Good day.
I have a citi golf 1.4i.
The problem i have is when i start it when it is cold it idles but then cuts out. I have to do this several times before it idles without cutting out and idle a while longer before i drive due to it does not rev. I could start it whenever and drive directly now not anymore and have no clue what it could be. The timing is right aswell
It has never done this before. Please any advice will be helpfull.
2005 Citi golf 1.4i cuts out upon starting
Re: 2005 Citi golf 1.4i cuts out upon starting
Seems as if the car is starving for fuel when cold.. i would CHECK the 4pin water temp switch and map sensor..
Get somebody with a scantool to view a live data stream of coolant temp, intake air temp, manifold pressure at a cold start.. if any 1 of those readings seem incorrect then u can focus on that particular sensor... (the intake air temp sensor is built into the map sensor)
Normally on a cold start more fuel is added.
I always only noticed a failed water temp switch causing high idling - overfueling.. but i dont know exactly how the switch is made or how it works so im not too sure if it can cause underfueling at low temps, worth the check.
- ADZ
- Car Model: Mk2 GTI 16v
Sounds like the water temp switch has failed, those are the symptoms when you start it in the morning or when the motor is cold it idles but then cuts out as soon as you touch the throttle it dies, I've changed mine with the one from GW and its been working 100% ever since. Just check the color band on the temp switch your's should be blue replace it with the same one from GW
02' citi 2L 8v
04' Mk4 Jetta 2L
89' Mk2 1.8 16v GTi
72' Beetle 1600TP
Thank you very much will give it a try. Will keep you up to date. Thank you again
Got it sorted yet?
- Car Model: VW Golf Plus 1.4 BUD 2007
I had a Polo 1.6i 2002 , the coil had a crack on it which had similar symptoms , but does sound like a cold start water temp switch problem
Ex : Polo Vivo, Renault Clio 3 1.6, Renault Megane and Scenic 1.9dci, Renault Clio 3 1.4, Renault Clio 2 1.4, Peugeot 308, Mini Cooper R56 1.6, Polo Tdi 1.4, Jetta 5 2.0 Tsfi Sportline, Ford Focus 2.0a, Bmw 320d E46 f/l, Citi Golf Chico 1.6, Corsa 1.7d converted with Gsi 1.6 engine, BMW X5 3.0im, Bmw 328 E36,Opel Kadett Ts by Group N Opel team, Jetta Vr6, Bmw 316i E36, Astra 160ie, UNO Turbo by Rudi, Bmw 325i Turbo by Alpine, Golf Gti16v exec, Mazda 323 Egi, Bmw e30 318i f/l
