MK 1 brakes assistance PLEASE HELP
Jakkels85
Registered for: 10 years 9 months
Car Model: Mk1 2 door 16v turbo
Post by Jakkels85 »
HI Guy's
Could someone help help me i wanna know who did the brake booster delete and just used the master cylinder directly on to the pedal?
How hard is the pedal and any issues?
I am running a turbo setup but want to keep every thing nice and clean in the engine bay and still wanna stop when i have to.
Any suggestion?? :hi:
Shadows101Fall
Registered for: 8 years 10 months
Re: MK 1 brakes assistance PLEASE HELP
Post by Shadows101Fall »
People use the Beetle master cylinder for this mod, I've personally never driven a Golf with one fitted but to my understanding it stops just as well, but there's a much thinner line in pressure on the peddle between stopping safely and wheels locking up.
I buy broken/smashed/written off cars
Current: 2005 Alfa Romeo GT 1.9 JTDm
Ex: 2014 Nissan NP200 1.6i - meh.. Sold
Ex: 2000 Alfa Romeo GTV 3.0 Sold http://www.vwclub.co.za/forum/viewtopic ... 1&t=197077
Ex:1980 2 door mk1 build thread Sold http://www.vwclub.co.za/forum/viewtopic ... 1&t=192831
alfaquad
Registered for: 11 years 8 months
Car Make: VW Touareg V6 TDI
Car Model: Golf 2.0 8v Race Car
Post by alfaquad »
It's pretty simple to do. I run the master cylinder directly on the pedal in the race car - as do most other people who race them. You can get a spacer for the pedal from Norbrake in Boksburg, R300 odd. Then just have to have new brake lines made up and fit them. Doesn't take too long once you get going.
The pedal requires a fair bit more pressure applied to have the same braking force, but it's really not such a massive inconvenience. I run a standard Mk1 master cylinder on my car.
2007 Volkswagen Touareg 3.0 V6 TDI
1966 Austin Mini 1000 / 1958 Porsche 718 RSK Replica
VW Golf 2.0 8V Race Car
V6 Capri
Registered for: 12 years
Car Model: V6 Capri
Post by V6 Capri »
alfaquad wrote:The pedal requires a fair bit more pressure applied to have the same braking force, but it's really not such a massive inconvenience.
This ^^
I have this on my Escort. Pedal is very hard (when compared to normal vacuum assist), but you do get used to it after about 3 stops. Then you appreciate the vacuum assist when you drive a car with it again. Brake force is the same, pedal feel is just much harder than normal.
2016 VW Touran 1.6TDi
1971 Baywindow project
1964 Ford Anglia 997cc
1972 Ford Capri 3L GT
1994 Escort Cosworth (replica)
1996 Escort 2L Zetec
Shadows101Fall wrote:People use the Beetle master cylinder for this mod, I've personally never driven a Golf with one fitted but to my understanding it stops just as well, but there's a much thinner line in pressure on the peddle between stopping safely and wheels locking up.
You actually have a much better feel for the brakes and it's much easier to modulate it without locking up. Almost the whole of VW challenge ran that way and you get used to it in no time. Using a slightly bigger master than stock helps somewhat.
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker »
You can upgrade the front discs to 256 or 280mm to help off-set the extra pedal effort.
Current rides:
Hyundai - 1.4 Getz (daily)
Jakkels85
Post by Jakkels85 »
HI Guy's
Thanks a lot that answers most of my questions, I do have the vr6 disc in frond with stock calipers (vlokspares up grade kit) and the mk2 rear disc setup at the back of the car.I will also place 2 suppressors in the line on for each side to reduce the pressure to the back form locking up. I just wanted some more knowledge of the hard nest of the pedal but let me try this and see what happens.
Panic, I was wondering about that if i use a bigger master wouldn't it be a better option than regular one.
I a going to measure the distance between the two bolts and see if i cant get a bigger one that will fit directly on it as well with out making some major adjustments.
:hug:
Thanks a lot guy's will keep you posted.
EX-DOHCTOR
Membership No: 712
Post by EX-DOHCTOR »
Snip - see you're looking for a master cylinder so my option wont help.
