Golf 4 GTI-R wont rev past 5500 RPM
- Wheel Whore
Hi All,
I have pulling my hair out for this problem, besides all the money I had to spend with no luck!!
I have a 2004 GTI-R and she has 180K kms on it now already. The car used to run like a demon, but now it will not rev past 5500 rpm.
Whats has happend and what is still happening :
The problem just started out of the blue, one day it was fine the next it wasnt.??
1. Replaced the Divertor Valve. - Showed up on the error codes.
2. Replaced the PCV - Did not show any error but replaced anyways.
NO LUCK - still the same
3. Replaced the MAF sensor - No luck.
4. (The money Spinner) - replaced the entire turbo, plus oil feeder lines - No luck
5. Changed out the crank sensor, from a working GTI-R same model, no luck!!
Now I really need assistance! Please someone help.....
What next? I am at my wits end....
PS....we have checked the boost pipers for leaks ( i guess the best way we could removed and replaced)...
Help please.....
Any suggestions would be appreciated.
Regards
Fadeel - Tired and ready to strike a match!
Help please.....
Regards
- BongzThaMr_K
- Car Make: Polo
- Car Model: Vivo
Re: Golf 4 GTI-R wont rev past 5500 RPM
Get a diagnostics check done might be a fault in software or perhaps you'll pick up a problem there , goodluck
I'm argumentative, uncompromising and Emotionally-distant. Being with me's a war of attrition...
That's what winning the war gets you! *Remisces to my days in Vietnam*... *Sheds a Tear*
Previous Car: Toyota Tazz 160
Current Car: Polo Vivo 1.4 With Ridiculous Bass from the Boot
- Membership No: 2033
+1BongzThaMr_K wrote:Get a diagnostics check done might be a fault in software or perhaps you'll pick up a problem there , goodluck
This ....... before spending money by guessing what the problem could be.
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- Wheel Whore
Thanks for the responses so far....
Just to make it clear...I did the diagnostics and also had the car checked multiple time...on many occations the car car gave no errors...and as it stands right now...as far as computer id concerned there is no errors.
Get diagnostic check done and run some logs.
If you can install a temporary boost gauge to check your boost.
Check for leaking boost fittings. Any whistle sounds under boost.
Have you had plugs and fuel filter checked? Is your car pulling strong on lower revs and then just does not want to go further.
Have you checked the loud pedal? DBW pick accelorator input from here and it has a variable resistor switch / slide wire and this might be offset. Should pick this up on diagnostic log. Is idling low or where it should be?
- Wheel Whore
Awesome...thanks....I will check the loud pedal switch..and fitting a temp boost gauge.
Just to answer some of your questions...
We have checked the fuel pump even bypassed the cut out to see if it was the fuel pump. Checked the fuel filters as well. Same problem.
We had replaced the Coil packs some time before the problem started.
We also serviced the car, and replaced the cam belt and tensioners...no difference.
Will try your suggestions and revert back.
Are you doing all this yourself?
What error code is that?fadeel wrote: 1. Replaced the Divertor Valve. - Showed up on the error codes.
How did you check it?fadeel wrote: PS....we have checked the boost pipers for leaks ( i guess the best way we could removed and replaced)...
His: '05 WRX STi, '98 356 Speedster Rep, '76 Dodge D100, '79 Golf LS
- Wheel Whore
Hi,
1. Replaced the Divertor Valve. - Showed up on the error codes. - This I did myself
What error code is that? - I cant remember, but it said in the report to replace the DV.
PS....we have checked the boost pipers for leaks ( i guess the best way we could removed and replaced)... - This was done via a mechanic, and he said that the boost pipes were removed and checked and then I replaced one with a new one as it had a tear in it.
Any other suggestions?
- Killerwatt
- Car Make: AUDI
- Car Model: S3
It was probably the pressure drop between turbo and engine error. It tells you to replace the dv.
You should log the following:
Requested Boost
Actual Boost
N75 duty cycle
Airflow
Specified Load
Actual Load
Throttle body position
Requested Air Fuel Ratio
Actual Air fuel Ratio
Ignition timing angle
Timing delay on all cylinders
And also check fuel trims.
Check if any of the actual parameters do not meet the specified.
Is the car stock? If not then what mods do you have on there?
Also where are you located?
If you are unsure how to interpret the logs then you can email them to me and i will have a look.
Requested Boost
Actual Boost
N75 duty cycle
Airflow
Specified Load
Actual Load
- Wheel Whore
Hi Killerwatt,
Thanks for the reply, I am in Cape Town.
I will log the car and to get the logs again. The car is standard, the only mod (if you want to call it that) is a flat bmc filter.
I will get the logs asap.
