1.8 Cti overheating
1.8 Cti overheating
Hi Guys
I need some help please my car started to overheat and burst the top radiator hose the other day. O replaced the hose with the small hose that's going to the water bottle as well. I also replaced the water bottle with the switch .
I replaced the radiator switch on the side as well and fan is still not coming on I checked the fuses as well.if I short the switch with a screw driver then the fan comes on
Re: 1.8 Cti overheating
change your thermostat under the water pump. Remember you can't just take it out. You have to put another one back in. It closes off passaways when it opens.
Thanks Panic
Can it be the thermostat in the water pump
I checked the hoses and it's only the top hoses that's getting hot the bottom one is cold
- Car Make: VOLKSWAGEN
- Car Model: 2009 Citi Rox ABF
this is an indicator that the thermostat in the waterpump housing, is not opening. replace it.Barel005 wrote:Thanks Panic
..../._____________.\.....
../( )====VW====( )\..
.|\_________________/|.
.|_\_______________/_|.
'A Trend is For a Month, Style is Forever...'
**2009 AB-EFF'd citi Rox**
**Meet Nimbus----EURO PROJECT**...SOLD
**My 77' HONDA CB550 Project**
What was unclear about my post? that is exactly what I said, change the thermostat....
Hi
I changed the thermostat but the fan still not coming on
Anything else I can maybe check
I left the car to idle for about 15min the top hose got hot and the bottom one as well
Fan switch side of the radiator. can be faulty even though new
Thanks I have a spare Peugeot switch which they gave me as it's suppose to switch the fan on much faster
Will give it a try tomorrow and let you know
Thanks for the advice
The downside of that is that the fans work themselves to death.
Thanks very much for all your assistance Panic
I changed the switch on the fan and played around with the wires the fan is kicking in often now
Fully agree with Panic on his statement. Check what the Peugeot switch specs are. You will see they run much cooler than VW engines.
1977 Datsun 1200GX
Wife's car: 2019 Suzuki Ciaz
1977 Datsun 1200GX
