G6 gti timing chain tensioner issues
Fahiem-Vr6
Registered for: 12 years 7 months
Post by Fahiem-Vr6 »
Hi Guys
So on Friday while driving home I heard this terrible noise coming from the engine bay.
I was only a few hundred metres away from home so cruised the rest of the way.
I switched the car off and on again but the noise was still there.
I then noticed the check engine light was on.
I also noticed the car took a while to start when turning the engine over.
Yesterday I took the car to VW and I just received a call to advise me that the tensioner failed which caused the timing to go out as well due to the timing chains jumping a tooth/teeth.
It is a 2009 model with 70k kilometres on the clock.
VW is waiting for authorisation from motorite before ordering the new tensioner.
My question is, is the tensioner and a few bolts the only thing that should be replaced in this instance ?
I have read up on forums that sometimes the entire chain gets replaced, even valves etc.
I would appreciate some help.
nemesis20v
Registered for: 15 years 4 months
Car Model: Edition35
Re: G6 gti timing chain tensioner issues
Post by nemesis20v »
Hopefully you didnt bend valves....
Current: 2013 Golf 6 GTi ED35 DSG
ex: 2009 Golf 6 GTi DSG
ex: Runx Rsi
ex: Rxi 20v 14.98 msa
GB9
Car Model: 8V S3 Sedan
Post by GB9 »
Suffered this yesterday, but luckily, I had taken my car to VW before the horrible engine rattle was experienced. My car had been struggling to start since Tuesday and started idling poorly on Thursday. Static CEL came on, so I took it in on Friday, despite all VW dealers in Durban saying that they could not see me until next week Thursday! Whilst at VW, I started the car for the service manager and the death rattle was heard.... Looks like I'm without my car for a week or two now, due to all VWs in Durban being chokka-block!
2015 Audi S3 Sedan : Nappa leather seats, LED headlights, Panoramic sunroof, rear PDC, B & O sound system
2010 VW Golf 6 GTi : RNS-510 Nav | Xenons | Adaptive Chassis Control
2005 VW Polo TDi (96kw) F/L
1996 Opel Kadett 160IS
1996 Citi Deco (Jazz Blue)
NeoSA
Post by NeoSA »
Did you guys keep tabs on your oil levels at all? GB9 - what year model is your car?
'11 MK6 GTi DSG - Unitronic 2+
GB9
Post by GB9 »
NeoSA wrote:Did you guys keep tabs on your oil levels at all? GB9 - what year model is your car?
Yeah, I'd checked it last week and it was pretty much in the middle, if not a little below. When I checked it again on Friday, whilst at the dealer, it was a bit on the low side. It's a 2010 model. I've no idea what is in store for Charlie now, but he has a maint. plan until 2015 / 120 000km. Mileage is on 100 494km, so I'm glad I upgraded from a service plan to an extended maint. plan! I did it for this very issue too... Now to see whether I bent anything.
NeoSA
Post by NeoSA »
Good luck dude. I'm sure it's going to work out just fine!
I think the theory that this is linked to low oil levels does hold water somewhat.
NeoSA
Post by NeoSA »
Do we know if there's any update to this? I like to keep track of issues like these and to hear different experiences.
GB9
Post by GB9 »
NeoSA wrote:Do we know if there's any update to this? I like to keep track of issues like these and to hear different experiences.
I have an update; VW have told me that they need to replace the head. Will get the quote tomorrow and post it here. Maybe a chance that the bottom end (i.e. the whole engine) needs to replaced too, but they'll only know once they remove the head, I reckon.
NeoSA
Post by NeoSA »
Man you're lucky you're not modded. Apparently they use Odis on all of the cars now, no longer just mk7's. It's probably the only downside to owning a MK6 gti - knowing that at any time, at any moment, your engine will eat itself.
TimeShifter
Car Model: 2012 Mk6 GTi
Post by TimeShifter »
:hijack: Sorry for the hijack, iirc NeoSA was looking/investigating this issue a while ago. What was your findings bud? Are only the 2009-2010 models the mostly affected GTi's? What preventative measures are there? Any warning signs to be weary of?
2012 VW Golf Mk6 GTi
NeoSA
Post by NeoSA »
Findings:
All MK6 GTi models are affected. From 2009 right through to 2013. Some people will argue that. Trust me. No year model is exempt. We heard a lot about 2009 models failing and some 2010 ones as well. The only reason why they started the trend was because they had the most mileage. It's logical. As time has moved on, we are now hearing about all of the later year models as well. As those models pick up mileage, we're going to see them fail more and more.
There is no preventative maintenance to do except replacing the timing chain tensioner with the latest version. That will cost you about R12,000. VW will not replace the timing chain tensioner under the maintenance plan unless it has already failed. I know because I asked them.
The best you can do is to make sure your oil levels are always optimal and never too low. Also listen to the car when starting it. If it makes a funny rattle like a bike chain slipping or it starts idling rough, or it struggles to start at all - take it to a dealer.
