need to adjust my caddy handbrake, can I please have a DIY as it is pulling up way to far
caddy handbrake
- Car Model: Caddy AGG 2L Carb
caddy handbrake
Caddy Club AGG 2L Carb 1998 model
- Car Make: VW, Ford
- Car Model: MK1 2door,Caddy,Bantam
Re: caddy handbrake
Its quite easy, if its a case of just adjusting, then you can do it by tightening the 2 bolts underneath the handbrake lever.
But it could be that the handbrake cables are stretched, or you're back brake lining is wearing thin , there is self adjusters at the back that is suppose to keep the right tension on the handbrake.
Hope this helps.....
Aaaand remember kids, Google is you're friend....
vee double you and me,I know I'm driving quality!!
Re: caddy handbrake
thanks for the reply
For now I would start with handbrake adjustment first and take it from there, what I need to know is do I just do adjustment by screwing those 2 nuts by the handbrake lever or how?
- amstel18
- Car Model: Tiguan Allspace
Re: caddy handbrake
Correct. Each side has 2 nuts. the front nut is just to lock hte 2nd one into place. You loosen both from each other to break the lock and then just screw the back one to increase tension on the cable. do this on a flat surface otherwise you may be rolling somewhere. Pull up lever to check tension. If happy then use to spanners to lock the two nuts tight.caddy club wrote:thanks for the reply
Bobs your aunty.
If this doesn't work, then as mentioned, either the cables are wrong, strenched or the drums need replacing
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
Re: caddy handbrake
oh that's a good one thanks at least I have a lekker DIY for the weekend, sounds pretty easy
