Hwzit Guys
I have 2002 citi 1.4i
The car is completely dead. When I boost then the negative cell sparks like crazy & cables get hot.
When it does boost eventually the car start then die off when I let go off the gas ... there is a bad smell like something burning as well.
Ive recently replaced clutch , did major service including engine/radiator flush, after a week the car refused to start & temperature gauge was down I took the car in for diagnostics the cold start switch was at fault. Ive replaced it & bought a can Liqui Moli Throttle Body cleaner & cleaned the throttle body & map sensor.
Please assist ...
Citi Golf Start then switch off
- chucker02
- Car Model: Citi ADY
Re: Citi Golf Start then switch off
Next time you try and jumpstart it, feel if the alternator is not getting hot. It can be shorted on the inside
1971 VW beetle
1971 VW beetle
- Sean Trollope
- Car Make: VW. Hyundai.
- Car Model: Citi golf. Hyundai i10
Or your battery fried
Yup battery has a shorted cell most likely
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
Time for a new battery.
