RWD Conversion
- Bratt
- Car Model: MK2 8V Golf
RWD Conversion
Hi Guys
I am looking for some information to find a Rear wheel drive gearbox or All wheel drive gearbox that would fit on a Golf 2 2L motor.
If anyone knows which boxes will fit with little modification please let me know.
I am in the process of building a custom chassis but would need the box so that I can make sure to build it right the first time.
- ALRoN73
Re: RWD Conversion
Fit a cressida box and have a bell housing made?
- Carel040
Re: RWD Conversion
No dude all wheel (4 wheel drive) not rear wheel drive
- Neuk
- Treasurer
- Membership No: 806
Re: RWD Conversion
Did you read what the OP asked?Carel040 wrote:No dude all wheel (4 wheel drive) not rear wheel drive
- ALRoN73
Re: RWD Conversion
"Rear wheel drive gearbox or All wheel drive gearbox"Carel040 wrote:No dude all wheel (4 wheel drive) not rear wheel drive
Read again please.
- Carel040
Re: RWD Conversion
Sorry bro as quoted Cressida 21R gearbox will be best suited for your application
Re: RWD Conversion
well how are you fitting the motor - transvere or longitudinal.
If you do RWD with a cressida box then speak to gilo engineering they have all kinds of adators and would have that most likely
http://www.giloeng.com/prodlist.htm
Re: RWD Conversion
Or if you looking for a AWD box, use a 2.7 Hi Lux box.
- amstel18
- Car Model: Tiguan Allspace
Re: RWD Conversion
Depends on what its going into.MrMazda wrote:Or if you looking for a AWD box, use a 2.7 Hi Lux box.
If its the Mk2 in the OP's signature, i'd think a Haldex setup from a 8L s3 would work perfect.
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
- Mk1Crazee
- Car Model: 1980 Mk1 4 Door 2L8V
Re: RWD Conversion
Haldex all the way
1989 VW Fox 1800 (Sold)
1985 Ford XR3 1600Sport (Restoration Sold)
2004 Mk1 Golf 1.4i Velo Motor (Sold)
1980 Mk1 Old School Golf 2L8V
Shallow Pockets. Backyard Builder
- jouberrd
- Car Model: Caddy Bakkie
Re: RWD Conversion
What?! 21R and a Hilux 2.7 box....Please don't!
First of all its a VW not a Toyota.
Secondly the ratios will be all wrong ,even on a 2E or ABF.
Go for a first gen. Haldex (TT or S3)
- ALRoN73
Re: RWD Conversion
Lol then it will be fwd with more weightjouberrd wrote:What?! 21R and a Hilux 2.7 box....Please don't!
- jouberrd
Re: RWD Conversion
Nope AWD! Quattro's the best!ALRoN73 wrote:Lol then it will be fwd with more weightjouberrd wrote:What?! 21R and a Hilux 2.7 box....Please don't!
- PoLonY
- Car Model: A8
- Membership No: 1997
Re: RWD Conversion
Nope!jouberrd wrote:Nope AWD! Quattro's the best!ALRoN73 wrote:Lol then it will be fwd with more weightjouberrd wrote:What?! 21R and a Hilux 2.7 box....Please don't!
Haldex is FWD until it detects slip then an amazing 30% gets sent to the rear
Wow such power transfer!
Such traction!
It’s not proper AWD
The longitudinal Motor Audi’s like my A8 have genuine AWD
- ALRoN73
Re: RWD Conversion
Nope AWD! Quattro's the best!PoLonY wrote:Nope!jouberrd wrote:Nope AWD! Quattro's the best!ALRoN73 wrote:Lol then it will be fwd with more weightjouberrd wrote:What?! 21R and a Hilux 2.7 box....Please don't!
Such traction!
It’s not proper AWD
- Bratt
Re: RWD Conversion
Hi Guy thanks for all the responses.
Sorry for the delayed reply have been busy with work.
I am not going to do the conversion in my current VW, this is a project car and would like to use the VW motor as I know it well.
I will be doing RWD as it will save some weight and space issues I am seeing with AWD.
I am currently only doing research on what would be best until I can start working on it again.
Regards
Regards
- jovann46
- Car Make: VW CADDY,SEAT CUPRA,RAZZO
- Car Model: 1989 Caddy 16v ABF. Razzo 1800
Re: RWD Conversion
Audi TT drive train might work?
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Re: RWD Conversion
That only applies for Gen2 haldex. Gen4 and Gen5 have electrical pump on them and send power to the rear before slip. From my logs it sends torque to the rear from standstill, any increase in engine load under part throttle and full throttle. Haldex clutches also recieve full clamping pressure when launch control is used.PoLonY wrote:
Nope!
Such traction!
It’s not proper AWD
But the clutches will slip if the propshaft torque goes over the clamping limit, think around
2000nm.
- ICE King
Re: RWD Conversion
Polony is correct regarding the GEN 1 HaldexKillerwatt wrote:That only applies for Gen2 haldex. Gen4 and Gen5 have electrical pump on them and send power to the rear before slip. From my logs it sends torque to the rear from standstill, any increase in engine load under part throttle and full throttle. Haldex clutches also recieve full clamping pressure when launch control is used.PoLonY wrote:
Nope!
Such traction!
It’s not proper AWD
But the clutches will slip if the prop shaft torque goes over the clamping limit, think around
2000nm.
See link for differences https://en.wikipedia.org/wiki/Haldex_Traction
Volkswagen does not have "proper" RWD system unfortunately - will have to look at another brand - Go Toyota or BMW - Theres plenty of parts around
- Bratt
Re: RWD Conversion
So reading about this Haldex AWD system is more of a computerized AWD which I would not go for in this project if I do decide on AWD I would go for something I can have static in at 50% rear and 50% front even when the car is swithed off.
I currently do drive a AWD Ford which is very good but the trans is to expensive and big.
I am thinking of the Toyota RWD as I know the size is not that big and might fit well.
I would also need to go a little bigger on the wheels for more grip as the power output is more that I first wanted as it is all going to 2 wheels.
Sent from my SM-A720F using Tapatalk
