Page 1 of 2
2l 8v rebuild to aleast 110kw
Posted: Thu Jan 18, 2018 2:45 pm
by mike65
Howsit guys
Is their actually like a step by step guide on how to build a more or less 110kw 2l 8v motor?
Not that i dnt know how but would just like to see how other people get there.
Im planing on :
boring to 83.5mm
fitting branch and freeflow and
doing head work then maybe change to aftermarket management at a later stage.
Ive got pricing for pistons at R1380 with goetzee rings and bore costs about R860 rest of pricing will follow
Any input on a guide would be nice maybe i can learn new things
Re: 2l 8v rebuild to aleast 110kw
Posted: Thu Jan 18, 2018 2:47 pm
by billionairebum
Slap a 1.9 TDI 8v motor in there and klap a file = 110 to 120 kw.
Posted: Thu Jan 18, 2018 2:54 pm
by dazza
How much money do you have, that's gonna be key
Posted: Thu Jan 18, 2018 3:14 pm
by panic-mechanic
Bore (increase capacity), raise CR, head flow , long cam, branch and freeflow , throttles. That is the normal path.
If not enough , more valves, NOS, Turbo.
Posted: Thu Jan 18, 2018 4:15 pm
by supervly
I am looking at going a similar route - but its for a T3 syncro , I have a spare 2e motor which ran bearings .
I was looking at doing the 1.9 tdi crank and 2.3 caravelle pistons and potentially a mild cam
How far can one take the MP9 mapping? , currently I am using the short loom with mp9 polo cup 2.0 computer box
I don't want crazy top end power , just more bottom and mid range power - to help climbing hills without generating too much heat
Sorry for the hi jack mike
Posted: Thu Jan 18, 2018 4:20 pm
by mike65
supervly wrote:I am looking at going a similar route - but its for a T3 syncro , I have a spare 2e motor which ran bearings .
^this im leaving for my 16v built which will be in this year as money rolls in
^Im not sure how far but with uni q you should get enough for under 120kw id say?
^ no stress, enjoying the chat
Posted: Thu Jan 18, 2018 4:22 pm
by mike65
panic-mechanic wrote:Bore (increase capacity), raise CR, head flow , long cam, branch and freeflow , throttles. That is the normal path.
Today ive learned you get two 83.5mm pistons of which one is 63mm long and other one is shorter
Which one would suit the long block running standard crank and rods?
Posted: Thu Jan 18, 2018 4:24 pm
by mike65
dazza wrote:How much money do you have, that's gonna be key
Money is no issue, This will be my daily and mid range race car so as time goes on i will upgrade and build a 16v later on
by Neuk
Where is @BlueBlob, he is an expert at extracting power from an 8v.
Posted: Fri Jan 19, 2018 7:41 am
by dazza
mike65 wrote:dazza wrote:How much money do you have, that's gonna be key
If money is no issue why not go straight to 16V?
Posted: Fri Jan 19, 2018 7:53 am
by AlexTDi
You need about 25-30k, give Sarel Eloff from 8v performance a call but you basically need his stage 3 flowed head, high rev kit, bigger valves, Estas 288 or 298cam, his gatsby bottom end (2.1) 11:1 compression so either you run two maps or NF/higher octane fuel daily.
I did all this last year but didn't go 2.1 as I wasn't looking for 110kw and guess what I'm completing this weekend? a 2L 16v ABF build so if you really really really want a strong 8v then do that but a midly tuned 16v will do that power all day every day
Posted: Fri Jan 19, 2018 9:05 am
by mike65
dazza wrote:mike65 wrote:dazza wrote:How much money do you have, that's gonna be key
16v is in the year plan im buzy getting my parts ready and i only have one car so cant sit without it for long
Posted: Fri Jan 19, 2018 9:11 am
by mike65
AlexTDi wrote:You need about 25-30k, give Sarel Eloff from 8v performance a call but you basically need his stage 3 flowed head, high rev kit, bigger valves, Estas 288 or 298cam, his gatsby bottom end (2.1) 11:1 compression so either you run two maps or NF/higher octane fuel daily.
alot of the above mentioned i can do myself and would like a 90% diy job
the 8v i dont want to spend to much on it because i have to start from scratch with the 16v build,saving most of the cash for the next build...
110kw at the coast for an 8v is easy to get and its enough for a daily...16v im planing on atleast 130kw
Posted: Fri Jan 19, 2018 9:16 am
by AlexTDi
Ah you at the coast, yes much simpler then
Posted: Fri Jan 19, 2018 9:23 am
by ICE King
mike65 wrote:AlexTDi wrote:You need about 25-30k, give Sarel Eloff from 8v performance a call but you basically need his stage 3 flowed head, high rev kit, bigger valves, Estas 288 or 298cam, his gatsby bottom end (2.1) 11:1 compression so either you run two maps or NF/higher octane fuel daily.
Buy a 2l 8v , use MP9 if existing or go management , branch + exhaust , cam & induction and be happy with it while you build your 16 valve in the background.These mods are doing +-105kw ATF down here in CPT
No point going all out on a 8v when you could have a spend less money getting a stock 16v and making more power.
Unless the plan on only running quarter miles all day then the 8v is good enough, after 400m you'll watch a 16v pass you.
Posted: Fri Jan 19, 2018 9:24 am
by Mk1Crazee
Posted: Fri Jan 19, 2018 9:34 am
by mike65
@ ice king
I have a 2l agg motor that im doing over very soon my intentions are to bore do full head work branch freeflow and retune
Posted: Fri Jan 19, 2018 9:40 am
by WeirdSteam
mike65 wrote:@ ice king
Bore to 83.5mm (40 thou oversize) fit a nice 288 cam with flow and branch. And you are sorted.
Posted: Fri Jan 19, 2018 7:24 pm
by Unobeat
I soo miss Torker, where has he disappeared to.
He has such epic N/A builds.
Posted: Sat Jan 20, 2018 11:48 am
by supervly
Ya where is Torker - he did manage to pull epic power from 8v motors
Posted: Sat Jan 20, 2018 12:25 pm
by InquisitiveKid99
Hey guys, so i have a Polo 9n , ran a whole in the block and took the engine out, i do'nt want to buy the exact same engine i was thinking of buying a 2l 8valve APK .
What I'd like to know is :
1. will it be a straight fit
2. will i need to get another gearbox as well or will the standard 1.4 work
Posted: Sat Jan 20, 2018 12:36 pm
by InquisitiveKid99
hole*
Posted: Sun Jan 21, 2018 8:36 am
by missioner
InquisitiveKid99 wrote:Hey guys, so i have a Polo 9n , ran a whole in the block and took the engine out, i do'nt want to buy the exact same engine i was thinking of buying a 2l 8valve APK .
What is the original motor?
Posted: Sun Jan 21, 2018 3:15 pm
by vwpro
You can forget 110wkw on a na 8v motor, not possible with all the money you got. Only to achieve that figures is to do a dyno run on a happy dyno.
Speak to 8v performance, Sarel Ellof if reacable.
https://m.facebook.com/groups/171419086276082
Posted: Sun Jan 21, 2018 11:20 pm
by dubz-on-drugz
vwpro wrote:You can forget 110wkw on a na 8v motor, not possible with all the money you got. Only to achieve that figures is to do a dyno run on a happy dyno.
I think it's easier to make that power at the coast .many 8v's with itb on pump fuel making more then 110wkw.
