weird problem
- Kingshill1@
weird problem
ok i have this weird problem my oil level light coming on but oil is fine also no oil water and all that stuff no white stuff in oil ect.... funny thing is as soon touch the oil pressure sensor wire black then it goes away as soon start car again this happen every week coming to fridy which is blere weird. any ideas? as i know oil leve sensor is in bottom and oil pressure sensor is in block.
polo 1.9tdi 2006 model
- Neuk
- Treasurer
- Membership No: 806
Re: weird problem
It sounds like a sensor issue.
- Membership No: 2033
Re: weird problem
Break in the wire?Kingshill1@ wrote:ok i have this weird problem my oil level light coming on but oil is fine also no oil water and all that stuff no white stuff in oil ect.... funny thing is as soon touch the oil pressure sensor wire black then it goes away as soon start car again this happen every week coming to fridy which is blere weird. any ideas? as i know oil leve sensor is in bottom and oil pressure sensor is in block.
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
Re: weird problem
HOWIE-WP,
- Kingshill1@
Re: weird problem
replaced the sensor already. how can i test if there is a break in wire maybe somewhere.? its just funny that after touch the wire it goes away
- Kingshill1@
Re: weird problem
is the oil level sensor and pressure sensor wires interlinkee? because it's weird oil level comes on and not the pressure light which if i touch the pressure sensor wire the oil level light goes away
Re: weird problem
Sensors use a 5v reference to be able to read it. It might be a break in the cable and it either kills or shorts the 5v. So yes it is possible that the share a power or earth and thatbth one can affect the other.
- Kingshill1@
Re: weird problem
thanks panic makes sense will go test weekend and see
- Kingshill1@
Re: weird problem
any way of testing these wires maybe? or to find break is there a a diagram or route sketch for the loom?
Re: weird problem
I have never seem a route sketch for a harnass in all my life. So not sure where you will find that other than the factory. It usually involves a couple of hours of hunting with a multimeter to the fuse box.
- Kingshill1@
Re: weird problem
seems it is a break in ground somewhere as my fan heater motor have short on and to get to that **** is crazy as need remove damn dashboard all together. did diagnostics yesterday short on ground
