snapped cambelt
- Car Make: Seat
- Car Model: Ibiza Cupra
snapped cambelt
yup thats it .....F*#$%&g thing snapped
the motor just died there was no noise at all like as if something broke !.....
didnt sound like valves hit the pistons or anything .......
is there a decent quality cambelt i should be looking at getting if so
please which one ?
please which one ?
Current : Ibiza CUPRA 1.8T
2005 Citi 2l 8v *sold*
1983 Golf 1.6 *sold*
- Car Make: Seat
Re: snapped cambelt
PS....... the cambelt had probably done just under 1000Km
- Colonel
- Membership No: 1041
Re: snapped cambelt
hopefully you did not bend any valves, I normally get cam belts from Goldwagon. Set timing, fit new belt and turn motor over by hand if she turn over easy then try to start only. If she starts with a miss then you a compression tester to check in which cylinder the valves bent. Get a new tensioner as well maybe that seized up and caused the belt to snap
- Car Make: Seat
Re: snapped cambelt
thanks for the info ....... come to think of it the tensioner pulley did have a slight "squeek" to it
- Car Make: Jaguar
- Car Model: X-Type 2.2D
Re: snapped cambelt
Gates Powergrip. It's the OEM part for 8v VW engines, if memory serves.
Current: Jaguar X-type 2.2D
Ex: 2000 Citi 1.3
Ex: 2000 Citi 1.3
- Tdi jetta 4 ever
Re: snapped cambelt
Powergrip or Dayco otherwise oem, replace the tensioner if it have a squeek. Don't overtighten the tensioner. If you start and it runs uneven then you give it a couple of revs to get oil in the lifters again then it should run fine.
Robin
robinwisse@gmail.com
- Car Model: Golf MKVII TSi
Re: snapped cambelt
My CTi's tentioner came loose a few weeks ago(previous owner used a heli coil to keep the stud in). Car died. I wasn't so lucky. All 8 valves were bent.
Current :2014 - VW Golf 7 1.4TSi Comfortline
EX's
2009 - VW Golf 6 1.4TSi Comfortline
2006 - Audi A4 1.8T 1997 - VW Golf 3 GTS 1991 - VW Golf CTi
1997 - VW Golf Chico 1.6 1996 - VW Golf 3 GS 2004 - VW Golf 5 1.6 Comfortline
1997 - Isuzu 280DT LWB 1997 - Ford Bantam 1.3 1992 - Mazda 323 2.0I 16v
2003 - BMW 318I E46 1989 - Ford Sapphire 1.6 GL 1989 - Ford Sapphire 3.0 GLX
1976 - Audi 80 GLS
EX's
1976 - Audi 80 GLS
- Car Make: Seat
Re: snapped cambelt
Wow all 8 !!! ..... Then I was rather lucky ... I replaced the cambelt ... Put my standard cam in ... (Cause I'm selling my 272) .. And battled with timing a bit and drove it to work today .... .....
- Velofox
- Car Model: '94 FoxT 2.0 16v'
- Membership No: 1314
Re: snapped cambelt
you defiantly are...Mange wrote:Wow all 8 !!! ..... Then I was rather lucky ... I replaced the cambelt ... Put my standard cam in ... (Cause I'm selling my 272) .. And battled with timing a bit and drove it to work today .... .....
Current Rides
1994 2.0 16v FoxT - Lexy
1998 2.0 8v Mk3 GTI - Liesy
My Inspiration
16vT Engine Pics
My Inspiration
16vT Engine Pics
- Car Model: S3, Polo Playa,
Re: snapped cambelt
In your case you will bend all 8 because the belt still on and force the valve onto the piston, if a belt snap its very seldom bend valves, if it does it will only be 2 valve at the most, but also its only 8v motors, 16v and 20v you ****pjjdp wrote:My CTi's tentioner came loose a few weeks ago(previous owner used a heli coil to keep the stud in). Car died. I wasn't so lucky. All 8 valves were bent.
- Tander
- Car Make: Seat
- Car Model: Leon Cupra
- Membership No: 1713
Re: snapped cambelt
What would happen to my Polo if the belt snapped? Stuff motor?
Reason I ask is because I have just got the car and not sure when it was changed.
Is it expensive to get a new one on there as well?
2008 SEAT Leon Cupra - Banshee
Exes:
2006 Polo 9N3 - 1.6i
2003 Citi.com 1.3
2003 Opel Corsa Lite
- Tdi jetta 4 ever
Re: snapped cambelt
Lucky you. How did she start up?
Robin
- Car Make: Seat
Re: snapped cambelt
wel once all the timing and that was sorted .... alright hey ..... theres no knocking funny noise or smoke ....... any other signs i should be looking out for ????? perhaps its a slightly bent valve and im not noticing it ???
- Tdi jetta 4 ever
Re: snapped cambelt
Nhaa, everything is ok then.Mange wrote:wel once all the timing and that was sorted .... alright hey ..... theres no knocking funny noise or smoke ....... any other signs i should be looking out for ????? perhaps its a slightly bent valve and im not noticing it ???
Robin
Re: snapped cambelt
Guys my belt did not snap but the teeth was almost shaved smooth in places... How now... Do I just replace the belt and tensioner... Or do I take the top off and see if It bent some valves.... 1.6 polo playa 2001 afx help plzzzz
- Registered for: 8 years
Re: snapped cambelt
What UDC wrote still applies:
If the engine starts without a miss, consider yourself lucky and move on.UDC wrote:Set timing, fit new belt and turn motor over by hand if she turn over easy then try to start only. If she starts with a miss then you a compression tester to check in which cylinder the valves bent. Get a new tensioner as well maybe that seized up and caused the belt to snap
