17 inch rims vs 15 inch rims
- Registered for: 8 years
Hello to all.Just wanted to know which of the two size rims will give you a better 400m time.
Sent from my E2303 using Tapatalk
- TDi4Life
Re: 17 inch rims vs 15 inch rims
For which car would this be
Sent from my SM-G900H using Tapatalk
- dubz-on-drugz
I'd say low profile 17z are the worst for the 400m ..much more grip with 15s
Sent from my SM-G920F
- TDi4Life
Re: RE: Re: 17 inch rims vs 15 inch rims
Truthdubz-on-drugz wrote:I'd say low profile 17z are the worst for the 400m ..much more grip with 15s
For a citigolf
I also meant using Street tyres
- Neuk
- Treasurer
- Membership No: 806
Assuming tyre width is the same, why would 15's give you more grip than 17's?dubz-on-drugz wrote:I'd say low profile 17z are the worst for the 400m ..much more grip with 15s
- dubz-on-drugz
This is just my thoughts on this .the increase in tyre wall size increases the level of grip .it will be nice to get clarity on this one
- Car Make: VW Golf 1
- Car Model: 2.0 h8 valve
195/50/15 Michelin Pilot Sport 3 will be right for Raveens application- 2.0 8v N/A
17" on the golf throws the gearing ratios off which a lot more damaging to a 400m time- unless its a turbo golf don't waste your time with 17's period.
Having had 17'' rims and tires on my golf, worst ever for racing!!! Have to say though it looked sexy as hell, I got lucky when our detailing legend on the forum Lawrence sold me his rims that were on the Polo he had.
- Membership No: 2033
Wat?dubz-on-drugz wrote:This is just my thoughts on this .the increase in tyre wall size increases the level of grip .
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- dubz-on-drugz
It will allow the tyre to flex more ?using the concept of slicks ?
Sent from my GT-I9195 using Tapatalk
- Neuk
- Treasurer
I see where you are going with the side wall flex but running a 50 profile, even on a 205 tyre, isn't a high side wall at all and I wouldn't think it would flex anywhere near as much as a drag radial would.
- DotDubb
- Can I buy your wheels?
- Registered for: 15 years
- Car Make: Audi A6 3.0T
- Car Model: DKW, Cabrio, A6 avant,Mk2
- Membership No: 1593
I recently had 17's on my citi golf(2.1 16v N/A) and changed over to 15's.
The 17's does have better launch, but does not accelerate fast.
The 15's is perfect for a N/A car, it drives better, accelerate faster, but you do have to launch softer(I just feather it in 1st and 2nd gear)
I can't go smaller that 15's(big brakes), but even for drags(semi slicks) and my gear ratios, the 15's is the answer.
1991 Golf Mk2 1.8 20vT
1960 Autounion DKW 1000s
