2006 Golf 5 GTI - misfire
Camo
Registered for: 12 years 2 months
Car Model: White-G5 GTi
Re: 2006 Golf 5 GTI - misfire
Post by Camo »
Sinbad wrote:I'm starting to see more misfires on my car as well. Will check the HPFP... m-plan ends in September ...
I have two HPFP's!
Mine gave kak last year and decided just to have spares on this thing. But I have MASTERED the Sensor part and know how to fix it. Also changing the Cam follower is a 15min jobbie!
Camo
Post by Camo »
Sinbad wrote:
Camo wrote:Any car needs 3-Things to function properly:
-Fuel
-Air
-Spark
That is your basic that you need to check when you have a misfire.
This much I know.
My misfire count tends to increase when I blip the throttle at idle. Given that at that point the rail pressure changes suddenly and quickly, the HPFP would be a logical place to look.
+1
Sinbad
Registered for: 16 years 5 months
Car Make: Mercedes
Car Model: R170 AMG Hairdryer
Membership No: 1152
Post by Sinbad »
Camo wrote:
+1
Doff question - is the problem obvious? What should I be looking for?
GV
Registered for: 17 years 10 months
Car Model: MK5 GTI (BWA)
Post by GV »
ruan9n wrote:PCV fine?
Mmmm - did'nt check.
GV
Post by GV »
Camo wrote:
The HPFP has two Sensors,..The one on the TOP normally gives kak! I see you made mention that the Thrust Sensor and the Cam follower have been changed.
Do you have a pic of the old cam Follower and can you take a pic of the HPFP to see if the TOP Sensor not Cracked!
Mine never gave EPC light until the crack was worse. The car had very bad misfire and thought it was coils.
When I went to Shaheen @ E-Tuners we found TOP Sensor on the HPFP cracked.
Can email you a pic - struggling to upload it here.
GV
Post by GV »
ruan9n wrote:When last was the cam follower changed? Is it 100% still?
cam follower also replaced, old one was fine.
Camo
Post by Camo »
No problem buddy
ctheron@merseta.org.za
Camo
Post by Camo »
This is what I mean by cracked sensor!
GV
Post by GV »
The idling seems ok now - however the misfire is still there under load now.
Registered for: 16 years 9 months
Post by ruan9n »
Km on the car? Have a look in carbon doctor's section on the forum. Have you changed the fuel filter?
GV
Post by GV »
ruan9n wrote:Km on the car? Have a look in carbon doctor's section on the forum. Have you changed the fuel filter?
99000KM - can't remember when last the fuel filter was changed
Shygolf
Registered for: 17 years 9 months
Car Model: MK5 GTI DSG BWA
Membership No: 1156
Post by Shygolf »
Do you have access to vagcom?
If you do log the following blocks
002 + 020 + 115
031+ 230 + 231
2012 Dec Mk6 GTI CW DSG - REVO Stage 1
Ex 2008 White Golf 5 Gti DSG REVO3 K04 - Weekend Toy
Regards
Hoosen
072 135 7861
GV
Post by GV »
Shygolf wrote:Do you have access to vagcom?
002 + 020 + 115
031+ 230 + 231
I don't :-(
but thanks!
Dale
Post by Dale »
Long story short in my case:
Logged low fuel rail pressure (Thanks MacMan), so replaced:
LPFP - in tank, side pressure sensor on HPFP and new fuel filter (the **** that comes out there :crazy: ), cam follower bucket.. Cleared logs after that, car was a bit more responsive but still bogged on WOT.
Upon closer inspection I saw that the plunger shaft was BAAAADLY worn ( about 1 mm :twisted: )
- will see if I can get pics upload of this. (my guess is this) Take off your HPFP again and inspect if its worn or not? I got a secondhand replacement one from Ruan (Thanks!)
Cleared logs again and no more issues. Unfortuneately this is a design flaw and a serviceable part from VW imho. Best to check this every 15000KM. Any wear on plunger, cambucket or follower will result in loss of performance guaranteed
Post some pics of what it looks like.
Dale
Post by Dale »
GV
Post by GV »
Dale wrote:Long story short in my case:
LPFP - in tank, side pressure sensor on HPFP and new fuel filter (the s**t that comes out there :crazy: ), cam follower bucket.. Cleared logs after that, car was a bit more responsive but still bogged on WOT.
seems like the problem I'm having now too - my car miss under load +- 2500RPM to 3000 RPM :-(
my car is currently also extremely heavy on fuel.
Uvy
Car Make: VW and Seat
Car Model: MK2 GTi 16V Golf
Membership No: 1740
Post by Uvy »
Dude.. Check your throttle body and your FPR
Heaven on Earth - VAG for life
GV
Post by GV »
Fanatix Boy wrote:Dude.. Check your throttle body and your FPR
Is this something I can do myself?
Uvy
Membership No: 1740
Post by Uvy »
best to get a mac to check it
GV
Post by GV »
@Dale - do you have part numbers please?
GV
Post by GV »
Had the fuel filter replaced and the car is MUCH better now - still not 100%. slight stutter now and then +- 2500 RMP
pologp
Car Model: G5 GTI
Post by pologp »
Mine had the same problem, changed thrust sensor and took out the lpfp and cleaned it and also used injector cleaner about 3 times and problem has gone. Try injector cleaner and see.
GV
Post by GV »
pologp wrote:Mine had the same problem, changed thrust sensor and took out the lpfp and cleaned it and also used injector cleaner about 3 times and problem has gone. Try injector cleaner and see.
Thanks will try.
M@rc!0
Post by M@rc!0 »
Camo wrote:
GV wrote:
Camo wrote: On top of your HPFP!
Normally when it is cracked it will misfire and also give EPC light!
your car will starve from fueling. I got a permanent fix for it if broken.
no EPC light.
is this not the same as the thrust sensor?
howzit, so whats the fix for the cracked top sensor?? im struggling with it now...replaced fuel rail sensor and thrust sensor only for the hpfp sensor to go now...bad misfire once i just touch the throttle
BdtDSG
Post by BdtDSG »
In my experience on my previous G5 Gti, first time it was PCV. Few years later same issue but was caused by fuel filter. Also, after an engine wash coilpacks can be the culprit, but not all 4 at once. Perhaps the person who logged it referred to cylinder 4 instead of all 4? Engine wash on those engines is not recommended, although I've never heard a dealership doing it...