Best case scenario you get away with only replacing the chain and tensioner. Worst case, new engine.
If you plan to drive a MK6 GTi for longer than 5 years, you better save up and get the tensioner updated. Otherwise it's a very expensive game of Russian roulette.
TimeShifter
NeoSA wrote:Findings:
Thanks for the feedback bud! What was the average km that the tensioners failed? You scaring me a bit cause my car has a slight delay when starting and I can't remember if it's always been like that and perhaps is normal? I'll try compare with another GTi soon. Do you know from which revision is the less troublesome?
TimeShifter
NeoSA
Post by NeoSA »
Nah dude, don't worry about it. Kilometers don't seem to be the issue. It can literally happen at any time. I'm not sure what revision tensioner we are on now. I know that the latest tensioner didn't make it into the production engines though. Just look after your oil levels and enjoy the car. If it's going to happen, it will happen and it's not user error.
TimeShifter
NeoSA wrote:Nah dude, don't worry about it. Kilometers don't seem to be the issue. It can literally happen at any time. I'm not sure what revision tensioner we are on now. I know that the latest tensioner didn't make it into the production engines though. Just look after your oil levels and enjoy the car. If it's going to happen, it will happen and it's not user error.
Thanks bud! I'll be keeping a closer eye on the oil level from now on.
GB9
Post by GB9 »
VW called me today "asking permission" to strip the engine further to confirm the extent of the damage and whether I need a new engine entirely, or just a new head. I don't see why they need to do this, but if they think, or rather, if the Innovations Group think I will be paying for any of this, they've got a moerse fight on their hands.
NeoSA
Post by NeoSA »
But I thought you have an extended maintenance plan? When I bought my car I took it with the maintenance plan extension to 5 years / 90,000km.
The fact that they're "phoning you for permission" is a worry. I would ask them straight if they think you're going to personally pay for this. Rather clear any ambiguity ASAP.
rodga
Nazi Spelling Master
Registered for: 16 years 5 months
Car Model: MKVI GTI
Membership No: 1323
Post by rodga »
are these revised units guaranteed not to give these failures?
I havent heard of any happening with them, so just checking
rodga's ride
'09 Generic XOR 125 - matte black - Daily Driver :)
NeoSA
Post by NeoSA »
rodga wrote:are these revised units guaranteed not to give these failures?
The revised units (the latest one) is supposed to solve the reason why the old timing chain tensioner fails under low oil pressure.. That being said, be FLIPPEN careful who you get to install this timing chain tensioner. Some guys in the States have managed to perform this themselves (brave) with success, but others weren't so lucky.
Rant: what I find complete bulls#@t from VWSA is that they insist on charging you the full price (over R12,000) even if you're prepared to pay with your own money to fix THEIR stuff-up. If you ask me, they should be offering this procedure to MK6 GTI owners at a massively reduced price.
rodga
Car Model: MKVI GTI
Membership No: 1323
Post by rodga »
agreed, but by them reducing the price its basically admitting there is a fault, which should be covered under warranty....
rodga's ride
NeoSA
Post by NeoSA »
The whole warranty thing is a sham most of the time. They always try and find something to let them off the hook. But that's another topic. I love my MK6 GTi, but the whole tensioner issue has left a very bad taste in my mouth with VWSA. I doubt that I'll buy a VW again. I know BMW and Audi are not much better at this sort of thing, but still.
Balls
Registered for: 13 years 8 months
Membership No: 1708
Post by Balls »
Where did you get this price of R12000?
Also wasn't the revised tensioner fitted 2010ish+?
Balls
Membership No: 1708
Post by Balls »
This one?
ryanrich
Registered for: 18 years 5 months
Car Model: Territory
Post by ryanrich »
NeoSA wrote:The best you can do is to make sure your oil levels are always optimal and never too low. Also listen to the car when starting it. If it makes a funny rattle like a bike chain slipping or it starts idling rough, or it struggles to start at all - take it to a dealer.
I wouldn't count on that as a preventative measure. I drive my Audi until the oil warning comes on, at which point it needs a litre, which last 3000 km's before it comes on again. Currently on 93,000 km's and going strong.
Have no idea why Audi doesn't seem affected by this, or nearly as much anyway, since it's basically the same engine...
Glad I have the unlimited 2 year Motorite warranty when my freeway plan ends though, definitely something I don't wanna risk.
2016 Ford Territory TDCi Titanium AWD
2016 Kia Sportage Si
aslam
Car Model: MK6 GTi
Post by aslam »
I did mine Oct 2012
I paid R4272 parts and labour incl.
The following parts were bought.
Part numbers:
Old part number for tensioner was 06H 109 467 AB (12-12-11 and earlier)
New part number for tensioner is 06K 109 467 K (13-12-11 and later)
Old part number for cover: 06H 109 210Q
New part number for cover: 06K 109 210
Sealant needed for sealing cover: D 174 003 A2
