Vw 2E/ADY/AGG/ABA decisions decisions, which 1 do I buy?
- Car Model: Mk2 Gti crossflow 8v
Re: Vw 2E/ADY/AGG/ABA decisions decisions, which 1 do I buy?
Thanx Viper for the informative response.
However my car won't be standard for long few months down the line I'll have a cam + headjob + exhaust. I'm sure it will do for now in future I'll go for single dowel clutch and see the difference.
Regards
Gershy
Regards
Gershy
- Car Make: SEAT
- Car Model: Golf MK1
Where will you be getting a 282? is it going to be specially machined to that deg for you?The Gti Guy wrote:Hey Guys
Update!!!!
Bought me a double dowel SACHS clutch kit today, what's the difference between double dowel and single dowel? Also bought new inner cv's, bush kit to set the linkages. Car will go in Monday for this, my inners have started screaming really loud lately. I bought the clutch kit for R1045 at Goldwagen Claremont and the salesman was really interested in my car since I told him what I did to it. He drives a mk1 1.6 8valve with a 276 *** cam since Goldwagen is selling *** cams his now trying to persuaded me to get a ***. Now there is no ways I'm doing that I'm sticking to my original idea of estas 282 already contacted Nellis about this hopefully I'll have it next month. Apparently his car goes nice with the *** but I'll not leave anything to chance I'll make a wise investment in the estas.
Regards
Gershy
16v
'05 velocity ABF
'95 cti
'05 velocity ABF
'95 cti
Duncan
No Sportscam has stock of the 282. Its the estas hopefully end of next month I'll get it.
Regards
Gershy
Regards
Gershy
- Car Make: SEAT
BTW how much are you paying? I got a new a new billet at Supercams for R1300.00The Gti Guy wrote:Duncan
Regards
Gershy
16v
'05 velocity ABF
'95 cti
'05 velocity ABF
'95 cti
Duncan
Where is supercams? Its slightly more expensive but not by much. What degree cam did u get? Do u have an Abf and Ady now?
On another installed a SACHS double dowel clutch today my car drives like a dream is all ima say.
Regards
Gershy
Regards
Gershy
- Car Make: SEAT
Speaking in the past tense back in the 8v days.... They situated in stikland, down by the Sasol off Labelle rd.
16v
'05 velocity ABF
'95 cti
'05 velocity ABF
'95 cti
Duncan
Are u sure its Supercams and not Sportscam? I got a quote from sportscam they are agents for Estas Billets.
Regards
Gershy
Regards
Gershy
- Car Make: SEAT
Yip Supercams it was!
Did you get the cam you wanted?
16v
'05 velocity ABF
'95 cti
'05 velocity ABF
'95 cti
Duncan
No I didn't there is lots of stuff I had to replace since the conversion, clutch, cv's, battery, gearlever was messed (struggled to get 5th), starter, accelarator cable. So my pockets is still reeling now.Will get it once my pockets are filling up again lol
Regards
Gershy
Regards
Gershy
Hi, Guys
Here I am again, seeking advice lol
So last night I discovered that my car is leaking petrol after doing an inspection since it started smelling like fuel. It leaks underneath the car just behind the driver seat. I know its the fuel pipes running from the pump. Question is how do I fix this? There is 2 pipes below my induction system also leaking petrol. I do know how to fix that atleast. Advice needed plz with
Regards
Gershy
Regards
Gershy
- Car Make: SEAT
Best bet is to replace the lines, couldve got hurt somehow.The Gti Guy wrote:Hi, Guys
Regards
Gershy
16v
'05 velocity ABF
'95 cti
'05 velocity ABF
'95 cti
Duncan
Thanx for the advice pal, I agree. I will try to knock this jobbie off tomorrow. Phoned around for this today won't set me back a lot thank goodness lol.
Question for you. Was your 8valve modified? If so, how does it compare to the Abf?
Can you also tell me what parts u had to buy when u went from Ady to Abf plz.
Regards
Gershy
Regards
Gershy
- THANAS
- Forum Advertiser
- Car Model: AW Polo GTi
- Membership No: 2035
The engineThe Gti Guy wrote:Duncan
Regards
Gershy
Sent via Hedwig
- Car Make: SEAT
Just the head had minor work, port & polish + 276 cam i think it had bigger valves not sure, will have to hunt down invoices to tell you what size. You can't compare the 2, totally different leagues. I bought absolutely nothing, car was FI so it was just drop in and start. Had to buy management and a 16v branch then changed the exhaust from 57-63.The Gti Guy wrote:Duncan
Regards
Gershy
16v
'05 velocity ABF
'95 cti
'05 velocity ABF
'95 cti
Duncan
So let's say I get an abf then I'll just need a 16v branch, I'm on management already.
Would that be the only part?
Regards
Gershy
Regards
Gershy
Duncan
Do u have a progressive 57-63mm or straight through 63mm?
Regards
Gershy
Regards
Gershy
- Barney
- Car Model: Mk3.5 Cabrio
- Membership No: 1723
at times i miss my 2.0 8v with 282.
only problem here unless you go throttles and big work you get decent power. but if you want reliable decent on fuel . cam piggy exhaust are what will give you best bang for buck
Barney
What was your mods with the 282? What power did u make?
Regards
Gershy
Regards
Gershy
- Barney
estats 282 perfect power branch and a exhaust which then realised what teh problem when i went 20v.
made 100hp atw.
100hp in a citi shell is still plenty
made 100hp atw.
Barney
What was the problem? Did u go 1.8 or 2.0 20 valve?
What was done to ur head?
Btw I fixed the leak today.
Regards
Gershy
Regards
Gershy
- Barney
i want 1.8 20vt AUQ 132kw full oem
head was stock
head was stock
- Car Make: SEAT
Split exhaust, 53-63mm. Yip that's all you will need to jump to 16v.The Gti Guy wrote:Duncan
Regards
Gershy
100hp? how much would that be in kw? I get k@k confused, dont know how to convert. Down in CPT people speak about KW only.Barney1212 wrote:estats 282 perfect power branch and a exhaust which then realised what teh problem when i went 20v.
made 100hp atw.
16v
'05 velocity ABF
'95 cti
'05 velocity ABF
'95 cti
- Barney
Guys
Supaquick is having a sale with their Stainless Steel free flow exhausts for R999 would this be a good investment and on par with what a powerflow exhaust would give me?
Regards
Gershy
Regards
Gershy
- Barney
got one from there. all i can say is it sounded good but the bends fok me. unless they mandrel bent dont
