Hi guys I just want some more info on the following I found on the forum.
"If you would like to test the coil:
When looking at the coil with the HT lead and the plug facing you:
left pin the positive, center pin the signal and the right pin negative
So connect power to the two outer pins, then a piece of wire from the HT pin to ground. When you pulse ground on the center pin you should get a spark."
Must I connect 12v on both the left and right pin?
Must the HT pin be grounded, or just near ground to see the spark jump?
Can the center pin just be tapped on the battery ground for a pulse?
If i understand this correct the spark should come from the HT pin?
How to test velociti coil?
- TemoMK1
- Car Model: Velociti 1.4i
Velociti 1.4i
