Hi.
My friend wants to upgrade to a 276 cam but he asked me how to tell the difference between the standard cam, a 272 or the 276. I told him I wasn't sure so that's why I'm asking. Hes worried that maybe someone will say its a 276 when its actually not. Are there numbers on the cam to distinguish the difference in duration etc?
Thanks guys.
How to tell camshafts apart
- Ansell
- Registered for: 9 years 6 months
- Car Model: 1997 Golf 3
1997 Golf MK3 GSX (1.8 MP9)
Specs:
79.7kw at 5209rpm and 160nm at 4240rpm (Saichs Dyno)
Modifications:
Stock exhaust with one 50mm-57mm freeflow box.
Standard airbox
Standard cam
Ex: 1970 Beetle 1300 twin-port
If you don't look back at your car after you park it, then you own the wrong car.
Specs:
Modifications:
Standard airbox
Standard cam
- Car Make: Merc
- Car Model: C63 Edition 507
Re: How to tell camshafts apart
only way is to measure the lobes/lift - also some cams will have special markings which tell them apart
Polo 20VBigT - The Redhead
C63 507 Edition - The Dragon
Isuzu 4x4 - Little Joe
- Ansell
Ah I see, okay cool. Thanks. So if there are no markings then would I use a dial indicator?
Specs:
Modifications:
Standard airbox
Standard cam
Specs:
Modifications:
Standard airbox
Standard cam
You cannot measure a loose cam using a dial gauge. Can only be done on an engine where it is installed.
But all aftermarket cams will have a marking on the one end showing it's duaration. If not then walk away as you won't know.
To add to OP's question, Would you know if said cam is intended for hydraulic or solid lifter setup?panic-mechanic wrote:You cannot measure a loose cam using a dial gauge. Can only be done on an engine where it is installed.
- Ansell
Thanks Panic.
Specs:
Modifications:
Standard airbox
Standard cam
Specs:
Modifications:
Standard airbox
Standard cam
Aftermarket VW cams as Panic said has engraving on telling you the duration. Reputable cam suppliers put a "S" for solid lifter or "H" for hydraulic lifter cam behind the cam duration.Dale wrote:To add to OP's question, Would you know if said cam is intended for hydraulic or solid lifter setup?panic-mechanic wrote:You cannot measure a loose cam using a dial gauge. Can only be done on an engine where it is installed.
A solid lifter cam also has a larger base circle and lobes than a hydraulic cam.
- Ansell
Thanks PapJo, now ive learnt something new.
Specs:
Modifications:
Standard airbox
Standard cam
Specs:
Modifications:
Standard airbox
Standard cam
- Psycho8v
- Car Model: Citi Golf
- Membership No: 1881
