Citi golf gear selection issues
Hi All,
Not sure if you recall I had clutch issues. The clutch replacement was done but I had endless issues with the mechanic. The issue now is - is that i still have gear selection problems(car on or off). We had a look at the release bearing about 2 weeks ago and the release bearing was busted in pieces and the pushing rod was black(like burned) on both sides. We replaced the releasing bearing and the pushing rod but still have gear selection problems. When i tap on the clutch pedal then there is a buzzing/rattling sound. Clutch peddle engagements are better but it randomly goes a bit stiffer. I have taken the car to two mechanics and they advised that the poor workmanship is the cause and the clutch replacement would need to be redone. They suspecting the pressure plate is bent. I had endless troubles and can right a 20 page essay on this...i just need your guys input. Should the clutch replacement be done again as I have spent over 7k so far on which should have been a 3k job or whatelse could be the cause. I dont feel like doing another clutch replacement then that that is not the cause.
Thanks.
Thanks.
- Colonel
- Membership No: 1041
Re: Citi golf gear selection issues
Citi golf gear selection problems are usually related to linkage alignment or linkage bushes worn out, are you having problems selecting gears or other gearbox/clutch issues
Crap bud, hope you get this sorted.
Unfortunately I can't really assist with this, but as mentioned by UDC it could be the linkage alignment or bushes. The bushes you can get from Gold Wagen for not to much if I recall this cost about R150 to R200...I think this should be a great place to start
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
You mention a buzzing sound when you press the clutch pedal in.
This is not a good sign.
Personally I feel that you need to chalk the money spent so far up to school fees and go get the car repaired at a reputable workshop.
Leaving this issue to get worse can and will cost you way more than you have already spent.
My experience with linkage bushes from GW is not good. The ones I got from the agents proved to be much more durable.
Mechanic number 1 said he did the linkage bushes. When i got the car back there was no play on the gear lever side. The positioning of the gear nob was solid. It is not solid anymore. There is a buzzing noise when i engage the clutch pedal. I really dont know where to start as another mechanic said we need to replace the clutch kit as it was not done correctly but what if its the gearbox. sigh sigh sighmissioner wrote:You mention a buzzing sound when you press the clutch pedal in.
- Registered for: 6 years
Re: Citi golf bootspoiler installation
Hi Guys
Can someone help me to install rubber boot spoiler on citi golf pleaese
- Colonel
if there is a noise when you press the clutch then it is releaser bearing related, you said the releaser bearing was busted previously.
Check the gearbox housing where the releaser bearing fits, maybe pieces of the old releaser bearing are still present or the housing for any damage or wear, also check the finger that presses against the releaser bearing for any wear or cracks
Banned for hijackcba741 wrote:Hi Guys
The buzzing noise you hear could be coming from the rod and the release bearing turning the whole time. If you look at a new pushrod, you will notice that the one side is well rounded shaped and fits 100% in the hollow surface in the release bearing. If you turn the shaft around, the other end on the shaft does not go all the way into the hollow part on the release bearing. That side should be at the pressure plate end pushing on the round plate. Wrong way round result in the shaft and release bearing turning the whole time. You will see wear on the rod where the rod sits in the brass bush behind the input shaft seal. Replace the shaft and release bearing and check the brass bush and seal.
Thank you. We replaced the release bearing when we did the inspection after the clutch replacement was done. The release bearing was busted. We also replaced the pushing rod with what the mechanic said a bit longer one which came out of his gearbox(fox/5speed). As soon as you tap on the clutch paddle you hear the buzzing noise. I still struggles a lot with the gear engagements. 1. do i go with another clutch replacement eventho the car is doing exactly the same i did before the replacement without the slipping. 2. could it be gearbox related. 3. could it be selectors etc? I dont want to do another clutch replacement to only find out that it could be something small or something big like replacing the gearbox
As I stated previously, as it seems to me that you have lost faith in the first mechanic (?), Go get a second opinion from another better mechanic (workshop). Most won't charge you for checking the car, but if they begin working it will cost you some money.my_citi1.8i wrote:Thank you. We replaced the release bearing when we did the inspection after the clutch replacement was done. The release bearing was busted. We also replaced the pushing rod with what the mechanic said a bit longer one which came out of his gearbox(fox/5speed). As soon as you tap on the clutch paddle you hear the buzzing noise. I still struggles a lot with the gear engagements. 1. do i go with another clutch replacement eventho the car is doing exactly the same i did before the replacement without the slipping. 2. could it be gearbox related. 3. could it be selectors etc? I dont want to do another clutch replacement to only find out that it could be something small or something big like replacing the gearbox
I recommend a MIOSA and/or RMI approved workshop this time. If their work is faulty they are obligated to fix it for free as per industry norms. You are going to have to count the money you've spent as a loss and get your car fixed properly. The longer you take to get it done the worse the damage is getting.
