prv is the one thats on your tip....better known as the hockey puck....the pcv sits under the intake manifold it sits in a T piece lots of people get confused just double check...or change both of them for a piece of mind
Return to “Forced Induction Petrol Engines”
Users browsing this forum: spdgti and 19 guests