The only way to check for a boost leak is to pressure test the system to 1bar with compressed air like so:
http://www.audizine.com/forum/showthrea ... eak-Tester
Then, start with WOT logging the following blocks using VAG-Com:
003+115+119
001+031+118
002+020+111
001+002+031
There's no point (except wasting money) in replacing things if you do not know 100% what's wrong, but I'm sure you realise that now.
003+115+119
001+031+118
002+020+111
001+002+031
- Wheel Whore
hi porno_ster
Thanks a million, I appreciate all the help. We will assemble a device like that and test again. I just sorcing someone to do the logging as well.
I will revert asap. I also agree that throwing good money after bad is just not on....
No problem, as Killerwatt said, we can help with deciphering the logs once you have them.fadeel wrote:hi porno_ster
- Car Model: Golf 7 R TTE535
Check that your TIP is not squeezing closed at those RPM's.
We have replaced a few stock TIP's on the 1.8T where the car would just not want to rev pass a certain RPM (Usually upper RPM band)
Replacing the TIP solved the issue.
Worth a try
Worth a try
Shaheen Moosa
- BMW X4 xDrive20d MSport Auto
- Tiguan 2.0TDI R Line 4 Motion Highline DSG
- Citi Golf CTi 1.8
- Golf Mk2 CSX 1.8
- BMW E46 325TI MSport 6 Speed
- BMW E30 325i MEX 1989 Diamond black metallic
- BMW E30 325i Shadowline Mtech2 Brilliant Red
- Citi Golf CTi 1.8
- Golf Mk2 CSX 1.8
- VELO-GP
- Car Model: MK4 GTi
- Membership No: 1870
test your fuel pressure, and check your throttle body - i (Tiaan) picked up this problem on my car
Jip, throttle body alignment is a must.VELO-GP wrote:...and check your throttle body - i (Tiaan) picked up this problem on my car
http://www.youtube.com/watch?v=2zrmhDw_v7Y
- Solo786
- Registered for: 17 years
- Car Make: Porsche,BMW,VW
- Membership No: 1251
I would also check the TIP is not collapsing under load.
If thats fine then check the FPR and perhaps the TB.
- Wheel Whore
Hi All,
Just an update, and once again thanks for all the feedback.
So after all the advise and too and fro, here is what was done and the car is still the same.
1. Did a diagnostic check and it came up with a few error.
2. Replaced the Divertor Valve. - Showed up on the error codes.
3. Replaced the turbo with the oem replacement part, as the boost pipes were soft during boost, and it was found that the turbo was cracked between the exhaust housing and the actuator.
4. Replaced the oil feed lines to the turbo.
5. Changed the MAF sensor
6. Checked the fuel filter and fuel pump, as well as the the fuel pressure.
7. Checked for Boost leaks - with a compressor and gauge.
8. Checked N75 Valve - the actuator is responding, so possibly not a boost problem.
9. Swapped out the crank sensor.
10. Had the car at a VW dealer, and here is the answer "We cannot find the problem"
SO - The car still wont rev past 5500rpm, and it is not like it hitting the limiter, it gets to 5500 rpm, and then everything just shuts off!
Any more suggestions would be appreciated.
All the macks in CPT know this car already!
Regards
Fadeel
Regards
Fadeel
- SemiColon
- I sparkle in the sunlight
- Car Make: Volvo
- Car Model: S40 T5
- Membership No: 1641
Are you sure its not a tdi?
- Sparkz0629
- Car Model: 2012 Polo GTI
- Membership No: 1768
LOLLLLL!!!!SemiColon wrote:Are you sure its not a tdi?
Current: 2012 Reflex Silver 6R Polo GTI
2006 1.9TDi Sportline - 158.7Hp & 413Nm at K.A.R 19-05-2012
VWicked wrote: I could do 300km/h if I wanted but I don't trust my brakes stopping from that speed so as soon as i hit exactly 241km/h on my garmin i will tap off, generally it takes me me 6.9 sec to get there so I will just cruise the last 5 sec's to allow the car to cool down..
- Sparkz0629
Did you try what Shaheen advised?
VVVVV
VVVVV
ETunersSA wrote:Check that your TIP is not squeezing closed at those RPM's.
Worth a try
Sparkz0629 wrote:Did you try what Shaheen advised?
VVVVV
Worth a try
Is it cutting out like a fuel or spark cut off or just hang on to the 5500 rpm's?
Longshot.......is exhaust not blocked?
Diagnostic check does not equal logs. Log it as I recommended and them come back with the info. If you keep on replacing stuff you are just wasting time and money and hoping for the best.fadeel wrote:Hi All,
Regards
Fadeel
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Do the stock k03 tips really get sucked closed though?
I thought this was just the k04 cars...
I can't see how this will happen on a stock GTI-R system...It most likely an electrical problem, i.e. ECU power cut, spark cut, etc.Killerwatt wrote:
