1.4i to 2.0 conversion - is it that simple?
- Car Make: VW, BMW, Nissan and Landrover
- Car Model: Citi, E46, Champ, Discovery
Re: 1.4i to 2.0 conversion - is it that simple?
Learning so much, taking notes
Will get the engine, service parts, clutch and flywheel then also adapter for the 1.4i's distributor
2005 Citi 1.4i (2.0ADY sleeper going 20v)
2001 E46 320D BMW
2002 Nissan Champ 149kw vvl
2004 Honda VFR Vtec
2003 BMW 650 Dakar
2001 E46 320D BMW
2004 Honda VFR Vtec
2003 BMW 650 Dakar
- chucker02
- Car Model: Citi ADY
haha i learned the hard way about that 1800 clutch. had to remove the gearbox when engine was in the car to remove the 2L clutch only to find the splines are bigger than the 1800 clutch, wish i knew that sooner.
1971 VW beetle
1971 VW beetle
- CRASH_IT
- Car Model: 8P S3
- Membership No: 1540
Why buy a 210mm flywheel then put the 1.4 clutch in. JustG-Spot wrote:I also think the 1.4 clutch will be fine, Just get the 210mm flywheel .IronG wrote:So no extra parts needed for my 1.4i to 2.0i?
Are you in capetown?
You need a 210mm flywheel and clutch kit.
The things listed here is all you need for the transplant.
Engine - 2E/ADY/AGG
210mm clutch
210mm flywheel
Service kit (cambelt, tentioner, oil, oil filter, fuel fiter, air filter)
Oil seals - Replace the crank, cam, secondary pulley, gearbox side crank seals to. just to be sure no oil leaks after installing.
Dizzy - Use either methods explained.
Map ECU to 2.0
Swop over all bits from 1.4 like pulleys, alternator, temp sensor, map sensor (I would swop entire intake and injectors, just easier)etc
CURRENT RIDE
2013 VW transporter 2.0TDI
2007 Audi S3
EX
- 2014 Ford Fiesta ST
2007 Audi S3
EX
Thanks for the wishlist.
Yes, that was a bit of a mistake made by my part...
Going to go to Goldwagen tomorrow to get the parts.
Mechanic friend told me I must ask for a 1800Flywheel and a 1800 clutch that goes with it.
Also he says I must get the two dowl clutch kit, while the sales person said I must get the single bell clutch kit and pressure plate (R950)
Also buying a headset as it comes with all the seals (so I've been told)
Have patience, I'm still learning
2001 E46 320D BMW
2004 Honda VFR Vtec
2003 BMW 650 Dakar
2001 E46 320D BMW
2004 Honda VFR Vtec
2003 BMW 650 Dakar
- General
- Car Model: Golf GT
- Membership No: 1464
It doesn't matter if you get single or double dowel, just make sure the flywheel and clutch kit is the same...IronG wrote:Thanks for the wishlist.
Current rides:
Hyundai - 1.4 Getz (daily)
- CRASH_IT
- Car Model: 8P S3
Head set doesnt come with both the crank seals and secondary shaft seal.
Only seal you will use out the kit is a cam seal and if you swop tappet covers for oem look.
CURRENT RIDE
2007 Audi S3
EX
2007 Audi S3
EX
- RyanJacobs
- Car Model: 1998 MK1
ironG I fitted my 2.0 ADY 2 weeks ago, bought it at Mikes Place in Epping, I am not sorry at all! Also the jump between the 1.4 to the 2.0 will be worth it, swap all your 1.4i bits, and do what Crash_it said with regards to servicing and you will be sorted.
All the best with your build!
M0nk3Y
Own: 1998 MK1 1800 8v MP9
- CRASH_IT
- Car Model: 8P S3
I heard the 2.0 8v motors prices have shot through the roof in recent.
CURRENT RIDE
2007 Audi S3
EX
2007 Audi S3
EX
- M3THANOL
- Blue Bomber
- Car Model: Golf Mk2...now....2.0L 8V AGG
- Membership No: 1822
when I bought mine last year in November it cost R5000, so not bad at all, but I think they will go up quickly due to them being in high demand, just like the ABF's got expensive fast!!
I'm literally can't evening!
http://www.iamsecond.com/
Current: The Blue Bomber
http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=151592
1/4 mile: 16.5s @ 133km/h (ODI-2013/10/27)
1km: 165km/h (ODI-2013/10/27)
- CRASH_IT
- Car Model: 8P S3
I was told over weekend they have shot up to R8000.
Thats what I paid for my ABF. And ABF's are +- R15000
Ill keep my ABF for few more years and will be worth more than value of my car soon. lol
Who says cars are bad investments!!
CURRENT RIDE
2007 Audi S3
EX
2007 Audi S3
EX
- General
Jeez, a couple of years back you could get them (8V) for R2950CRASH_IT wrote:I was told over weekend they have shot up to R8000.
Current rides:
When I first heard of the 2.0 conversion in '09 they were R3500!
Gave Mike's a call yesterday, they have about 100 ADY engines in stock at R5500.
OK, I thought I had my list of parts sorted out, but then CRASH enlightened me again.
So here is my final (hopefully) list:
2.0 ADY engine
1800 210mm double bell sachs clutch and flywheel
Cambelt
2E headset (I am swapping tappet covers to keep it standard looking)
both the crank seals and secondary shaft seal - Can I just say 2E Both crank seals and secondary shaft seal to the sales person?
Service parts was not included in this list as I'll just get it from Midas ; Same for ECU- got a contact to get the 2.0 polo ECU)
Hopefully tomorrow morning I will be completely sure about ALL the needed parts
2.0 ADY engine
Cambelt
2001 E46 320D BMW
2004 Honda VFR Vtec
2003 BMW 650 Dakar
2001 E46 320D BMW
2004 Honda VFR Vtec
2003 BMW 650 Dakar
- goose763
- Car Model: Citi 1.6
Sorry for the jack but im also going to do the 2l swap for the first time on my own and so far ive gathered lots of info from this thread.
My question, when converting from a 1.6 carb to 2l motor is the adapter ring required for the dizzy i.e. can i fit the 1.6 dizzy directly onto the ady motor? Ill be using the carb for now because of my limited budget.
2000 Citi Golf 1.6
ex rides:
'97 mk3 golf 1.6i GS
'99 Citi Golf 1.6
'97 Citi Chico 2l 8v
'99 Citi Sonic 2l 8v (73kw/164nm-atw)
Honda CBR400RR
Honda VFR400R
Suzuki RG125F
ex rides:
'99 Citi Golf 1.6
Honda CBR400RR
Honda VFR400R
Suzuki RG125F
- CRASH_IT
- Car Model: 8P S3
All the VW 8v and 16v motors have same crank seals and secondary seals.IronG wrote:both the crank seals and secondary shaft seal - Can I just say 2E Both crank seals and secondary shaft seal to the sales person?:
CURRENT RIDE
2007 Audi S3
EX
2007 Audi S3
EX
- RyanJacobs
Well I paid R6000.00 for my engine at Mikes Place, the ones for R5500.00 don't look in good shape, just my opinion.
And for the 2.0 Engine you need a 4 window dizzy, if I am not mistaken
M0nk3Y
- zain_c
DAFUQ??!!RyanJacobs wrote:Well I paid R6000.00 for my engine at Mikes Place
I did an engine conversion in mid 2011, bought a AGG motor from them and paid R4200. Moerse jump in price since then.
1400 to 2.0 is awesome...had tons of fun on trackdays and drags. My car was nice and quick. Chowed them Runx RSi, 20v's, vtecs whether it was B16 or B20 like chips. Even some force induction cars fell victim. Miss that torque, and zero traction.
2010 Honda Accord K24
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
04 Citi 14.7 s2s Killarney
06 MK5 Golf
92 MK2 2.0 16v GTi Exec
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
- chucker02
Goose you need the adaptor ring for the dizzy on the 2E engine
1971 VW beetle
1971 VW beetle
I bought my 2.0 ADY engine today from Mike's Place for R5500, in a very good condition as well.
But I had spoken with both Daniel and Sox before I heard of Gino from my mechanic.
He gave me a top quality engine and even checked the water pipe and swapped the breather hoses.
So I would recommend anyone to work through him.
Also got the 1800 9pin double bell (spelling...) Flywheel and 1800 Sachs clutch that goes with it.
Some engine cleaner and a head set (swapping over the 1.4 tappet cover).
Going to start stripping the engine tomorrow as I have some other work to finish tonight
If someone will give me an idea of how to upload pics I can do that as well?
2001 E46 320D BMW
2004 Honda VFR Vtec
2003 BMW 650 Dakar
2001 E46 320D BMW
2004 Honda VFR Vtec
2003 BMW 650 Dakar
- Goldwagen Delarey
- Car Model: GOLF 1 1870cc 8v ethanol
- Membership No: 1800
Ok go for the 210mm singel dell flyweel setup. The presure plate are stronger than the double once. You can buy the adaptor for the distributor from us. You will also need extra flyweel bolts.
Wikus Dippenaar
Goldwagen Delarey
011 477 9979
Sent from my Samsung S3
Wikus Dippenaar
Goldwagen Delarey
011 477 9979
OK, time for a update.
Viper, you were correct about those flywheel bolts, 3 of them at R36 made me interrupt my build with almost a hour to fetch them .
But it was quite simple and I have now got a 2.0 Golf that looks like an old lady 1.4i car.
I went to Kuilsrivier with a friend of mine to go view some cars and this guy in a bubble shape 1.8 Toyota comes with the music blasting and 2 of his friends in the car and just starts revving it up for a robot to robot dice and I thought cool, my 1st dice.
I smoked him for 500m (not going past 5500rpm as I have standard everything, small pipes and even a non cut airbox).
When we stopped at the 2nd robot he was shocked "Is djy seker dis 'n veertien honderd??" I smiled and smoked him again , after that he went onto the N1.
You do really feel the difference in torque from the 1.4 to 2.0
2001 E46 320D BMW
2004 Honda VFR Vtec
2003 BMW 650 Dakar
2001 E46 320D BMW
2004 Honda VFR Vtec
2003 BMW 650 Dakar
- M3THANOL
- Blue Bomber
naaaas bru, enjoy it
- CRASH_IT
- Car Model: 8P S3
enjoy it.
CURRENT RIDE
2007 Audi S3
EX
2007 Audi S3
EX
- Car Model: Citi Golf 1.4i
I'm also looking at doing this conversion is a few months time before he end of the year and this post has been so help full thanks!!!!!!!!
i have one question I'm in vanderbijlpark and i have gotten quotes from engine den and engines for Africa and the cheapest i got is R5950 for the engine is ther a place to get it a bit cheaper or better that the 2 places listed????
- CRASH_IT
- Car Model: 8P S3
Engine prices for 2l 8v have gone up alot lately.
CURRENT RIDE
2007 Audi S3
EX
2007 Audi S3
EX
- Barney
- Car Model: Mk3.5 Cabrio
- Membership No: 1723
well my motor might be going up if i am going to do my motor convert... probably full hanress with standalone management (xms4) and 282 cam
