VW Polo 6 1.6 TDI
jmvangreunen
VW Polo 6 1.6 TDI
Post by jmvangreunen » Thu Feb 01, 2018 11:16 am
Good day all
I would like to know if you should do software when you decat the Polo 6 1.6 TDI as my cat is clogged up and really giving me a hard time with injectors leaking the car has been broken now for 3 months and its just costing me money and more money !!!!
Any advise regarding the decat would be really helpfull
Ashveer03
Re: VW Polo 6 1.6 TDI
Post by Ashveer03 » Thu Feb 01, 2018 5:33 pm
That car should have a dpf - so yeah if u do a dpf delete and decat then u will need software..
Some tuners can just delete the dpf from the file at a cheaper price
8VALVE-zn
Car Make: VW Golf 1
Car Model: 2.0 h8 valve
Post by 8VALVE-zn » Fri Feb 02, 2018 8:22 am
RK Motion charges the same price for DPF delete without remap and stage 1 with dpf delete
2000 Golf 1 Chico- CRANKCASE [Std bottom end, head gas flowed,ported & chopped by Fastcar, 288 Estas Billet, 4-2-1 43mm Brospeed Branch, 50mm-57mm-63mm Exhaust] + THE PART (2B1 speacials) -Final power @ Autotrix 111wkw & 210wnm :drool:
2011 Jetta 5 1.6 TDI DSG - CRANKCASE Tow Services [CPI Stage 1 with DPF Delete]
jmvangreunen
Post by jmvangreunen » Fri Feb 02, 2018 1:04 pm
Thanks !
At what cheaper price can it be done ?? As one guy gave me a quote now for almost 9k which sounds hectic ??? Or is that the price ???
Do you know if any place around the East rand that does this ???
THANKS
Ashveer03
Post by Ashveer03 » Fri Feb 02, 2018 5:20 pm
Watsup 8valve - yeah maybe now things changed.. lol
@OP 9k is a stupid price. A file should cost u around 3k and a downpipe around 2k.. prices may differ abit since u in jhb..
Most exhaust shops can build u a downpipe and most tuners can sort the software out.
There is a rk motion tuner somewhere around jhb aswell. Google them
jmvangreunen
Post by jmvangreunen » Mon Feb 05, 2018 4:11 pm
Thanks for the reply
had the car at Noise boys in Boksburg today the car don't have a DPF but does have a CAT they charged me R1550.00 to decat.
But still have the same issue car still have no power. Don't know what to do or check any more on the car
8VALVE-zn
Car Make: VW Golf 1
Post by 8VALVE-zn » Fri Feb 09, 2018 1:50 pm
That is utter non-sense!! I can't believe that they said this to you!
On the Polo the DPF is just at the part where the standard downpipe leaves the engine compartment and the exhaust starts.
On my Jetta, the DPF is literally out the exhaust side of the turbo.
Even tho you got screwed around, I'm sure the car sounds nice.
8VALVE-zn
Car Make: VW Golf 1
Post by 8VALVE-zn » Fri Feb 09, 2018 1:54 pm
Yo Ash, it was a recent happening but none the less I'm super happy with the CPI file and the service Myen offered. It took me two years to decide to go with the file and now I ask myself, BUT WHY SO LONG!!
Ashveer03
Post by Ashveer03 » Fri Feb 09, 2018 2:03 pm
Anonymous wrote:Thanks for the reply
Iirc all of the 2010 upwards vws have dpfs..
Whether they know the difference between a cat and dpf - i dont know.
The easiest way to identify - the dpf has a few sensors on it and the cat doesnt.
So once the dpf is removed or emptied out, get the car tuned (u have to get it tuned once dpf is removed). They will remove the "dpf" of the software and ul never have that problem again.
Ashveer03
Post by Ashveer03 » Fri Feb 09, 2018 2:04 pm
8VALVE-zn wrote:Yo Ash, it was a recent happening but none the less I'm super happy with the CPI file and the service Myen offered. It took me two years to decide to go with the file and now I ask myself, BUT WHY SO LONG!!
Yeah makes a big difference bro, on economy and performance.
8VALVE-zn
Car Make: VW Golf 1
Post by 8VALVE-zn » Fri Feb 09, 2018 2:29 pm
Averaged 4.3km/100km driving up to JHB- aircon on the entire way fully loaded with four adults packed for 10Days
Averaged 3.9km/100km driving down from JHB- car loaded the same.
What I did notice is that the car started up so much better in JHB- with the high idle on start up until it reaches an optimal point. The car doesn't do that here in Durban, the start up is way more rough which I hate! Also, just a quick one- After the DPF has been removed I noticed a bit of white smoke on start up, its a light coloured white smoke that only lasts about 3sec and then stops. Do you think I may have a leaky injector?
Ashveer03
Post by Ashveer03 » Fri Feb 09, 2018 2:42 pm
Not really sure hey, a leaky injector will give u some other symptoms other than just a little smoke on startup which is pretty much normal for a diesel.. if the smoke started after the software, it could be a "hardstart" to the file.. basically it gives a little more fuel to start up quicker - check with ur tuner if he did that or not
8VALVE-zn
Car Make: VW Golf 1
Post by 8VALVE-zn » Thu Feb 15, 2018 3:12 pm
Sorry for the late reply Ash, thanks for that.
Well to be honest I'm not sure if the issue was there before the software because the DPF was still in place, not sure if I'm noticing this because of the DPF being out. I feel that the idle is a bit to low as well on start up, its around 750rpm, instant consumption at idle is 0.4l/hour, however if I hold the rev at 900rpm the instant consumption is 0.3l/hour which is what I think it should be. Also at 900rpm the car sounds so much more healthy!!
Send me a pm with your number, I will send you a video instead.
Ashveer03
Post by Ashveer03 » Thu Feb 15, 2018 10:26 pm
Ok cool
