Mk1 Golf 1.6, Keihin Carb - won't start.
Yesterday drove round all morning. Car stood outside for about an hour - then would not start! Battery good, turned over fine, there was fuel, no spark. Took out the trusty meter, checked voltages on coil and Hall sender - OK. Put plugs back - car starts!
Went to local supermarket, spent about and hour and a half inside, car starts OK. Go to garage (about 100m away), put in petrol - car won't start!
Test meter again - 12V across coil, 12V across Hall sender, no 5V while turning over - Aha!
Buy new dizzy. Car starts, ride home.
This morning, car starts fine, drive about 3Ks, switch off, car starts fine. Drive about 10ks, park outside my house, inside for about and hour, car won't start.
No spark - Now I'm cross!
Call local mechanic, who unearths an ignition module from under the dash - replace. Still won't start - no spark.
Mechanic shakes his head - Mumble, mumble.
Looks under dash, finds black box - Aha! Must be immobiliser problem - thanks a lot, bye.
Turns out black box is Sanji ZX70 alarm only unit (disabled).
If I had hair, I would be tearing it out.
Any ideas, chaps?
Any ideas, chaps?
- Neuk
- Treasurer
- Membership No: 806
Re: Mk1 Golf 1.6, Keihin Carb - won't start.
An hour and a half at the supermarket, has your boyfriend/husband had a look at the car?
Online
- Car Make: Ford
- Car Model: Focus ST
That's just nasty - I was repairing a computer, chaps!
Anyway - this morning, the damn car starts! Does anyone know of a problem which can affect the ignition circuit by the ambient temperature?
- Nextech
- Registered for: 15 years
- Car Make: VDub
- Car Model: citi 1.4 carb
Fantastic replies.
How were you testing to see if there is spark? Did you replace the rotor? When the car runs does it run smooth?
Are you sure that there was fuel? U_flow carb motors suffer from fuel evaporation in the float bowl when hot and standing. Just a thought
2006 Citi 1.4 carb (Under Construction)
1983 Bmw 323i AUTO (Under Reconstuction)
- Neuk
- Treasurer
At least you have a sense of humor...unixhed wrote:That's just nasty - I was repairing a computer, chaps!
It is strange that the issue comes and goes, I would start with checking all your contact/connection points. Perhaps you have a bad earth somewhere...
- Car Model: CitiGolf 2.0 8V
I had the exact same problem with my golf, same setup, but in my case it turned out to be the immobiliser. was a autowatch unit from 1997. I bypassed the unit, took it out, problem solved
- Registered for: 20 years
- Car Model: Caddy Club, Mk2 GTi 16V
- Membership No: 1040
Have you perhaps checked the coil?
I also had a similar problem with my caddy. Turned out to be a crack on the coil unit.
Replaced it and it has been fine ever since.
Membership No: 1040
His Daily: 2007 Caddy Club 1.6
His Toy : 1989 Mk2 GTi 16V Exec
Hers: Mk7 GTI DSG
2009 Golf Vi TSi Comfortline
2001 Golf IV 2.0 Highline (Too Heavy Too Slow) rear ended and written off
2002 Citi Life 16.338sec @ 141.18kmh (Wesbank)---- donated to RDP
1991 Cli 2.0 16V Exec - Gotech Management System
2001 Polo Classic 1.6 - 180kmh at Gerotek 2008
Hers: Mk7 GTI DSG
Hi guys I have the same problem mk1 13 curb is changed the plugs through oil in drive so 10k parking in the yard for so a hour drive again for so 30min and the damn thing just die under my feet no warning signs just died can sum1 tel me what's wrong mbe cause on my car everything is new but just won't start
- Car Make: SEAT
I'd check:
a) Earth strap and battery terminal connections;
b) HT leads (esp from coil to dizzy);
c) the coil itself
c) the coil itself
- dazza
- Car Make: VW and VW
- Membership No: 1327
If the HT leads are original I would look at replacing those, may just be intermittent issues with leads that are poked
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
- Neuk
- Treasurer
Just check which HT leads you can get I replaced the ones on my MkI but Goldwagen only had the newer type so I had to replace the distributor cap which no longer fitted the coil lead so I had to replace that as well.dazza wrote:If the HT leads are original I would look at replacing those, may just be intermittent issues with leads that are poked
